Old 07-29-2020, 01:01 PM   #1
stayathomedad
Default Overheating Situation
Hey guys, I'm running an old school dual carb set-up. I know that's not typically discussed here but I'm hoping you guys might be able to help me with an overheating situation.
I'm running a B230, 531 Head, V cam, dual carb. I'm fairly certain I installed the head gasket correctly, it has a new water pump and new thermostat (180 degrees). My temp gauge is telling me its running around 210 degrees plus.
First, I dropped my new thermostat a few times before install on accident. Is it possible I broke it and this is my problem?
Second, I'm running a Volvo temp sending unit and an Autometer temp gauge. I've read these two don't always get along too well and the gauge could read 30 degrees hotter then the actual temp of the coolant. Does this actually happen and/or is common or was that just bogus information?
Third, the dual carb intake manifold has a type of coolant bypass where a coolant passage from the head near the number 4 intake runs through the intake manifold to a coolant passage near the number 1 intake. HOWEVER, the coolant passage near the number 1 intake is closed/plugged/blocked. Essentially coolant just sits in the intake manifold. Should the coolant passage near the number 1 intake be open so coolant freely moves through the intake manifold bypass? And, could this be why the motor is getting so hot?
Lastly, is there anything else that could lead to a hot motor condition?
Thanks for any information guys!!!
Keith
stayathomedad is offline   Reply With Quote
Old 07-29-2020, 01:07 PM   #2
kyote
Living The Dream
kyote's Avatar
I would verify at thermostat housing with an IR temp gun.
Running boat carbs?
Volvo sending unit with autometer gauge is likely the problem IMO.
Old 07-29-2020, 01:07 PM   #3
Dan
Watching the World burn
Dan's Avatar
It's possible the temp sending unit and gauge have different ohm values, get a matched set and try. Radiator fins unclogged? fan spaced correctly inside shroud? (half in/half out). I'm not too worried about the coolant passage being plugged, but I would try to fix it if possible
1985 Chevy TPI V8 740.
Old 07-29-2020, 01:09 PM   #4
apachechef
Burnt Sierra Madre
Running boat carbs?
this check temp with good thermometer first.
Dammit, Lummert.
Old 07-29-2020, 01:16 PM   #5
The Librarian
Verify engine temp with a non contact IR thermometer.
I seriously doubt the Auto meter gauge will read properly with a Volvo sender.
An adapter is available so you can use the Auto Meter sender.
http://forums.turbobricks.com/showth...hlight=adapter
Not circulating coolant through the intake won't cause the engine to overheat.
Old 07-29-2020, 01:20 PM   #6
stayathomedad
Sounds good guys, I'll get myself an IR Temp Gun and check temperatures around the head and temp sending unit.
I'll hit up Culberro to see if I can get and adapter from him. I think I sent him a PM but for some reason when I send a PM it never displays whether or not I sent anything. My sent box is empty but my inbox is full lol
Old 07-29-2020, 01:38 PM   #7
The Librarian
You need to change the setting in your user control panel to save sent messages.
Old 07-29-2020, 01:44 PM   #8
stayathomedad
Ah, got it. I went ahead and changed that. Of course, I sent a message before I changed the setting so I'm assuming it will only save messages I send from here on out....
Old 07-30-2020, 10:59 AM   #9
stayathomedad
I find it odd that the Volvo oil pressure sending unit seems to work fine with the Autometer oil pressure gauge. Any ideas why that might be?
Old 07-30-2020, 11:58 AM   #10
culberro
culberro's Avatar
It just happens to be a similar resistance range.
Old 07-31-2020, 12:44 AM   #11
stayathomedad
Basically just luck then. That's good though, at least you only need to worry about one instead of both.
Old 07-31-2020, 08:26 PM   #12
stayathomedad
Update: got the IR temp gun and checked everything. Its definitely the sending unit communicating innacurately. Thanks for the all the help guys! I'll get the adapter from culberro and I'll be set!
Old Yesterday, 10:58 AM   #13
kyote
Living The Dream
kyote's Avatar
Glad to hear it was something easy!
