Old 12-29-2010, 07:40 PM   #26
Texas240
Prius Owner
Texas240's Avatar
Stealth +t!!!!!!!!
THis is my dads plan if he was remotely rich: pull out the lovely TR3A engine w/ mosh gear box and stick in a duratech V6 W/ automatic and AC... I say corvette engine which has been done before but only on the +8 morgans.
93 245 LS Engine Swap Project
Old 12-30-2010, 02:55 AM   #27
MasterCylinder
What a lovely day!
MasterCylinder's Avatar
Location: The Fred Durst Society of the Humanities and Arts
OH btw... don't forget the S-grooves
Originally Posted by CAPT_BLOTTO View Post
Wait. T-5 to T5? You can't do that. That's like against the rules.
'90 745ti '02 WRX Wagon '81 Corolla SR5
Master Cylinder Music
MasterCylinder is offline   Reply With Quote
Old 12-30-2010, 10:11 PM   #28
Texas240
Prius Owner
Texas240's Avatar
another day of what I call progress, slow but progress. Like I said before, this wont be a fast build.
I went and picked up the block from Jon (swiftjustice44) were he put the block in a giant parts cleaner/ washing machine and stopped by the machine shop to get a price for decking and getting new valve guides put in.
When I got back home I attempted to tap the oil return and this **** happens to me
Old 12-30-2010, 10:14 PM   #29
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
back it out with a screwdriver. Nothing that cannot be recovered. then try again!
Old 12-30-2010, 10:15 PM   #30
JohnMc
JohnMc's Avatar
Are you sure it's pre-drilled to the correct size?
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 12-30-2010, 10:20 PM   #31
Texas240
Prius Owner
Texas240's Avatar
3/4" hole, even though the tap says 45/64th holes
I got it out no problem.. Ive been using this tap for a month now.
Old 12-30-2010, 10:40 PM   #32
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
It seems to me when I tapped my block, i had to drill out the hole the rest of the way.....its like where the seal rides is a good hole, but it gets to small down low.
962j 815/692@27psi
THIS IS FORSALE V
Old 12-30-2010, 10:43 PM   #33
Texas240
Prius Owner
Texas240's Avatar
I made sure this time that I drilled all the way through the blank bunk and wall. The tap started off really easy then just stopped. Any thoughts for tomorrow when I try again with a new one?
Old 12-30-2010, 10:48 PM   #34
nathaninwa
nathaninwa's Avatar
ATF and walk it in back and forth, about 1/8 turn at a time.
Old 12-30-2010, 11:14 PM   #35
Texas240
Prius Owner
Texas240's Avatar
i use wd40
Old 12-31-2010, 09:02 AM   #36
wingnutty
wingnutty's Avatar
Great Job another texas build
wingnutty is offline   Reply With Quote
Old 01-03-2011, 07:38 AM   #37
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
i use wd40
tapping the vain of WD40.. 4tehw1n
Old 01-03-2011, 02:50 PM   #38
2fast242gt
Do you have a cobalt?
its kinda hard to break a tap that big be careful bud dont reef on them. turn 1/4 to 1/2 turn and back it out keep doing that to clear the shavings so it doesnt jam up. cast iron is pretty easy to tap compared to small taps with thick aluminum.
1983 242dl
*6.0 lq4 swaped* Build thread
Old 01-03-2011, 05:40 PM   #39
Texas240
Prius Owner
Texas240's Avatar
Now I'm at the point were I need a breaker bar to man handle 1/4 of a turn. If I can get hold of a proper 12 point socket I'll use my impact gun
Old 01-03-2011, 05:57 PM   #40
sdturbo
sdturbo's Avatar
Something is wrong if you are putting that much effort into it.
Josh
92 245 (TDI diesel powered.)
84 242 (16vT beater/track slut)397whp/11.6@118mph Sold
97 Land Rover Discovery (Mercedes om606 swap)
65 Mini Cooper (B18 powered)
www.yoshifab.com Volvo performance parts.
(760)468-7002
sdturbo is offline   Reply With Quote
Old 01-03-2011, 06:21 PM   #41
DNAsEqUeNcE
†John3:16
Yes, all that is not necessary if the hole is drilled out and you are using some cutting fluid.
Old 01-03-2011, 06:24 PM   #42
towerymt
the real Towery
towerymt's Avatar
Hope you're joking, or bought a 6-pack of taps.
Old 01-03-2011, 08:42 PM   #43
Texas240
Prius Owner
Texas240's Avatar
The 6 point socket was slipping around the corners of the tap, a 12 point will hold like my wrench is doing. Just need a little more leverage and that was it.
and now She is tapped and all I need now is that squirter kit from John V whenever he finally answers my pm
Old 01-03-2011, 08:51 PM   #44
740tankDriver
Post-Hypnotic Sigma
740tankDriver's Avatar
why do you not machine the block for Volvo squirters?
Happy Passover!
Great Victory!
740tankDriver is offline   Reply With Quote
Old 01-03-2011, 08:59 PM   #45
skunked
skunked's Avatar
are you an IATSE member? Just noticed the sticker in the back window.......
Nice wagon btw
73 142E
91 940SE "Tweek" the winter beater
skunked is offline   Reply With Quote
Old 01-03-2011, 09:08 PM   #46
DNAsEqUeNcE
†John3:16
Old 01-03-2011, 09:10 PM   #47
Captain Bondo
Exklusiv Zubehör Klub
Captain Bondo's Avatar
Well... it is a tapered tap... how far you run the tap in will depend on the fitting you're using. Have you tried installing the fitting yet? If you spin the tap in too far, the threads will end up too large for the hole.
-Kenny
Old 01-03-2011, 09:52 PM   #48
Texas240
Prius Owner
Texas240's Avatar
You want to pay for it?
Nice wagon btw
Im in the Local 484 Film and Tv
Ive run the tap about half way and this is the first time ive had this issue before. But all is well now
Old 01-04-2011, 09:43 PM   #49
Texas240
Prius Owner
Texas240's Avatar
News flash Not. I found out what the problem was. When I drilled the final size out with my step bit I seemed to get it off track a little and it didnt quite follow the line so there was a slight notch sticking out now allowing the tap to continue. Took the dremel out and fixed that.
So now I wonder how the other tap broke when it wasnt even touching that notch..
Old 01-04-2011, 10:07 PM   #50
Josh
Beast force bro
Josh is offline   Reply With Quote
