Old 07-31-2020, 08:50 PM   #1
stayathomedad
Default Setting the Distributor and Timing
Hey all, I've noticed that when I have the B230 motor running the only way it's happy is if I have the dizzy turned all the way counterclockwise to the point that it maxes out on the bolt. I'm finding this is proving to be difficult to actually get it timed correctly as I can't move it anymore.
Can I remedy this by moving the dizzy one tooth and if so which way?
Is a good baseline timing roughly 12 degrees?
And lastly, what is a good idle RPM for these motors?
Thanks!!!!
stayathomedad is offline   Reply With Quote
Old 08-01-2020, 12:52 AM   #2
bobxyz
bobxyz's Avatar
I'm assuming LH2.2 (what year is your 240?), so idle timing should be 12deg @ 750 rpm (IIRC). When wrenched over to TDC, the end of the disti rotor should roughly be over the scribe line in the edge of the disti housing.
Old 08-01-2020, 02:07 AM   #3
First of all, was there any recent work done to the vehicle?
Dropping the block-mounted distributor in place can be a little tricky. You gotta start ahead of the mark and it will "twist" in as it meshes with the gear.
Year/make/model, please.
Old 08-01-2020, 10:55 AM   #4
apachechef
Burnt Sierra Madre
60 degrees Ahead
Dammit, Lummert.
Old 08-01-2020, 04:40 PM   #5
stayathomedad
Hey guys, thanks for the responses. As far as work goes, I started with a donated B230 (unsure which vehicle it came out of). I put a 531 head on it and stuck a V cam into it. As I mentioned it is running and seems to be happy with where the dizzy is sitting right now, but it's only "timed by ear" which is why I'd like a little more play to see if it would be happier if I'm able to move it even further clockwise.
I'll open the dizzy up today, wrench the motor over to 0 degrees TDC and see where the rotor is lining up in relation to the scribe line. Hopefully that'll free up some space to turn the dizzy a bit so I can get it timed to the 12 degrees at 750 rpm.
Old 08-01-2020, 07:42 PM   #6
122power
dude
122power's Avatar
What year is your car? What year is your engine? Well its a b230 we know that. You can check your vibration damper also as they are know to slip, so your timing mark is always off. Best to find tdc on #1 cylinder and go from there. Take plug out stick long screwdriver in there and rotate engine over by hand till it goes up and stops moving before going back down. 24mm is the socket on the crank fyi. Once you have that done peek inside the valve cover under the oil cap to see of both cam lobes are at 10 and 2 position on the #1 cylinder lobes and or your cam gear matches the dot on the timing cover. IF that all checks ok then you can proceed to do ignition timing. Double check your damper mark to see where it is, should be on "0" off the lower timing cover. Then check the rotor inside the distributor as shown above.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
