Old 07-24-2020, 10:20 PM   #1
Wilford Brimley
LOCAL ONLY
Wilford Brimley's Avatar
Default Retroturbo coilovers
Anyone use them on a 7/9? 500ish usd, thoughts?
94 940T "Deb" build under way http://forums.turbobricks.com/showthread.php?t=354303
B5.5 passat wagon, low af sexier than most wagons here.
Old 07-25-2020, 01:25 AM   #2
Sjeng
Sjeng's Avatar
- Hardness front: 10kg / mm .
- Hardness rear: 8kg / mm
450lb/in rear. Way too stiff for a 7/9 mate.
I hve 225lb/in in the rear and that's already stiff.
Old 07-25-2020, 01:48 AM   #3
Wilford Brimley
LOCAL ONLY
Honestly I dont know much about this stuff for these cars. Just trying to do my suspension a little better this build
Old 07-25-2020, 06:44 AM   #4
classicswede
Volvo upgrades
Is that the ones that say the warranty is void if you drive fast?
If you want something good that will not break the bank with spring rates that are correct and if not to your liking easy to change then consider
for the front https://www.classicswede.co.uk/Weld_..._16251176.aspx
and for the rear https://www.classicswede.co.uk/Adjus..._16754546.aspx
