Old 01-06-2014, 09:43 AM   #176
thelostartof
unbalanced chemical
thelostartof's Avatar
I have not test drove it yet, it still idles like crap but that could be bad plugs or just the beat to hell motor, plus it was a cold start after a month of not running. I will check for pressure leaks today and then possibly test drive.
Old 01-06-2014, 11:18 AM   #177
Roy 940
Yes! I hope it'll run good soon, so you can share your result!
project Blue is Better
http://forums.turbobricks.com/showthread.php?t=247082
Roy 940 is offline   Reply With Quote
Old 01-06-2014, 11:23 PM   #178
thelostartof
unbalanced chemical
Well it drove around the block, made 10psi just fine, but after idling for 10-20 mins it developed a miss at idle and under load it seems to miss at the same pressure.
Going to change the plugs tomorrow and do a compression test, If it needs another HG I am so ready to call it a day with this Volvo motor stuff, V8 is really getting close to go in.
Old 01-07-2014, 12:41 AM   #179
cosbySweater
cosbySweater's Avatar
What v8 you gonna run? Ls or lt/350?
1974 AMC Gremlin, 401 v8, 727, 8.8
1995 Porsche 993
2013 VW Passat TDI
Old 01-07-2014, 01:22 AM   #180
mbolton1990
mbolton1990's Avatar
Everybody's swapping out redblocks now it seems?
mbolton1990 is offline   Reply With Quote
Old 01-07-2014, 01:36 AM   #181
55superbeetle
Don't fight it, just accept it
83 242, Turbo 6.0 LSX, E85, TH400, 8.8, 10.3@135
55superbeetle is offline   Reply With Quote
Old 01-07-2014, 01:47 AM   #182
cosbySweater
Old 01-07-2014, 03:52 AM   #183
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
If you gut it.. put me in for the intake
Old 01-07-2014, 09:40 AM   #184
thelostartof
unbalanced chemical
I would be one of the newer Gen III's, same as what my truck has. I am so ready for something a wee bit more modern, then again that engine has twice as many parts so it could be just as much effort as this. I am just wanting to drive the car and stop fixing stuff as it has been down for the last month and this is the best time of year to drive.
Last time I had an issue like this I blew the HG between 3-4, before I pulled it apart for the intake swap I did note a few breaking up issues up top so good chance I did it again, I will know for sure this afternoon when I do a compression test. The engine also has a odd squeak or tick from the top front of the engine, I am still trying to make sense if it is something in the valve train or not, Either way I do need to do a VC gasket so I could at least check clearances if the compression test checks out out.
Old 01-07-2014, 01:31 PM   #185
Roy 940
If you want to put a V8 in your car, it'll be a sad news...but I'm in to buy your V16T cam!
Old 01-07-2014, 08:19 PM   #186
thelostartof
unbalanced chemical
Well.good news is compression is 120 across all. So doing a few more tests so we shall see.
Old 01-07-2014, 11:21 PM   #187
thelostartof
unbalanced chemical
And problem fixed, #4 injector had the grey wire break, and now it has WR6DC+ plugs.
Made 25psi but hard to compare power as I blew off a few hoses under the manifold so tomorrow I will clamp them on and go for another test drive after work.
Old 01-08-2014, 02:02 AM   #188
str8krewzn
str8krewzn's Avatar
25psi sounds fun! 👍
88 740:438WHP @20psi 95b230ft,Wiseco pistons,H-beam rods 9.1cr ,Minor ported 531 head with 38/47 SS valves,Rsi Stg3 cam,Rsi Adj Cam,Rsi solid mounts, Double Valve Springs ,BW S262 turbo,Nathaninwa custom header & Nathanwa Custom Intake Manifold,3.5inch exhaust turbo back,t-5 trans with BNE Adapter plate/shifter extender,stg 5 spec unsprung clutch.
01 IS300: Stock
99 CBR600 F4:(hit by a drunk driver)
02 CBR954rr :Akra Bolt On
str8krewzn is offline   Reply With Quote
Old 01-08-2014, 03:20 AM   #189
Roy 940
Wooohoooo! That's a very good news!!!
Old 01-08-2014, 01:50 PM   #190
fige
KING OF TBOT
fige's Avatar
DTR mike.... DTR
Originally Posted by diponyou View Post
yeah gotta wait for jbweld to dry before I do anything today
fige is offline   Reply With Quote
Old 01-08-2014, 01:51 PM   #191
Lord_Athlon
Chuckie Blows
Lord_Athlon's Avatar
WAt?
Yet Asher here went with...
Old 01-08-2014, 02:07 PM   #192
fige
KING OF TBOT
fige's Avatar
Down to race bioooootch.
Old 01-08-2014, 03:57 PM   #193
thelostartof
unbalanced chemical
From a dead stop .......let me get the slicks on the back and let's see you keep up off the trans brake.... Jan 24th wild horse pass.......if I am keep it on the road.
Old 01-08-2014, 04:36 PM   #194
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
you're such a pussy.
Megasquirt Tuning!
Old 01-08-2014, 05:03 PM   #195
thelostartof
unbalanced chemical
Some of us do not have more than one turbo car to enjoy, my 90whp daily driver gets boring after while.
Plus on paper I have the trans and engine mounts already for the v8.... One of my volvos is going to get a v8 so we shall see.
Doesn't matter much as the car runs again so now I have a few weeks to get little bugs fixed and running rich on lh so I can jump ship to MS .... Need to still add that one wire for IAC power still.
Old 01-08-2014, 05:11 PM   #196
linuxman51
linuxman51's Avatar
some of us are not holding back the others from going out and procuring such vehicles, now are we? Sell Na buy T
Old 01-08-2014, 06:04 PM   #197
fige
KING OF TBOT
fige's Avatar
30mph roll. I can't launch. Doubt they'd let us at the dragstrip
Old 01-08-2014, 11:12 PM   #198
thelostartof
unbalanced chemical
But but but the wife won't let me get another car, and I am afraid to buy another car and have to fix all of the stuff I already fixed, i'm . . i'm lazy.
Old 01-09-2014, 12:18 PM   #199
Daviticus
Dibs on your MAF, injectors, and LH2.4 setup if you bitch out and go V8.
Blue 1979 245, Khaki 1988 244.
Go read performance subforum for like a month.
Daviticus is offline   Reply With Quote
Old 01-09-2014, 08:32 PM   #200
thelostartof
unbalanced chemical
Well I am for sure going MS very soon, looks like 75lb injectors on E85 are near the limit as I am pushing into the low 12's AFR wise with LH set @ 250 for the bin. So larger injectors means MS time as I have enough trouble making this thing idle so LH parts can be sold easy like.
What LH parts do you need as I have tons of spare stuff.
