Old 07-25-2020, 05:28 PM   #1
blakemcelroy2000
Default Volvo Amazon-VDO Tach not working
Hey all, Im reaching the end of my 122 restoration and Im installing a VDO tach. I have a keyed power in, a wire going to the negative of the coil, and a good ground. The tach is a three plug, which coding switches for different engines. When the car is started, the tach doesn’t move. Im pretty sure its wired correctly with the correct sequence of coding switches, and both the ground and keyed power is good. Any suggestions?
blakemcelroy2000 is offline   Reply With Quote
Old 07-25-2020, 05:42 PM   #2
Try double checking the coding switches. Just to be sure it's proper. Make sure the tach is set to be triggered by points.
1982 242 turbo. 340k miles. MVP coilovers and 3" exhaust. Flowed 405 with a V15. Cossie turbine housing with upgraded compressor housing. 90+, IPD remote oil filter. Some other goodness, too. Been lots of fun over 25 years. Restored in 2k. Now ready for a 2nd restoration.
Old 07-25-2020, 07:16 PM   #3
blakemcelroy2000
I have a magnetic pointless system installed on my engine. Would that change anything?
Old 07-25-2020, 07:18 PM   #4
planetman
planetman's Avatar
I just recently installed a new VDO tachometer in a customers 142S that I bought from a speedometer shop.
Can you supply the part/model number and/or installation instructions of the tachometer?
FYI, I had trouble with the VDO tachometer and I was only able to make it work and read correctly after I installed a "filter" the speedometer shop supplied after the fact.
Eric
Torrance, CA 90502
planetman is online now   Reply With Quote
Old 07-26-2020, 02:19 AM   #5
blakemcelroy2000
Its the VDO product number 333051. Black face with an adjustable orange shift “hand.” Has three terminals the on the back in the 2,3,4 slots, and the rest are empty. Has three coding switches.
