- Dec 25, 2002
- mont, AL
From "it's just a number"
https://youtu.be/MrAQbNJx9BU
on the last two pulls of the day I added .5 degrees of timing each time (first one picked up ~30 or so, second picked up another 20 some odd), and had something in the driveline not started making a noise, I'da bumped it again and probably would've ended up over 700whp. Next time.
ran in to a couple technical challenges, rear brake caliper was hanging up at the beginning, not frozen, but the crusty lines are probably failing internally and blocking the fluid from returning when pressurized.
couple leaks here and there, and culminated in a transmission noise that I initially thought was a tire failure (but it didn't vibrate, just sounded like it). put the car back in drive at idle and things could be heard making noise, so we stopped there. no desire to have a catastrophic transmission failure at 6000+ rpms lol.
on the last log, it tickled 39psi and settled down at around 37.5 or there abouts.
anyway, enjoy!
setup:
NA pistons flycut.
ebay hbeam rods
Yoshifab cams
th400 with a 5800rpm stall converter
fresh pump e85.
anyway, enjoy!
setup:
NA pistons flycut.
ebay hbeam rods
Yoshifab cams
fresh pump e85.
