Old 09-19-2018, 04:27 PM   #426
WAGONRACER
WAGONRACER's Avatar
Thought I’d add this as I couldn’t find anything on wiring up 2x standard ignition modules...
Ezk green output into terminal 5 (module 1) out of terminal 5 into coil input 3
Ezk blue output into terminal 5 (module 2) out of terminal 5 into coil input 1
Make a y lead x3 and join terminal 2,3&4 into the original ignition module wiring .
945 se b200ft
944 wentworth b200ft
944 TURBO b230ft
945 se b200ft
744 gl b23* carb
964 executive b6303
945 sports edition b230ft
744 gl b200e
S60 se b5204t5
945 2.3t b230fk
V70 awd R b5234
764 turbo intercooler b230ft
945 b230fk
945 celebration r reg b230fk
745 gl b200e
244 gl b21
945 wentworth b200ft
S80 b5244s m56
944 h reg gl b230fb
WAGONRACER is offline   Reply With Quote
Old 09-20-2018, 06:24 PM   #427
JimmyMelbs
Thanks mate.
I gather this is done in order to keep the stock ignition wiring in order to keep tacho working?
JimmyMelbs is offline   Reply With Quote
Old 09-27-2018, 01:02 PM   #428
Chumley360
I'm getting a parts list together for this add-on and was wondering if anyone had any experience with the Chrysler 4-cylinder coil in a WS conversion. I saw a few internet threads talking about using it, but not a ton. Seems similar to the Subby coil, but with a flat base. I figured the flat base will simplify a mounting bracket and it's got HEI connections, so wires shouldnt be troublesome.
Got boost? Yes! Got manual? Yes! Got gear? Yes! Got V-8 power? No
1995 940t
Chumley360 is offline   Reply With Quote
Old 10-10-2018, 08:27 AM   #429
bmos
bmos's Avatar
Does anyone have a part number/source for extra EZK connector pins?
I want to use some of the previously unused pins for my spark outputs.
bmos is offline   Reply With Quote
Old 10-11-2018, 10:49 AM   #430
bobxyz
bobxyz's Avatar
I think it's this socket pin for the Amp Junior Timer series of connectors, but I haven't actually tried one:
https://www.digikey.com/product-deta...5CT-ND/5419527
Or, you could check Dave Barton's site to see if he has these already, along with all sorts of other 240 connectors.
Old 01-17-2019, 03:18 AM   #431
Brotkasten
Jonas
Brotkasten's Avatar
I installed BTI's wasted spark kit yesterday.
I did some testing because it would not start. After resoldering the wiring I finally got spark (I tested all plugs). The car still would not start. It started once but only for a few seconds. Checked all the wiring and voltages along with continuity.
Could the starting problems be caused by too much fuel in the cylinders from prior test starts? After it died on me after running a bit I gave up for the day and reconnected the dizzy. After all I had to go to work in 4 hours.
91' 940 B230FB+T M90
Old 01-17-2019, 03:26 AM   #432
Brotkasten
Jonas
Brotkasten's Avatar
Here are some pics of the kit:
Old 01-18-2019, 03:27 AM   #433
Brotkasten
Jonas
Brotkasten's Avatar
Yesterday I got it to start and run but really weak and choppy. The spark is blue and looks strong tho. When I remove a plug from either one of the coils (Bosch 2x2) the car dies. I tested that because I was thinking it might just ran on one coil.
The tachometer does not work even with the relay in place.
Old 01-25-2019, 02:02 AM   #434
nitroboie
Switch the plug wires around, the chips output banks are more than likely swapped.
'90 244
'94 945T ipd cam, springs, sways, brace, 16T, TLAO chips, wasted spark, do88 IC
nitroboie is offline   Reply With Quote
Old 01-28-2019, 07:53 PM   #435
WinXis
Quick question, has anyone used 2 of the stock igniters? I'm doing a budget build on my 145 with a b230fk swap. And since I had 2 940 turbo igniters laying around that was the cheapest option for me.
The partnumber is 0 227 100 124. Was wondering if anyone used these and has a wiring scheme, or how I should wire it up with 2 stock igniters. I cant really find the pin-out anywhere. Or am i better of just finding a J702T or a 0 227 100 203? Or can i just stay low budget with two stock igniters and have a tach signal via them. Thanks in advance.
WinXis is offline   Reply With Quote
Old 01-28-2019, 08:00 PM   #436
JimmyMelbs
Get a 203 as you need it to be dual output I believe the stock ones are single output.
Old 01-28-2019, 08:28 PM   #437
WinXis
I know they are single output, but according to the cflmoto website you can either use the J702t, the 960 igniter or 2 stock igniters
Old 01-29-2019, 02:26 PM   #438
nitroboie
It could be done, not positive how the tach output would work.
Using the info from this diagram:
http://www.extraefi.co.uk/assets/img/bosch124.jpg
A sample wiring would be:
Ignitor 1:
Pin 1 to Pin 1 on Bosch 2x2
Pin 2 ground
Pin 4 12v
Pin 5 WS 1/4 output
Ignitor 2:
Pin 1 to Pin 3 on Bosch 2x2
Pin 2 ground
Pin 4 12v
Pin 5 WS 2/3 output
Bosch 2x2 coil
Pin 1 from pin 1 ignitor 1
Pin 2 12v power
Pin 3 from pin 1 ignitor 2
You may or may not have to swap the pin1 and 3 connections on the coil if it doesn't run. Hope this helps.
Old 01-29-2019, 05:56 PM   #439
WinXis
Ignitor 1:
Pin 2 ground
Pin 4 12v
Pin 5 WS 1/4 output
Ignitor 2:
Pin 2 ground
Pin 4 12v
Pin 5 WS 2/3 output
Bosch 2x2 coil
Pin 2 12v power
thank you!
Old 01-29-2019, 09:38 PM   #440
bobxyz
bobxyz's Avatar
I haven't installed a WS board, but I think that the original spark pin on the EZK that went to the single ignition module is still fully functional. If so, you can wire a gutted relay to this pin to generate a tach signal. If you use your dual ignition modules, the tach from either of them will be at half the rate.
Old 01-30-2019, 12:29 AM   #441
JimmyMelbs
Alright gang so I'm a visual guy. Diagrams don't cut it for me or make this easy to comprehend.
Finishing up my wiring and not sure how to hook it up.
I'm using Bosch 2x2 coils and a 203 ignition module.
Have the board and wiring to engine bay and have repinned the new connector for the new ignitor.
I've been advised to keep the old ignitor intact and connected to original heatsink and run power from the original coil which is blue wire on b230ft lh2.4.
Not sure how to take power from the coil or do the relay thing if I even need to.
Can someone help?
If you can explain how you got power and ground from your original coil and what you did with your old ignitor and coil that would be great.
I would preferably like to move or delete the old coil eventually so need to know what I need to do.
Thanks for being patient with me.
Old 02-09-2019, 08:23 AM   #442
Brotkasten
Jonas
Brotkasten's Avatar
I did some more testing today (I ordered Butchka's board and replaced BTI's - LC reasons..) and noticed:
- The car still will start and run really choppy
- Revving up just kills it
- Tacho works fine now.
I started to probe again and then I finally found something: ALL pins on the Bosch 2x2 module are shorted out - 0 Ohms (tested directly at the module). That would mean all cylinders are firing at the same time, right?
Old 02-09-2019, 05:43 PM   #443
J2_
J2_'s Avatar
/offtopic
What are 'LC' reasons?
J2_ is offline   Reply With Quote
Old 02-10-2019, 04:03 AM   #444
JimmyMelbs
LC generally means 'legit check'
Old 02-10-2019, 12:07 PM   #445
Chilm
Double Dutch
Chilm's Avatar
Default Uhm...
Why posting this here and not contacting Blabla, Martijn, BTI?
He wil help you right away that's for sure.
Double Dutch - Build and goodies thread ;P
Volvo 945 - Blue Pearl - LPT Polar 2.3 Limited Edition
B230-FK Turbo - 90+ ported - 15G Ported - Airintake
Erland Cox Regrind - Blabla Chips - 3 inch exhaust
MBC on 0.95 - Wasted Spark - Sponsored by my wife
Chilm is offline   Reply With Quote
Old 02-10-2019, 07:02 PM   #446
JimmyMelbs
So much conflicting information here
I have 6 connections on my old coil
Do I just move all these spliced together onto the 85/86 terminals of a gutted relay?
Diagrams state to leave old ignition module plugged in which I've done.
I assume I need switched 12v from the blue wire from old coil so if I splice the power into this and plug both into relay will this be correct?
If not where are you all getting switched 12v from?
Old 02-12-2019, 03:33 AM   #447
Brotkasten
Jonas
Brotkasten's Avatar
There is no way for me to contact him. The Mail on the Website is down and gives an error answer.
Old 02-12-2019, 05:22 AM   #448
JimmyMelbs
Can someone please answer my questions as there's so much conflicting info here
Where do I get switched 12v from?
The blue wire from old coil or from the 12v wire from old ignitors connector plug?
Old 02-12-2019, 03:39 PM   #449
Chilm
Double Dutch
Chilm's Avatar
tuning@bijlsmatechnicalinnovations.nl
Old 02-12-2019, 03:50 PM   #450
soclosenotnear
Pull from old igniter. That worked for me.
