haltechsupra
- Jun 22, 2004
- Texas
Required fuel is 3.9 ms. As far as the kpa, I am using a holley 5 bar map.
low req fuel allows a more finely grained tune (if you need it/want it), as long as you have enough to meet the highest demands. think 255 is the highest value you can use on the ve table.
also, on the siphoning for the alcohol inj, a lot of folks started using solenoids for nozzles installed after the tb that are subject to vacuum. food for thought, wouldn't be much to install some and have them come on with the pump.
What kind of scaling is going on with that VE table?
