Old 02-04-2013, 10:50 PM   #76
jao
glad to see it back together man!
-jesse
1971 142e 16v/MSNS/m47/18" Kinesis K20s etc
1988 244dl 16v+T/18" HREs/ corbeus / MSNS etc
"...i often drift when i drive..." - the ghetto boys
jao is offline   Reply With Quote
Old 02-04-2013, 10:58 PM   #77
kinematics
sucks that you are in need of money and have no time, I am sure at least 10 people on this board would buy a downpipe or exhaust from you
1993 Volvo 945t
kinematics is offline   Reply With Quote
Old 02-05-2013, 09:17 PM   #78
thelostartof
unbalanced chemical
thelostartof's Avatar
Got the intake bolted on along with oil return line made (no pics)
I know about the downpipes and exhausts, my plan is to get this car running and the BMW and from there I am trying to find time to build some before summer gets here as people will want to buy around then and I will want to get them done before it gets hot out here.
Old 02-05-2013, 09:22 PM   #79
BricketyWagon
Shyt id buy 1 just to fund the project, looking good.
90 744t ported 90+, ported t25, glass sunroof and stage 0
Feedback thread:
http://forums.turbobricks.com/showthread.php?t=260360
http://www.lukenos.wakeupnow.com
BricketyWagon is offline   Reply With Quote
Old 02-06-2013, 01:05 PM   #80
thelostartof
unbalanced chemical
And of course my luck the turbo doesn't fit back on. So now I have to either cut up and reweld manifold or build a new manifold, I could use another turbo but a manifold is a lot cheaper than a turbo.
Old 02-06-2013, 08:10 PM   #81
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
Why no fit?
Loosen the passenger side mount, take a ratchet strap and crank the motor over a few clicks.
Old 02-06-2013, 08:24 PM   #82
thelostartof
unbalanced chemical
Compressor housing is hitting the head, problem is this head had the exhaust side milled flat and I did not realize it until this problem happened. The Joy of to many used heads. Going to cut off turbo flange and try to angle it out and weld back on. If that doesn't work I will prob torch the car to the ground and start over. Plan was to make it run today but those plans were foiled by my arch nemesis Murphy's law. With my old setup I had 1-2mm of space on the VC.
OH well, that's my fault for running a manifold that had so little clearance to begin with on this big ass turbo.
Old 02-06-2013, 08:38 PM   #83
SwedishBee
Drill em deep
SwedishBee's Avatar
I'll take 2 full systems.
Originally Posted by CrazyChopStick View Post
I bought an 850.
SwedishBee is offline   Reply With Quote
Old 02-07-2013, 04:33 AM   #84
Roy 940
You're really not lucky...
Anyway, I'm still excited to hear this beast again!
project Blue is Better
http://forums.turbobricks.com/showthread.php?t=247082
Roy 940 is offline   Reply With Quote
Old 02-07-2013, 04:37 AM   #85
thelostartof
unbalanced chemical
Yea I will get it all figured out just frustrating at times.
Good news is I am going to make a Mild steel version of my header and put up for sale to help fund my addiction, other parts will follow as I get stuff fixed.
Old 03-02-2013, 06:45 PM   #86
thelostartof
unbalanced chemical
I will try to get some pics and maybe a video up but the car runs again. I had Jao weld on another t3 flange to the existing one after I sanded it to the needed angle so now the turbo fit. Drove the call all week with no real issues.
I still need to do the next few little mods and tweaks to make it stand out by using the s70 third brake light along with adding a 'dome' light back in. From there instill need to bend new trans cooler lines and ditch the rubber ones I have.
Old 03-07-2013, 01:27 AM   #87
thelostartof
unbalanced chemical
Originally Posted by fige View Post
Now once I get my Right rear wheel back I can drive it more, stupid pot holes.
Old 03-07-2013, 08:46 AM   #88
Roy 940
Good news! Your beast is back on the road! Congrats...and it seems to pulls nicely!
Old 03-07-2013, 09:35 AM   #89
DNAsEqUeNcE
†John3:16
can jesse or anyone you know fix pretty seriously beat aluminum wheels?
18x10.5 that will need quite a bit of surgery.
Old 03-07-2013, 10:15 AM   #90
thelostartof
unbalanced chemical
My wheel is at jesses shop right now getting fixed, so the 744 sits until someone makes the tucson-phx trip next week which is fine as I have a few things I need to fix/add/update.
18x8.5(rears) right now, once I have the funds I will have my HRE wheels rebuilt into 18x8 and 18x9. Should help the 265s look more square and hold the road better for the rear. I like the borbets that are on the car now but I really want the hire wheels.
I am hoping to get to the dyno by the end of the month along with a few more videos so we shall see.
Old 03-07-2013, 02:11 PM   #91
Lord_Athlon
Chuckie Blows
Lord_Athlon's Avatar
Brett, Jesse does amazing work.
Yet Asher here went with...
Old 03-07-2013, 02:25 PM   #92
hk 40
Lord clear your inbox
hk 40 is offline   Reply With Quote
Old 03-17-2013, 11:39 AM   #93
thelostartof
unbalanced chemical
A few updates, car has been running well, waiting on the centering rings to show up to see if the little vibration goes away.
Here is the added turbo flange that Jao weld'd up for me to fix the turbo clearance.
Yesterday I added the new trans cooler lines that I bent, works a bit better than the full length rubber hoses I had. should last a bit longer.
And way back when I put the 200r4 in I also added these frame braces but I do not remember getting pictures of them. so here, I have another set of them to install on the 944 when I ever get around to working on it
Old 03-17-2013, 11:43 AM   #94
Lord_Athlon
Chuckie Blows
Do you drive around with the tc exposed?
Old 03-17-2013, 11:48 AM   #95
thelostartof
unbalanced chemical
The front support plate is on the engine, one of these days I will order a plastic TC cover, requires me to remember to look one up online.
I guess I could do it now.
Old 03-17-2013, 01:00 PM   #96
Lord_Athlon
Chuckie Blows
Just didn't want something to hit the tonering on the flexplate and have lh die out
Old 03-23-2013, 11:05 AM   #97
thelostartof
unbalanced chemical
It feels good to be clean
For what its worth the dust shield for the 200r4 is on the way, as are the centering rings for the wheels to help with the vibration. Either way I can report that with 200+lb's of crap in the trunk along with a passenger the car still wants to spin spin spin under load. And these cars are apparently invisible to cops even with all of the noise.
Old 03-23-2013, 12:45 PM   #98
Lord_Athlon
Chuckie Blows
Nice
Old 03-23-2013, 12:59 PM   #99
Roy 940
Really nice looking car!m Those wheels are absolutely perfect on your car!
Old 03-23-2013, 08:33 PM   #100
thelostartof
unbalanced chemical
The HREs should look pimp I just have to decide what color to have the centers powder coated. I want to say matte black like these but the stock HRE silver looks good with the polished lips so it is hard to tell what to do. Plus the HREs will have 3"+ or lip in the back so that will make it super pimp.
