#1 |
![]() Hey all. I'm working out the last few bits of my M90 swap in my 740. I have been unable to find an M90 prop shaft or a shop who can modify an M46/7 prop shaft without shipping it to California or waiting longer than a month. This area SUCKS for car people.
I found this page: http://www.volvoturbo.net/Garagebilder%2023.html which tells me that my next idea of a spacer is at least possible. I'm going to draw this up and take it to the local fabricator but is there any particular type of steel I should tell him to use? Would regular mild steel hold up or should I use something more exotic? This setup will stop getting upgraded at around 300hp. Thanks! |
#2 |
educator monkey
![]() You're telling me there are no driveshaft shops in Florida?
#3 | ||
![]() Of course not. I'm telling you that there's only one that's less than an hour's drive from me, they couldn't do it (no tooling for the propshaft end) and he didn't know any others that could. Then I called around and every time I said 'Volvo' they said 'nope!'.
If I find one it's likely to be in Orlando and that means I have to spend 2 hours driving there and 2 hours back, then do it again when they finish the work. Or pay to mail the thing to them and have them mail it back, which I doubt will be much cheaper. Quote:
#4 | |
educator monkey
![]() Quote:
![]() Lengthening a driveshaft is not rocket science. Just don't tell the shops what it's from. Last edited by 740atl; 06-13-2014 at 10:13 AM.. |
#5 |
1994 960 B204FT, full options, leather interior. 1991 745 B204GT (Swede Sixteen VT) M90 conversion. 1986 745 B230FT, 302mm V70 brakes, camber mod. (sold) 1983 244 turbo B21FT/AW71 - leather /airconditioning 1987 244 GLT - Polaris, Strutbar, viking motorsport lower chassis brace, k-cam, gaz strut/shocks, pu-bushings |
#6 | |
![]() Quote:
#7 |
![]() why not forged aluminium? I think it is used for wheel spacers as well. It will be cheaper to machine. and it will be lighter.
#8 |
is DeeWorks.ca
![]() Join Date: Aug 2006
![]() I would use aluminum for that spacer. No need to go with steel and have it rust over the year. I would try to have it a little less thicker than what he did and maybe use flat head bolt that stay screwed in the adapter.
I did this adapter for Nathan, different purpose but same way of thinking. ![]() ![]()
94 944T - 16v turbo - 12,14@122 Lm7 5.3, S475, Ms3Pro, 4l80e - 10,36 @ 134 / 6,70 @ 107 www.deeworks.ca Need T5 Adapter? T5 Speedometer Plug? Gm Torque Converter Adapter? Freeze plug retainer? HE351 solenoid plug? Pm me! |
#9 |
![]() I'm fully aware. All I can tell you is that none of the shops around here will even look at it. Having a 9 to 5 job means I can't just go driving halfway across the state without a good reason.
I didn't expect this to be such a pain in the ass either, but it is what it is. I've spent the better part of a week making phone calls trying to figure out why there don't seem to be any competent shops around here. Every transmission shop and automotive performance shop I've spoken to has confirmed that they don't know anyone capable of working on Volvo drivelines. I appreciate your help though. |
#10 | |
![]() Quote:
![]() They hear the word Volvo and know it's some cheap F****r with a problem they'll lose money on and have to listen to whining when it's done |
#11 |
![]() when i was still wrenching on rally cars we had a volvo driveshaft shortened/lengthened (forgot) by a shop that does this kind of work for farm equipement, earth moving equipement and trucks. They had no issue whatsoever. did a fine job to.
#12 | |
![]() Quote:
And the ones that do are apparently Swedophobic. |
#13 | |
![]() Quote:
Tell them it is for a Jeep.... Most of the drive shafts use components that are "universal" and used in a lot vehicles. Find out what universal joints you have and see if you can cross reference it with a Jeep or some other application.
#14 |
Vintage anti-ricer
![]() Join Date: Oct 2004
![]() Call up the local shop, ask for the manager when you get told they can't retube a Volvo shaft. Ask him what is so different between a steel shaft on a Volvo and a steel shaft on (insert your favorite non-Volvo RWD car here). There ain't a difference.
Personally I'd go that route, but if they won't do it, yeah, go the alum. route.
RIP Doug Williams "Mr. Doug" 4/15/2009 Pete Fluitman "fivehundred" 7/14/2013 Mick Starkey "TrickMick" 1/10/14 Mark Baldwin "blue850t5" 7/19/18 Nick Fengler "fengler" 8/6/18 Thomas Fritz "stealthfti" 10/11/18 74 144 B20 http://forums.turbobricks.com/showthread.php?t=224983 90 745Ti http://forums.turbobricks.com/showthread.php?t=334698 If you need Superpro bushings PM me for price and availability! |
#15 | |
![]() Quote:
I'm working on a place that does a lot of European performance stuff but I haven't been able to reach them all week. Looks like I'm going to own a big chunk of aluminum soon. |
#16 |
![]() Some engine machine shops will weld and rebalance driveshafts.
I'm not sure why it's such a big issue. The driveshaft ends are welded between centers to keep them aligned. Any machine shop can do this, but a machined chunk of aluminum may be cheaper. |
#17 |
Vintage anti-ricer
![]() Wow, that manager needs to be taught how the real world works. Just curious what shop they referred you to? Driveline Specialties by any chance? If it's some other shop then hey, I guess we have 2 here in Cali. lol
Best of luck man, sucks the shops there are idiots. FWIW I called 4 machine shops for a basic bore and hone on my 230FT block. They were fine until I said Volvo, then came the 'we don't do Volvo's'. 5th shop said no problem, a block is a block, boring and honing is boring and honing, doesn't matter if it's european cast iron or american. Bingo, that's the shop I've had great luck with. Similar experience with getting a diff installed years back. All was fine til I said Volvo. Dana 30, sure no problem, in a Volvo? Nope can't do it. Idiots. |
#18 |
The Beloved Oarnge Juice
![]() Join Date: Aug 2009
![]() Sounds the like shop doesn't want to fab anything to make it work. If they took the time to make the tooling they won't have to say no the next time
Can you lengthen the rear driveshaft and repo the carrier bearing? That alum adapter roger made me is fitted in a BMW with a 700whp 1j and he launches the car at 10psi on drag radials at the strip around 4k in a manual car
962j 815/692@27psi ![]() SHEETMETAL INTAKEhttp://forums.turbobricks.com/showth...etmetal+intake THIS IS FORSALE V ![]() |
#19 |
The Blue Baastard
![]() We have the same type of shops in MA. No one wants to be responsible if (when) the custom piece fails and then get hit with a lawsuit.
Funny how everyone think it's so easy to find shops that do this type of work in every state.
Tony 1958 Volvo PV444 1983 245 Turbo - The Project - Targa Newfoundland entry - Sold http://forums.turbobricks.com/showthread.php?t=225396 2002 BMW M5 - Sold ![]() 2011 F150 FX4 Screw with Ecoboost V6 Past bricks - '95 855 manual, '98 V70 T5 Manual, '04 V70R 6-speed, '10 XC60 T6 |
#20 |
![]() Flar-duh.
John Vanlandingham/JVAB Imports Sleezattle WA, USA --> CALL (206) 431-9696<---- www.rallyrace.net/jvab www.rallyanarchy.com Vive le Prole-le-ralliat "When a man tells you that he got rich through hard work, ask him: 'Whose?'" — Don Marquis |
#21 |
#22 |
#23 |
![]() Join Date: Dec 2006
![]() I have a m90 740 front driveshaft.. I have a M46 740 front driveshaft. I'll take measurements and pics here in a sec for you. YOu don't say what front driveshaft you have. You'll need either a 740 M46 turbo or 740 m47 as they both have the front quibo connector. I remember someone use two quibo's as a spacer before for a getrag conversion. I'll see what I have for front driveshaft's and compare them to the 740 M90 one I have.
#24 |
![]() The front of the M90 driveline is a guibo, a guibo like the BMW-O's... The back end of the front section of the two piece driveling is a splined slipper inner.. No u-joints to joint with.. Snot one on the front section of the m90 driveshafted.
Mull that over Mueller..ha. I will get those pics and measurements later today, got sidetracked yesterday. |
#25 |
![]() Old ford rangers actually have a spacer on the diff shaft yoke. Iirc its about the same size as the guibo on a 740. Drill the holes straight and rock that badboy. Its also made from forged steel.
Thread Tools | |
Display Modes | |
