Old 01-06-2019, 01:21 AM   #676
The Full Banana
not yet good enough
The Full Banana's Avatar
The front seats are back in and feel excellent.
-Tom 1980 242 T5
Old 01-06-2019, 01:30 AM   #677
Baller
Old 01-06-2019, 03:19 PM   #678
soclosenotnear
Looks awesome
check my feedback here
Old 06-06-2019, 05:39 PM   #679
The Full Banana
not yet good enough
Long story short, I was wrong about having solved the oil consumption issue (at least in part). I pulled the engine and found one melted piston (infamous cylinder #4) along with all other pistons having broken ring lands. I won't get deep into the why, but effectively, the cause is believed to be oil induced detonation over a long period of time, compounded on top of the fact that these pistons already had 240k on them.
Time to rebuild it better than before. Thanks largely to the generosity of Alex and Doug, I will be piecing together a refreshed block built with h-beams and Wiseco pistons.
Might as well repaint the engine bay while things are apart.
Disassemble
Sand
Prime
Basecoat (Volvo 477 electric silver metallic to match the exterior)
Clearcoat
I wish it was as easy as this short series of photos makes it look.
Next step: block machine work.
Old 06-06-2019, 06:26 PM   #680
Vol242vo
Keep it clean...
Vol242vo's Avatar
Sorry to hear about the engine, the replacement will be sure to bring smiles. Fresh painted bay looks fantastic, eager to do the same soon. What gun are you using?
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 06-06-2019, 06:50 PM   #681
Stiggy Pop
Stiggy Pop's Avatar
Painting is fun
'79 242
943 pickup
Old 06-06-2019, 07:28 PM   #682
Duder
Comes with a free Frogurt
Duder's Avatar
That engine bay is looking fresh! Nice job. It only took about 30 seconds as far as I'm concerned
Your new block looks super clean too; I had a sneaky peek at it. I'm sure you'll be happy with it.
Old 06-06-2019, 10:15 PM   #683
The Full Banana
not yet good enough
I bought this kit last year when I ceramic coated the exhaust manifold and turbine housing.
PowRyte 4-Piece HVLP Gravity Feed Air Spray Gun Kit https://www.amazon.com/dp/B0762M9LCK..._wDC-CbGGWPFZ3
Ended up using the detail/touch up gun for both that and spraying the engine bay this time. I don’t really know what I’m doing with these, but it worked just fine in both cases.
I can’t wait to check it out when it arrives! Looked practically new in the photos. It’s about time I get to give this GTX a workout—not long now.
Old 06-07-2019, 09:53 AM   #684
DET17
Reformed SAABaholic
Originally Posted by The Full Banana View Post
Long story short, I was wrong about having solved the oil consumption issue (at least in part). I pulled the engine and found one melted piston (infamous cylinder #4) along with all other pistons having broken ring lands.....
Will the next 5 cyl. block be the small bore type? What is your engine management system?
Old 06-07-2019, 03:10 PM   #685
The Full Banana
not yet good enough
Next block is a 81mm bore 2.3l from a 1999 T5. I'm using MS3x
Old 06-07-2019, 10:11 PM   #686
DET17
Reformed SAABaholic
I understand the 81mm is the bore of choice; I hope to follow your lead with MS3x.
Old 06-17-2019, 01:26 PM   #687
Chuck W
Chuck W's Avatar
This build is an inspiration!
'78 264GLE
'97 854 T5 (Eventually to be 5spd)
'80 264GLE (B21FT/M46/MS) - SOLD '77 242DL (B21F/M45) - SOLD '75 245DL SOLD '85 244GLT DEAD
'83 Tbird Turbo (2.3T/T5/MegaSquirt)
My feedback thread
Chuck W is offline   Reply With Quote
Old 06-17-2019, 03:00 PM   #688
The Full Banana
not yet good enough
Update!
Thanks to Alex Buchka doing all the legwork, a fresh block arrived to serve as a base for the new engine. This block came from a '99 T5 and appears to be identical to my 98 block with the exception that it has the factory-machined windows in the crankcase walls between cylinders. The block was cleaned and media blasted before Alex shipped it to me.
Some nice Wiseco pistons also arrived, huge thanks to Doug Kauer. At 81.2mm, these necessitated a slight overbore to the block.
Accordingly, the block and pistons went off to the machine shop to be matched. They ended up boring the block and resurfacing the deck.
After a shocking 2.5 days, I had them back from the shop and ready to go. At the same time, the last parts showed up so I geared up for a weekend assembly party.
The bottom end parts list includes
  • Maxspeeding chinesium h-beam rods
  • King main and rod bearings
  • Wiseco 81.2mm pistons sold by RSI back in the day
  • Total Seal rings
  • ARP 2000 rod bolts
  • new OE headbolts and reused OE bolts everywhere else
Thanks to a ton of help on Saturday, the fresh bottom end is assembled.
We continued on to get the head and pan on, and get everything timed.
I should have this sitting in the car within the next week. From there, the goal is to have it back on the road in early July.
I have a batch of fresh powdercoating being done on a bunch of things throughout the engine bay to change things up a tad. Should both look and perform like it's brand new!
The first part is done... the rest should be done in the next week:
Huge thanks to Alex (Alex Buchka), Doug (Hank Scorpio), Justus (justlie), Art (elpress) and Jay for all of their help so far. The quality and expediency of this rebuild is totally thanks to the generosity and direct efforts of those guys.
Old 06-17-2019, 06:48 PM   #689
elpress
Previous:
2000 Volvo V40
2004 Volvo S60R
2011 Subaru STI
Current:
1984 Volvo 242 DL +T
2005 Volvo S60R
elpress is offline   Reply With Quote
Old 06-17-2019, 08:08 PM   #690
Stiggy Pop
Stiggy Pop's Avatar
This is going to be great
Old 06-17-2019, 09:04 PM   #691
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Can’t wait to see it back on the road! Thanks for clearing some storage space in my garage for me
Old 06-26-2019, 10:40 AM   #692
The Full Banana
not yet good enough
Parts came back from powdercoat, so I got the engine ready to go back in the bay. If all goes well, it should be sitting back on the mounts tonight. Posting pictures because it makes me happy when things are this clean, and I know it won't stay that way .
Old 06-26-2019, 10:44 AM   #693
Stiggy Pop
Stiggy Pop's Avatar
stealthy
Old 06-26-2019, 11:38 AM   #694
Noice.
Old 06-26-2019, 12:01 PM   #695
Chuck W
Chuck W's Avatar
Damn. That's a nice-looking mill.
Old 06-26-2019, 12:15 PM   #696
+Kardboard+
Chinese guy/Swedish rides
+Kardboard+'s Avatar
NSFW
'08 XC90 V8 Big Björn|'88 245DL Uncle Sven, sold|'95 945T Darth Haul, sold|'82 242GLT B23E Lumpy the Angry Viking, sold|'77 244DL, sold|'90 744T, sold
mtd240: I suspect "the wives" have a super-secret forum to discuss whether or not they will let us buy Volvo parts.
DavidSamuels: Not a website, a panel discussion/reality show. Real Housewives of Gothenburg.
-Feedback-
+Kardboard+ is offline   Reply With Quote
Old 06-26-2019, 04:07 PM   #697
Duder
Duder's Avatar
Like I always say, a murdered out T5 is a sexy T5.
Old 06-26-2019, 10:39 PM   #698
The Full Banana
not yet good enough
Thanks all! Engine is in as of an hour ago.
Old 06-27-2019, 01:02 AM   #699
Dirk242
Nice
‘81 245
Dirk242 is offline   Reply With Quote
Old 06-27-2019, 01:07 AM   #700
NONHOG
equal opportunity car guy
NONHOG's Avatar
Man! that looks great!
