Old 08-01-2020, 02:39 PM   #1
linkkjm
linkkjm's Avatar
Default B230FT Loosing Coolant
Hi all, have some Redblock issues. My B230FT is loosing a large amount of coolant. Pressure test on cooling system is great, compression test is great. Replaced all the cooling items, except the overflow tank and cap. Oil is not milky, but it does sizzle and crackle when I put a little amount on the manifold. No oil in the coolant. Recently replaced the oil cooler as well. Freshly machined head and new headgasket aswell. I honestly have no idea anymore. I can't seem to find any other threads with the same issues. Anyone got any other areas to check?
linkkjm is online now   Reply With Quote
Old 08-01-2020, 06:02 PM   #2
iamrolling
Is this a brick with an automatic transmission? Check the transmission dipstick. And soon. If the fluid is frothy, replace your radiator, do a transmission flush and pray that it isn't ruined.
iamrolling is offline   Reply With Quote
Old 08-01-2020, 06:33 PM   #3
2manyturbos
Try the opposite process. Hook up your pressure tester to the system, don't pressurize the system, start the engine and watch the pressure gage on the tester. I had a scenario like this on a LT1 powered Z28. What was happening in my case was the head gasket was only leaking under really high cylinder pressure. It would put so much pressure in the cooling system the cap would let the coolant out while driving. If I ran a typical pressure test, the cooling system would hold 15 psi for 24 hours.
Old 08-01-2020, 07:32 PM   #4
122power
dude
122power's Avatar
I had a coolant leak on a 85 245T. Did the headgasket and still had a leak or overheat issue. Pressure tested it as well and was ok. Then come out in the morning and had coolant around the exhaust manifold. Took that off and had a pinhole in the #4 exhaust port. Didnt show up in oil since it was going out the pipe.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
