Old 08-12-2012, 01:09 PM   #26
D123GT
Originally Posted by BricketyWagon View Post
L33's are animals they share so much with the ls more than the reg 5.3's.. I remember i dynoed my truck back in the day 278whp and 302rwtq and they are also very rev happy have fun.
And they love to be boosted.
1987 760 turbo sold
R.I.P 1996 960 saved three lives
sold 1967 123 GT sold
sold 1998 C1500 sold
sold 1998 S70 sold
sold 1991 740 SE Project car
1978 Trans Am Project
1997 960 sold
2002 s80
D123GT is offline   Reply With Quote
Old 08-12-2012, 04:06 PM   #27
MikeSr.
What, me worry?
MikeSr.'s Avatar
I've been talking to some local guys about these motors and they are saying 70-80 hp upgrade is super easy, and still streetable.
I coulda had a V8!
Old 08-12-2012, 06:42 PM   #28
MikeJr.
Gloss Boss
MikeJr.'s Avatar
We got the engine bay ready. The motor and trans were already out of it when we got it so that made things a little easier. Also pulled the seats, shifter, and front carpet.
Old 08-12-2012, 07:46 PM   #29
nathaninwa
The Beloved Oarnge Juice
nathaninwa's Avatar
Moving right along, at my pace I might add!
962j 815/692@27psi
THIS IS FORSALE V
Old 08-12-2012, 09:42 PM   #30
MikeSr.
What, me worry?
MikeSr.'s Avatar
Hopefully pick up the transmission this week So we can fit it and Jr. can build the mounts.
Old 08-13-2012, 08:30 PM   #31
MikeJr.
Gloss Boss
MikeJr.'s Avatar
Uh oh! LH6!
Old 08-13-2012, 10:34 PM   #32
MikeSr.
What, me worry?
MikeSr.'s Avatar
Yeah , after some research, it is definitely a LH6, which means I have to pull the heads and change the lifters and the oil pump. This is a Gen IV motor which has DOD or AFM which is to be deleted.
Ain't nothin but a thing.
Old 08-14-2012, 07:23 AM   #33
M.H. Yount
M.H. Yount's Avatar
Does that have to do with cylinder deactivation Mike? Don't know all about my Lxx engines yet....
Old 08-14-2012, 07:55 AM   #34
MikeSr.
What, me worry?
MikeSr.'s Avatar
Yep- DOD is a fuel conservation strategy that under light load cruise will use a hydraulic system to deactivate 4 intake valves while electronically shutting off fuel and ignition, turning it into a 4 cylinder.
So, my options are to get the correct harness and ECM and run it like it is, remove the lifters, valley cover and oil pump and exchange for non-DOD parts, or remove and go Megasquirt. This is problematic because I am not sure if MS can decode a 58 tooth crank trigger wheel, which is what I have. Need moar info.
Old 08-14-2012, 05:49 PM   #35
MikeSr.
What, me worry?
MikeSr.'s Avatar
So after further discussions with my LS GM guy, all I need to do is change the valley cover to an Ls 1 and delete DOD in the ECM.
Old 08-14-2012, 07:35 PM   #36
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
I think it would be a nice feature to have personally.
Old 08-14-2012, 07:55 PM   #37
D123GT
If you could figure out how to do it that would be very cool and very practical you would have a v-8 powered car that gets almost 30mpg.
Old 08-14-2012, 08:46 PM   #38
M.H. Yount
M.H. Yount's Avatar
You don't need cylinder deactivation for a V8 powered 242 to get almost 30 mpg.....mine regularly gets 27-27.5 under sustained cruise; best 1/2 tank of 29.2! Hackster's cast iron 5.3L w/T56 got 28+ on it's first extended cruise.
Old 08-14-2012, 08:59 PM   #39
MikeSr.
What, me worry?
MikeSr.'s Avatar
Well it depends on what I am able to run across in the way of harnesses and computers. I originally thought about MS, but I have a MS 2, and the most recent waves of problems with resets and noise have given me second thoughts. MS 3 looks promising for full sequential spark and ignition, but additional cost begins to exceed the cost of GM ECM.
Old 09-02-2012, 06:05 PM   #40
MikeJr.
Gloss Boss
MikeJr.'s Avatar
Well we found a T56 so it looks like that's the route we'll be going instead of a 700R4. We got the motor in today and man does this look like it's going to be a bitch. The T56 no where near fits the tunnel and the cross member will most definitely need to be cut. I'm going to copy hacksters build as close as I can as far as tunnel and crossmember mods. Of course it's always a lot harder after you've gotten a few beers in you.
Old 09-02-2012, 07:20 PM   #41
740atl
educator monkey
740atl's Avatar
lol. Beer tastes best in your garage.
Old 09-02-2012, 07:22 PM   #42
M.H. Yount
M.H. Yount's Avatar
Yup - I've about decided that when the time comes I'm going with a built T5 or a TKO -- avoid the extra weight, size and inefficiency of the T56. With all that torque, I won't need 6 gears anyhow.
Old 09-02-2012, 07:24 PM   #43
Karl Buchka
A stick should be much more fun. Definitely looking forward to seeing this come together!
Old 09-02-2012, 07:58 PM   #44
MikeSr.
What, me worry?
MikeSr.'s Avatar
A nice day's work.
Yes, that's an iron block 5.3 we picked up as a package deal with the T56.Soon to be for sale.
First try at fitment of the aluminum block 5.3
Shiny!
Now Jr. goes to work with surgery on the crossmember and tunnel and to build the mounts.Nice to be related to a craftsman.
Got a new clutch kit, with hydraulic slave cylinder. Now pedals, clutch master,lines etc.
Getting there!
Old 09-02-2012, 08:19 PM   #45
MikeSr.
What, me worry?
MikeSr.'s Avatar
Yeah, your big butt needs to be down here with us!
Old 09-03-2012, 12:38 AM   #46
hackster
Time for some chop chop on the engine crossmember.
I was able to use the stock crossmember just moved back two holes on the chassis and it all lined up nicely.
Oh and I believe that I mention in my build just how enormous this transmission is....nobody really believed me but I bet you will in a few short days.
Ill be keeping an eye on this. Looks good so far.
Sean
hackster is offline   Reply With Quote
Old 09-03-2012, 07:55 AM   #47
M.H. Yount
M.H. Yount's Avatar
Oh - he already believes you Sean....
"We got the motor in today and man does this look like it's going to be a bitch. The T56 no where near fits the tunnel and the cross member will most definitely need to be cut."
Old 09-04-2012, 01:02 PM   #48
740atl
educator monkey
740atl's Avatar
I'm so jealous. Can't wait to see how you guys shoehorn that in there... there may be a v8 in my future.
Old 09-04-2012, 02:25 PM   #49
MikeJr.
Gloss Boss
MikeJr.'s Avatar
Hell, I can't wait to see how we shoe horn that in there.
Old 09-04-2012, 02:39 PM   #50
mondo
Please post pics so we can see what kind of drama it takes to stuff those gears in there.
mondo is offline   Reply With Quote
