- Nov 19, 2002
- California
Step one is get power to the injectors and then work on the control side. I find it difficult to believe both sides of the circuit are bad. Ground side should be over 1000 ohms. I don't trust your readings. If you unplug the ecu, that same test would go to OL if you did things properly.
Do the tests I developed in that previous post while looking at a Haynes manual on the John Crapper this morning before work. I was late to the auto shop.
A wiring diagram is more valuable than 1000 posts. Study up. I have nice clean ones available online in interactive format at the shop. Old Volvo diagrams are tougher to read and tougher to find, but you gotta learn to use one and do it well. Parts swapping is no bueno. Even with duct tape, that part may have still been good.
