Old 07-28-2020, 08:45 AM   #1
VolvoGLT
Default wheel hub differences?
Skandix says that Volvo used a different wheel hub for the earlier models (until 1978) and the later ones (1979 up). Does a 1980 hub fit on the later strut housings that were used after 1981? The later spindles are thicker and require different wheel bearings - just not sure if the outer diameter is the same or different between early and later strut housings.
VolvoGLT is offline   Reply With Quote
Old 07-29-2020, 01:25 PM   #2
The early wheel hubs using the smaller inner bearing don't fit the 81 and later spindles if I recall correctly.
Old 07-29-2020, 03:02 PM   #3
billkaz
Bomber Dream
billkaz's Avatar
Will the newer bearings fit into older hubs?
My rockauto research shows the newer/older bearings with an OD of 60mm vs 59.1mm for the outers and 46mm vs 45.2 for the inners. Does that fraction of a mm make a crucial difference?
1992 240 Wagon
2006 Mazda6 Wagon
billkaz is offline   Reply With Quote
Old 07-30-2020, 02:10 AM   #4
petiww
petiww's Avatar
Dont even try to interchange them, it wont work. All diameters are different.
1980 Brown 244 GL
Old 07-30-2020, 02:58 PM   #5
The inner diameter of the inner bearing is much smaller. The outer wheel bearing is the same.
Old 07-30-2020, 03:17 PM   #6
It wont work,
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 07-30-2020, 03:54 PM   #7
VolvoGLT
Thanks guys, looks like I'll get the hubs as well then (doing a complete suspension rebuild on my 1980 GLT and will upgrade the strut housings to the later style).
Skandix should update their wheel hub info.. 1980 is kinda like the red headed step child: for hubs they say up to 1979 and for struts they say 1981 onwards lol
Old 07-30-2020, 04:21 PM   #8
The Librarian
According to the parts catalog the change occurred early in the '81 model production.
