Old 07-29-2020, 10:54 PM   #1
ogamer777
Loading...
ogamer777's Avatar
Default Opinions on NA build vs turbo build: B23F/M46
I recently redid all the suspension on the 84 242 I have with Kaplhenke stuff; so spherical bushings all over the place, coilovers, adjustable rear spring perch...basically the whole catalog. Well now I am remembering how slow the car is. I want to introduce more power to it. I plan to track it in some way. What can provide some decent power? I would like to aim for somewhere in the 250-300+HP range at the end of the day. Just wanted to get some opinions on what some of you guys have done. All of my other turbo cars have been KJet, in fact, this is my only LHjet car I have owned.
84 242 DL M46 212000Mi
82 244 GLT (15G) M46 243500Mi 23 Aug 2019
79 242 GT 1 of 600 Aussie RHD BW55 312223Km
83 245 TURBO M46 "117000Mi"
81 264 GLE M46 105k
Feedback thread: http://forums.turbobricks.com/showthread.php?t=322924
ogamer777 is offline   Reply With Quote
Old 07-29-2020, 11:09 PM   #2
2turbotoys
Salaminizer once again
2turbotoys's Avatar
NA 300 hp= big $$$$$$$ plus work
Turbo 300 hp = much smaller $ plus work
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
2turbotoys is online now   Reply With Quote
Old 07-29-2020, 11:59 PM   #3
culberro
culberro's Avatar
220-250hp NA is about $2-2.5k in parts and machine work if you’re going with all new stuff.
300hp is an Evo 8v, which was $14k used the last time I saw one for sale. It did include the ITBs, ECU, and drysump system.
Old 07-30-2020, 03:36 PM   #4
Awaffa2003
So why TF do people piss on itb's when the Evo kit uses them?
Awaffa2003 is offline   Reply With Quote
Old 07-30-2020, 04:28 PM   #5
oldschoolvolvo
oldschoolvolvo's Avatar
Def more straightforward to go the turbo route to reach that goal.
-Mike
1998 V70 T5
1979 242 DL 16v
|Feedback|
Old 07-30-2020, 05:13 PM   #6
Broke4speed
Broke4speed's Avatar
I'm gonna say that ITBs on a stock head and cam are basically useless, that's why. There will be some gain, but unless they're properly sized/tuned for the intake tract and have MANY breathing mods...the benefit will be small. The Evo 8v needs ITBs to breathe properly.
Old 07-30-2020, 06:04 PM   #7
ogamer777
Loading...
ogamer777's Avatar
Thanks for your input. Turbo it is.
Now with LH2.0, should I update the system with a newer LHjet version?
Old 07-30-2020, 06:16 PM   #8
oldschoolvolvo
Yes, def update.
For an 84, it is probably easiest to convert to LH2.2 & EZ-117K. You can buy a wiring harness from Dave Barton.
LH2.4 + EZ-116K is newer and handles modifications better, but is a bit more involved to retrofit to a car that did not come that way originally (crank position sensor, VSS signal).
Old 07-30-2020, 06:16 PM   #9
culberro
culberro's Avatar
See below
Bingo. Most people don't go with the proper supporting modifications and tuning to take advantage of the side drafts or ITBs.
With ITBs, they are definitely more challenging to tune for driveability with most ECUs. Wide open tuning is the easy part. Part throttle and just off idle is a pain.
Side-draft carbs can be pretty easy to drive around town when on a proper setup.
Old 07-31-2020, 12:37 AM   #10
122power
dude
122power's Avatar
Idk my lemons wagon with lh 2.0 and rsi cam and t5 is a hoot to drive and im not complaining. Even has the chrysler ignition still. It wasnt the slowest volvo on the track ill say that.
Turbo is turbo. NA with some upgrades is pretty fun tho. No its not 300hp but still fun to drive for what it is.
Just depends what you want out of the car pretty much. A t5 is so much fun to shift though. But i do love my high comp b23 and m46 in one of my driver cars. 2.0 with 2.2 maf conversion and chrysler ignition, 3.54 axle. That thing pulls like a freight train. M cam too lol.
Step one swap cam.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
122power is online now   Reply With Quote
Old 07-31-2020, 12:44 AM   #11
James M
Probably colorblind
James M's Avatar
Turbo, get a little one for a nice not peaky powerband and cut the cost of the rest of the motor build in half (or fourths) to reach 250hp
Old 07-31-2020, 02:51 AM   #12
John242Ti
LH-Jet & Carb Free Zone
John242Ti's Avatar
Step one swap cam.
Ethan's car is basically the same as your daily, but with the "846" block, so the cast crank/piston low compression B23F that has the more aggressive advance curve Chrysler box instead of the relatively tame box of the high compression engines. 3.31 was swapped out for a 3.54 in 2017. Exhaust is already turbo compatible, being a 2.5" system with Magnaflow in the stock rear location.
-J
@1982_volvo_242_turbo on IG
