Old 06-09-2019, 07:16 PM   #1
ogamer777
Loading...
ogamer777's Avatar
Default 262c front speaker options
Any 262c bertone guys with OG door cards, what front speakers did you go with? There's like, maybe, 1.5 inches of clearance to the window.
remember that the speaker goes behind the built in speaker grate in the door card so the speaker has got to be pretty shallow
84 242 DL M46 212k
82 244 GLT (15G) M46 239900k 3 June 2019
81 264 GLE M46 105k
Feedback thread: http://forums.turbobricks.com/showthread.php?t=322924
Looking for some hard to find Volvo accessories for my 82 GLT. Especially rubber trunk mats.
Stuff I have already:
http://forums.turbobricks.com/showthread.php?t=331526
ogamer777 is offline   Reply With Quote
Old 06-10-2019, 03:10 PM   #2
nel621
For my first Bertone way back when I was able to find very thin speakers from Crutchfield. Don't remember the brand. In this red Bertone , made for the president of Volvo, you can see they went with a more surface mounted speaker.
I haven't looked into what speakers are currently available. My coupes still have the OE speakers.
Old 06-10-2019, 03:37 PM   #3
TestPoint
TestPoint's Avatar
Crutchfield did, indeed, have thin speakers that fit under the OEM grill. The Bertones are getting scarce enough that I would never consider anything other than the OEM grills
Ford V8 Conversion Manual -
Old 06-10-2019, 06:53 PM   #4
ogamer777
Loading...
ogamer777's Avatar
yeah, there is no way i am cutting into the factory speaker grills. It's looking like i'll have to go with marine speakers or tweeters and put a speaker in the middle of the dash
Old 06-10-2019, 07:17 PM   #5
philski o'flood
philski o'flood's Avatar
aren't the factory "grilles" just small holes in the wood?
Old 06-10-2019, 07:31 PM   #6
JohnLane
Like Volvo did for DL models with AM only radio.
Old 06-10-2019, 09:00 PM   #7
nel621
I would look for 2 component speakers. I think they would be thinner and you can hide the tweeters in the 2 corner ac vents. That is what my cousin did although he had a 242T. Then get a set of these for the rear.
Old 06-11-2019, 12:26 PM   #8
ogamer777
Loading...
ogamer777's Avatar
I mean I would like to keep it as factory looking as possible, but still have a great sounding system
Old 06-11-2019, 12:33 PM   #9
JohnLane
I fit 6X9" speakers in the rear deck with a good head unit and amp that sounded real nice decades ago. Seems like the Bertone came with raised speaker boxes back there.
Old 06-11-2019, 12:35 PM   #10
nel621
Just measure carefully. You can use a speaker just a little deeper than stock, maybe 3/4 inch. Unlike other 200 series Volvos the coupe speakers mount directly to the door frame instead of the panel. Raise your window, get a ruler and see how far back into the door you can go.
Old 06-11-2019, 12:39 PM   #11
nel621
There were very few options you could order for the Bertone. I think most had to do with the stereo system, different types of radios and of course rear speakers., usually the box type like in my photo above. Although the ones in the pic I think are of a later type. The box speakers in my coupe are different.
Old 06-11-2019, 01:04 PM   #12
283SD
I have Bertone door cards in my V8 2 door wagon. I got speakers from Retro Sound I think due to the limited depth of the door card to door chassis [ 1.5"]. I did not want to cut into the wood panel. They fit and work well.
Old 06-11-2019, 07:39 PM   #13
ogamer777
Loading...
ogamer777's Avatar
This. Thanks for the insight I'll look into retro sound. Thank you!
