Old 07-27-2020, 09:34 AM   #1
lionhearted
lionhearted's Avatar
Default Wrong oil
Good Morning, just wondering if Iíll be ok for 5000 miles? I accidentally put 5/20 Full synthetic oil in my wifeís 2013 xc90 3.2 instead of 5/30. Or should I dump it back out now. Which I hate to obviously or maybe go 3000 and dump it? Thank you. Itís got 90000 miles.
lionhearted is offline   Reply With Quote
Old 07-27-2020, 09:44 AM   #2
iHateVolvoPeople
It will probably be totally fine, but given the cost of doing it right, I would change it out. Reason being is that the engine is designed with bearing tolerances designed for 5w-30 oil. A simple drain and fill with 5w-30 will be enough, and it's basically like you accidentally "flushed" your system. It should be REALLY clean now.
Back in ~2014, my girlfriend took her GS300, 2jzge engine, into Toyota for tires and an oil change. It had 220k miles and they must've put 0w-20 or something it in because it was the noisiest I've ever heard the engine. I changed it out with a 10w-30 and it was quiet as could be again.
Feedback Thread
Current:
'93 244T M47
'95 Camry A140E, 254k
'99 Camry A140E, 256k
'04 TSX 6MT, 210k
Old 08-01-2020, 12:08 AM   #3
84B23F
84B23F's Avatar
Originally Posted by lionhearted View Post
...2013 xc90 3.2 instead of 5/30.
Does this engine have variable valve timing? If so read this:
I accidentally put 5W-20 oil in my car when it takes 5W-30. Am I in any trouble if I drive it until the next oil change interval?
Myself, I'd add a can of STP, which will thicken oil
Old 08-01-2020, 12:13 AM   #4
84B23F
84B23F's Avatar
I suspect hydraulic lifters created the noise...not enough oil pressure, so they were quacking.
At 220k miles, oil pump would not produce enough pressure with a lighter weight oil.
Old 08-03-2020, 04:13 PM   #5
lummert
lummert's Avatar
As mentioned, Add STP to thicken oil.
Old 08-03-2020, 06:10 PM   #6
I add stp every other oil change just to keep some zinc on the cam and followers.
Old 08-04-2020, 12:43 AM   #7
c1800
Change the oil, now.
Old 08-04-2020, 09:26 PM   #8
2turbotoys
Salaminizer once again
2turbotoys's Avatar
Drain it into something clean and reuse it in another vehicle
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
