Old 01-10-2013, 11:36 PM   #1
thelostartof
unbalanced chemical
thelostartof's Avatar
Default 1991 744 Turbo (the Race Car)
Figured I need a thread for this so I can just have one thread to update.
More pictures to come and details as I do stuff.
So there now I have a project thread.
Old 01-10-2013, 11:37 PM   #2
thelostartof
unbalanced chemical
Others do this right? reserve space?
Old 01-10-2013, 11:37 PM   #3
thelostartof
unbalanced chemical
Oh snap double Post
Old 01-10-2013, 11:38 PM   #4
thelostartof
unbalanced chemical
looks like i did it again
Old 01-10-2013, 11:38 PM   #5
thelostartof
unbalanced chemical
must save space for spam
Old 01-10-2013, 11:38 PM   #6
thelostartof
unbalanced chemical
that should be enough space for more pictures
Old 01-10-2013, 11:38 PM   #7
thelostartof
unbalanced chemical
ah hell one more just because
Most Recent stuff I have done,
Got Dyno?
Engine Bay at time of Dyno
This is why you use thicker aluminum for base of intake and plenum wall.
Custom Trans Mount & Reinforced SubFrame so I can run slicks
7/9 Series Drive Shaft Safety Loop Install
Proper Brakes installed
My First Set of Corbeau
Old Engine Bay shot
Looking hot once again with 'track' shoes on
Fitting 265/35/18 Tires on 18x8.5 Wheels in the rear
This is why I do not run Autolite plugs anymore, 3 passes at the track and this happens. I think my manifold might favor #4 getting a bit more air.
3.5" over the axle pipe and making it full 3.5" exhaust turbo to tail
External WG and new manifold
Dead Sexy
044 Inline install, this was to assist the Walbro intank
Trans cooler with Fan
Fitting of my Newest Corbeau Seats
Ignore the red harness as that was just a test, Once the car is caged it will have a semi proper 5 point cam lock harness
My Best time at the track that lead up to me needing a 200r4
200r4 Swap
Old 01-10-2013, 11:52 PM   #8
thelostartof
unbalanced chemical
How she sits tonight waiting for me to find time to start pulling the head.
Old 01-10-2013, 11:56 PM   #9
Lord_Athlon
Chuckie Blows
Lord_Athlon's Avatar
Just swap engines and megasquirt dammit
Yet Asher here went with...
Old 01-10-2013, 11:58 PM   #10
thelostartof
unbalanced chemical
Give me the $700+ for pistons and bearings I need to rebuild my spare engine, as I have rods, just need bearings and pistons and then assemble time.
MS will be there soon enough, Once I pass emissions in May I will have two years to tear things down and redo, for now thanks to the wonderful US Gov I am some $10,000 poor'er this year so until I can find extra funds it shall wait.
Old 01-10-2013, 11:59 PM   #11
Lord_Athlon
Chuckie Blows
Just put my squirter in as a temporary
Old 01-11-2013, 12:03 AM   #12
thelostartof
unbalanced chemical
Do not tempt me as I already have one here I could do that but I fear the n/a pistons for some reason. Kenny has my thinking to not trust ring lands.
Old 01-11-2013, 12:08 AM   #13
Lord_Athlon
Chuckie Blows
Just buy mine, and rebuild yours. Ill sell it cheap. Think about it. If you bought it back, you got paid 150 to have me pull it for you ;)
Old 01-11-2013, 12:12 AM   #14
fige
KING OF TBOT
fige's Avatar
I love that logic!
Originally Posted by diponyou View Post
yeah gotta wait for jbweld to dry before I do anything today
fige is offline   Reply With Quote
Old 01-11-2013, 12:14 AM   #15
Lord_Athlon
Chuckie Blows
Originally Posted by fige View Post
I love that logic!
See, the az crew says boost that ****.
Old 01-11-2013, 01:19 AM   #16
cosbySweater
cosbySweater's Avatar
Finally! A build thread, 5 stars for how effing beat this motor is
1974 AMC Gremlin, 401 v8, 727, 8.8
1995 Porsche 993
2013 VW Passat TDI
Old 01-11-2013, 01:30 AM   #17
thelostartof
unbalanced chemical
Well I give it credit as my last compression test 2 days ago showed 60psi in #3 and 60psi in #4, #2 showed 130psi which blew me away as it has gained pressure (this is also on a semi warm motor). So beat or not but numbers are better than it used to be with the same gauge. I did not bother checking #1 as I was mainly looking for where I blew my HG.
and hey my first 5 stars, woot
Old 01-11-2013, 01:33 AM   #18
Lord_Athlon
Chuckie Blows
Just swap in mine.
Old 01-11-2013, 01:35 AM   #19
cosbySweater
I got the hookup on stock replacement hbeam rods if you wanna run stock pistons...
Old 01-11-2013, 01:39 AM   #20
thelostartof
unbalanced chemical
I have a set here out of a car but I could always use another set, Save a set for me and once I am not in the hole I might pick a set up.
Old 01-11-2013, 01:58 AM   #21
thelostartof
unbalanced chemical
There I have updated the last 2 years of 'work' I have done on my car, gives people something to see and poke at.
Old 01-11-2013, 02:22 AM   #22
cosbySweater
I ran 25psi on my n/a block for a while on pump gas, you'll be fine!
Old 01-11-2013, 02:24 AM   #23
jao
lol, about time man! looking through these pictures is awesome, post more! you know you only need to give us a time and place and we'll come and help you do anything you want man... you have waaaaay too many brownie points built up and need to cash in on some of them before they expire ;)
-jesse
1971 142e 16v/MSNS/m47/18" Kinesis K20s etc
1988 244dl 16v+T/18" HREs/ corbeus / MSNS etc
"...i often drift when i drive..." - the ghetto boys
jao is offline   Reply With Quote
Old 01-11-2013, 09:27 AM   #24
thelostartof
unbalanced chemical
There are links above most of the pics, that way people can go see more on each subject vs flooding this thread.
And yes need more stuff done here, no idea what but I need more stuff.
Old 01-11-2013, 09:32 AM   #25
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
[looks around]
no ms? no care. msorgtfofool
Megasquirt Tuning!
