Old 08-01-2020, 08:29 PM   #1
Texas Old Fart
Texas Old Fart's Avatar
Default overheat no low end power
Will cam tolerances and or distributor gear off by a tooth cause engine to run hot?
I have b230 NA with Turbo cam. 10 thou clearance on lifters. The heat gauge does not go above 1/3 scale, but an uncomfortable amount of heat is coming of the engine even on the intake side.
-Texas Old Fart-
1987 240 DL
Texas Old Fart is offline   Reply With Quote
Old 08-01-2020, 08:52 PM   #2
IansPlatinum
IansPlatinum's Avatar
Get an actual reading with an IR temp gun. Point it at the coolant hose, not at metal.
160F is cold for an engine but will scald your hand.
In other words, don't go by 'feeling'
The intake manifold has about 1mm of paper gasket insulating it from the head. So yeah that sucker's gonna get hot. Doesn't really tell you whether the engine is overheating or not
'96 854 Platinum - "Trusty"
'92 245 - "Boat"
'71 145 - "Rusty"
Previous:
'73 1800es - "Sunny"
'92 940T
'98 S70 T5
'99 S70 GLT
IansPlatinum is online now   Reply With Quote
Old Yesterday, 01:53 AM   #3
Tsayloco
Tsayloco's Avatar
If your distributor is off a tooth you would know it.
Edit* there would be a noticable power loss. I haven't seen that cause a major overheat in my experience. Could be two separate issues you re dealing with. Or the fabled overthinking of things. I'd check and or try clocking the distributor again for starters, it's surprisingly easy to get those off a tooth when your not used to them.
Tsayloco is offline   Reply With Quote
Old Yesterday, 08:55 AM   #4
2 old for this
Has the crank pulley slipped causing the timing marks to be off?
Old Yesterday, 09:52 AM   #5
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
over heating and now low end power sounds like excessively retarded ignition timing.
Megasquirt Tuning!
linuxman51 is online now   Reply With Quote
Old Yesterday, 10:08 AM   #6
Texas Old Fart
I should mention; I just replaced the belt and cam. I was pretty sure after many tries I got the belt aligned on the gears properly. After reassembly, the distributor had to be moved to fully counter clockwise to get the timing to 12 degrees.
Test drive result: poor acceleration, but good mid to high end power, 75 to 80 mph was easy.
However, when I returned to the shop, the had extreme heat coming off the engine. Much hotter than before the mods.
So I'm thinking I must have screwed something up.
