Old 09-07-2012, 01:32 PM   #76
2fast242gt
Do you have a cobalt?
A chevy t5 is bolt on also with a Chevy bb bell and ls7 pilot
1983 242dl
*6.0 lq4 swaped* Build thread
Old 09-07-2012, 01:57 PM   #77
MikeJr.
Gloss Boss
MikeJr.'s Avatar
Originally Posted by 2fast242gt View Post
Honestly I intend to run it with the two bolts I did it with the 16v for two years.
Yeah you might not ever have any issues at all with just the two bolts, and even if you did it would only take a small weld to correct it. No way to tell I guess until you do a little trial and error with it.
Old 09-07-2012, 02:17 PM   #78
MikeSr.
What, me worry?
MikeSr.'s Avatar
Thanks, man. I think a T5 would work stock, but any kind of power adder would crunch it.
I coulda had a V8!
Old 09-07-2012, 04:08 PM   #79
M.H. Yount
M.H. Yount's Avatar
242gt - what flywheel/clutch/pressure plate did you use to accept the T5 input shaft? I'm going with a built T5 as well. 60 lbs. lighter than the T56, much smaller physically, and about 30HP more efficient behind a 350HP V8. And let's face it - with 430HP/410 lb-ft of torque moving 2950 lbs and the ability to select gear ratios on the 5 speed, the 6th gear isn't necessary.
Old 09-09-2012, 07:24 PM   #80
MikeSr.
What, me worry?
MikeSr.'s Avatar
Some new update pics: The Moose is back!
Jr. did a lot of work today.
Motor in its final centered position.
Cut crossmember:
Surgery on the hump: T5 shifter on the T56.
looks good from this angle!
Nice!
The solenoid is the biggest clearance issue.
Centered in the tunnel.
The crossmember has to be notched more for installation than for clearance.
looks good!
This is all Jr.'s work. Many thanks, son
Updated with pics refreshed. Cat was walking on the keyboard.
Old 09-09-2012, 07:36 PM   #81
740atl
educator monkey
740atl's Avatar
Dammit! Save something for me to do!
Old 09-09-2012, 08:00 PM   #82
MikeSr.
What, me worry?
MikeSr.'s Avatar
This week we should get the starter and alternator, and a custom bracket for PS pump. The mounts and crossmember should be finished next weekend. Then we will be ready for the driveshaft. Ls-1 intake on the way, also. Lots of loose ends to finish- wiring, fuel, MS, cooling,a/c, etc.
Needs moar wideband, too.
Old 09-09-2012, 08:01 PM   #83
MikeSr.
What, me worry?
MikeSr.'s Avatar
If you are coming to SE, come down Wed and we can finish it and drive it down.
Old 09-09-2012, 08:27 PM   #84
MikeJr.
Gloss Boss
MikeJr.'s Avatar
My everything hurts
Old 09-09-2012, 09:35 PM   #85
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
I wanna get in on that drive-down. except I have to work friday, probably. so nvm.
Anything MS yet?
Old 09-10-2012, 12:36 AM   #86
2fast242gt
looks good! a few pics wont work for me though. did the pan come close top clearing? looks like extra was cut. does it sit above the crossmember? when i had my cut member i wanted to leave the bottom peice as a skid plate and tie that into the knotch when i welded it up.
Old 09-10-2012, 04:58 AM   #87
MikeSr.
What, me worry?
MikeSr.'s Avatar
Pics updated. Don't know where they went, but a certain kittah was walking on my keyboard lol.
Old 09-12-2012, 03:02 AM   #88
hakno
Nice build! I have a LT1 Volvo 264 with 4L60E but I have a T56 in the garage. Interesting to se how you managed to fit the T56 in your car. I started to fiddle with the T56 hydraulics yesterday and found out that it will be to much work to make the chevy system fit the Volvo 240/260.
Have you put any thoughts into the hydraulics? I would like to find a master cylinder with reservoir that fit the volvo bulkhead plate and is the correct size for the t56 slave.
/Hakan
hakno is offline   Reply With Quote
Old 09-12-2012, 07:12 AM   #89
M.H. Yount
M.H. Yount's Avatar
hako - hackster's daily driver is a 5.3L LS motor with a T56. He easily fabbed up a hydraulic cylinder mounted beside the brake unit, a bit of welding on the pedal assembly and it operates a hydraulic throwout bearing I believe. Pretty straightforward. Let me see if I can find the link.
Here ya go - scroll towards bottom of page 2....
http://forums.turbobricks.com/showth...=255021&page=2
Old 09-12-2012, 09:20 PM   #90
amerbritcan
Hnnnnnng
amerbritcan's Avatar
hackno your car is a lovely colour!
1990 745tic
1984 244DL (parts)
Originally Posted by My Mom
Get a bike
Poopie scissors
Old 09-12-2012, 10:04 PM   #91
doucheNozzle
doucheNozzle's Avatar
Lookin' good
'00 XC70 SE - Slow
'04 V70 T5A - Feels Fast
doucheNozzle is online now   Reply With Quote
Old 09-30-2012, 08:42 PM   #92
MikeJr.
Gloss Boss
MikeJr.'s Avatar
I made some new weld tabs for the motor mount brackets. We had bought some but I didn't think they were big enough so I made these.
I decided to use the stock gm motor mount plates to weld to for the bracket. It was thick enough, and all the holes were already there.
I got the transmission mocked up. Its where I want it, but I'm not real happy with the spacers. I will make a one piece spacer that goes across the mount. Don't mind the stack of washers. The finished product will look a lot better.
Still need to box the crossmember.
Putting the motor just were we want it. Scissor jacks are a must for doing something like this. Also notice how far the Hummer pan stick down past the crossmember. Not to bad is it? We can work with that. The pan is very close to the sway bar though. We will probably space the sway bar down a bit, or get a drop bar from ipd.
Dead centered
Cuttin like a boss
We also scored a NOS flat hood too!
Motor mount weld tabs tacked in place
Markin sh*t like a boss
Notchin by hand like a boss
Trial fit
Welding like a b... ah you get the point
Hello
Pretty much done. Don't mind the doo doo welds they are functional. The final product will look a lot better.
Old 09-30-2012, 09:13 PM   #93
MikeSr.
What, me worry?
MikeSr.'s Avatar
Jr. worked, I watched. Now we can get a driveshaft made.
Slowly but surely.
Old 09-30-2012, 10:49 PM   #94
2fast242gt
I would put a backing plate on the "frame rail" unless you trust just the 16g rails to hold it. I'd be afraid of stress cracks
Old 09-30-2012, 11:57 PM   #95
740atl
educator monkey
740atl's Avatar
Did you guys cut up my old engine stand?
Old 10-01-2012, 08:36 AM   #96
MikeJr.
Gloss Boss
MikeJr.'s Avatar
Yes, I still plan to do this. I just wanted to get the mounts made first. I'll cut the tabs back off and add some plates.
Well I had three of those harbor freight stands. I still have two more for now.
Old 10-01-2012, 08:49 AM   #97
500dollar744ti
still rides with MrDoug
500dollar744ti's Avatar
i approve of this project.
-Matt
1989 Volvo 744T- 16v turbo, '94 FD-block, RSI pistons/rods, GT35R, Tial 38mm, RFL, MSnS-E, DSM spark, 100lb Delphis, 4.6 springs, Bondo header, Heebspeed intake, Q45 90mm TB, Bosch 044 FP, 12x24x3 ebayIC, w/c t5, Clutchnet 4puck/PP, 4.10 G80, IPD sways, 960 brakes.
1998 Volvo S70 T5m- Stock, 229k
1998 Jeep Cherokee XJ- Stock, 154k
1983 Ford F150- '89 5.0 H.O, C6/4x4, F+R LSD 4.10, 7" lift, 35s.
1990 Cobia San Marino 225 ECS- MCM 350 Mag, GM Bowtie Intake, HR-Titan 19p.
500dollar744ti is offline   Reply With Quote
Old 10-01-2012, 08:52 AM   #98
740atl
educator monkey
740atl's Avatar
Got any more of those NOS flathoods?
Old 10-01-2012, 10:48 AM   #99
MikeJr.
Gloss Boss
MikeJr.'s Avatar
The one I put on your car and this one are the last two I could find.
Old 10-01-2012, 11:13 AM   #100
Iamtheonlyreal1
When you get to the Header Side of things, I have some custom Volvo LS conversion extreme block hugger headers for the P1800/Amazon, which were re-configured to fit in the compact early Volvo body work with no mods, and can be lifted in and out with jacking the motor..
Pictured are the older mock up pics, but production has started on the headers, which are being mass produced exclusively for us by Sanderson Headers.
Iamtheonlyreal1 is offline   Reply With Quote
