Old 07-23-2020, 06:46 PM   #1
skurela
Default Planning for a B230ft 16V build
Hi all, I am planning on building a B230ft with a 16v head, and wanted to have some input with my plans. I've tried to read as much as I could on TB and SS to have a general idea. So far I have acquired the head, which I feel like was the hardest part. I've never built an engine or done a swap before, but I've worked on a few motorcycles and feel confident in that department, and will have my friends who have done this stuff, as well as my dad helping me.
I am going to completely rebuild the engine regardless, and the head as well. I intend on converting it to coil on plug & running an MS3 using the same coils that Yoshifab uses, the motorcycle style ones.
I will more than likely be buying new rods & pistons, as I don't particularly want to take the risk with worn parts. Now I am debating whether or not to find a 2.5 crank & run that, but I am honestly not sure how much of a benefit it is since I can't find too much information on a built 16v b230ft 2.5. But anyways, here are my plans, with most parts being sourced from Yoshifab.
So I guess I intend on completely rebuilding the head & engine as I feel like my power goals of 300+ would be worthwhile to just get a built motor out of the way, however this is kinda where my knowledge ends, and I come to you all for input. Should I upgrade the head valves and put larger ones in since it needs a rebuild anyway? Is it worthwhile to go stroker? What turbo should I use?
Sorry for the inexperience, but I feel like there's no better way than to just go for it.
Parts I plan on:
Turbo 86mm pistons (if stroker)
158mm h beam rods (if stroker)
Redblock DSM CAS Adapter
Coil on plug stuff
rebuild springs & bearings & gaskets
regrinded camshafts from YF
YF engine / cam gears
Eaton Detroit TrueTrac
YF / DeeWorks T5 WC cross member & swap kit
I assume that the clutch & turbo are moreso going to depend on the horsepower goal, so I am not sure what to go with in that department. Again, sorry for the inexperience, but also thank you all for input and guidance, I very much so appreciate it.
edit: I intend on putting this all into a 242.
skurela is offline   Reply With Quote
Old 07-23-2020, 10:50 PM   #2
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
Sell the head to me when this doesn't get done
94 940T "Deb" build under way http://forums.turbobricks.com/showthread.php?t=354303
B5.5 passat wagon, low af sexier than most wagons here.
Old 07-24-2020, 12:12 AM   #3
skurela
Worst case scenario if my ambitious project doesn't get done, I still have a running 244 & a 245 I can just cut the piston reliefs on, not giving this thing up!
Old 07-24-2020, 12:42 AM   #4
Awaffa2003
We're in the same boat man, except I'm working with my B23. Planning to +t at all?
Awaffa2003 is offline   Reply With Quote
Old 07-24-2020, 12:44 AM   #5
skurela
Yeah, I do not have a motor yet for this build, trying to weigh the options of a b230ft as a starting block or a regular b230f. I figure if I send the engine to the machine shop anyways, might as well just use a b230f & have them drill out the stock location for the turbo return line. I can't lie & pretend I know how to pick a turbo, or what trim size & compressor size is, so I haven't really picked a turbo out yet.
Old 07-24-2020, 12:49 AM   #6
Awaffa2003
Same. I try to listen to these guys and see what's been done before, but you know...the whole opinions are like a$$holes thing. Wait until someone chimes in on the whole divided manifold that you CAN'T BUY ANYMORE from RSI...
Old 07-24-2020, 12:53 AM   #7
skurela
I figure I am just going to have to bite the bullet & go to a local fab shop & have headers & custom intake made. On one hand, I feel like I am headed in the right direction, but on the other hand I feel like I am partially going into this blind yet still confident.
Old 07-24-2020, 01:22 AM   #8
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
i bet those 86mm pistons might be a bit sloppy ;)
i have a dsm cas for sale if you need?
Old 07-24-2020, 01:23 AM   #9
culberro
culberro's Avatar
16v turbo manifolds are available, you just have to be okay with spending $800-1000 for one.
Decent intakes are also available, just spend $500.
For your HP reference, Harlard made 295ish whp on a 2.3 16v at 10psi using a 90+ 8v manifold and Chinese 3071 turbo.
Old 07-24-2020, 11:15 AM   #10
skurela
I am fine with spending the $$$, would prefer to do it right. I assume that after the built motor NA, all the power after that depends on how much I want to spend on a turbo?
What do you ean by the 86mm pistons maybe being sloppy? Should I plan to use a different piston? If i decide to go stroker I will get the 80mm stroke pistons from YF, unless there are other pistons recommended.
Old 07-24-2020, 12:06 PM   #11
oldschoolvolvo
oldschoolvolvo's Avatar
In a 240, the Yoshifab adapter / 90+ manifold requires hammering (or cutting/re-welding) the inner strut tower to make it fit with anything bigger than a 13C.
Example 1: https://lh5.googleusercontent.com/-1...hoto%25205.JPG
Example 2: https://i.imgur.com/IDiKT87h.jpg / https://i.imgur.com/xQjlC2ph.jpg
Yoshifab or Sweden Exhaust would be the top choices (IMO) for a high-hp 16v turbo manifold (outside of making your own).
https://www.instagram.com/p/B5av4zeHPHN/
http://swedenexhaust.se/en/volvo/378...volvo-16v.html
Some inspiration if you want to make your own fancy manifold:
http://forum.vccn.no/showthread.php?...-Tips-og-Triks
You can always do a basic log manifold too...depending on how large of a turbo you want to use (fender clearance considerations).
https://www.ebay.com/p/9023444155?ii...kaAsU4EALw_wcB
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
oldschoolvolvo is online now   Reply With Quote
Old 07-24-2020, 12:22 PM   #12
culberro
culberro's Avatar
The strut tower just needed some slight adjustments
Old 07-24-2020, 12:43 PM   #13
JanB
3.0L 16v plans ?
JanB is offline   Reply With Quote
Old 07-24-2020, 05:44 PM   #14
JerryJS8
der Junge
JerryJS8's Avatar
Ohhhh, fresh blood for another 16v Turbo build
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) 16v Turbo
Old 07-24-2020, 10:16 PM   #15
Wilford Brimley
LOCAL ONLY
Inb4 it doesn't get done cause it's too expensive
Old 07-25-2020, 02:05 AM   #16
Marvelous3
Who engineered this?
Marvelous3's Avatar
You’ve identified like $10k worth of parts to invest in a car that will make 300 horse and be sometimes reliable.
Here, I’ll help.
https://www.jegs.com/p/Chevrolet-Per...27486/10002/-1
Old 07-25-2020, 12:32 PM   #17
skurela
That's why I made the thread, trying to figure out from people who have done it before & have better knowledge on the topic what is worthwhile doing & what isn't. Had a ball park range of cost, but isn't that the fun of it, keeping it all Volvo parts, haha.
Here, I’ll help.
Thanks, will consider this.
Old 07-25-2020, 12:32 PM   #18
skurela
Originally Posted by JanB View Post
3.0L 16v plans ?
Maybe, trying to get an idea on what is worthwhile to do & what isn't.
Old 07-25-2020, 07:11 PM   #19
dafke
I'f he don't want it, i want to buy the CAS from you !!
dafke is offline   Reply With Quote
Old 07-25-2020, 10:46 PM   #20
Wilford Brimley
LOCAL ONLY
Still want the head...but who doesn't
Old 07-25-2020, 11:09 PM   #21
permavirgin777
Here, I’ll help.
I also suggest this route (or something similar e.g 4.gr8, 5.3, etc). He just said it in a way that is simpler and less jaded than I ever could.
Originally Posted by ovlov760 View Post
Best to stay a virgin and drive a 2/7/9 forever.
permavirgin777 is offline   Reply With Quote
Old 07-25-2020, 11:53 PM   #22
skurela
After doing a lot more research, thought I had done as much as I could, I figure I will upgrade slowly over time instead of jumping in head first. Prefer to keep it all Volvo, but for the meantime I am gonna reassess my plans & expectations. Thank you everyone for the reality check, had my head in the clouds.
