Old 02-10-2019, 09:40 PM   #176
didenpx
didenpx's Avatar
Originally Posted by matt b View Post
Man, you have got to be happy! Looks straight as an arrow.
starting to get excited; like this might be a car that I actually get to drive before I need Depends.
My feedback: http://forums.turbobricks.com/showth...hlight=didenpx
1970 1800E (Project Roedluvan:http://forums.turbobricks.com/showth...highlight=1970)
1977 242DL "Senf" (Summer Cruiser)
2x1973 1800 ES (Project Reanimator; disassembly and parts detailing to begin Winter 2020)
didenpx is offline   Reply With Quote
Old 02-11-2019, 10:46 AM   #177
matt b
Old 02-11-2019, 01:08 PM   #178
Old Iron
I Roll
Old Iron's Avatar
Looking great! It is funny how projects snow ball like you mention. Mine is going he same way!
Turbobricked
Originally Posted by Anonymous View Post
No sarcastic replies from Redwood Chair necessary
Old 03-03-2019, 06:44 PM   #179
didenpx
didenpx's Avatar
Painting has begun. Trunk and engine compartment are in color/clear:
[IMG]IMG_4704[/IMG]
[IMG]IMG_4726[/IMG]
[IMG]IMG_4714[/IMG]
[IMG]IMG_4706[/IMG]
[IMG]IMG_4716[/IMG]
Focused on detailing engine bay parts. On the fuel rail I wasn't sure whether it should be painted red or what looked like anodized; one 1970 1800E brochure shows it red, the other gold.
[IMG]Image 3-3-19 at 5.22 PM[/IMG]
[IMG]Image 3-3-19 at 5.21 PM[/IMG]
Turns out it isn't anodized, but shiny new brass....
[IMG]IMG_9065[/IMG]
[IMG]IMG_8456[/IMG]
After a soak in vinegar, brushing, and polishing with 0000 steel wool:
[IMG]IMG_1359[/IMG]
Old 03-04-2019, 08:01 PM   #180
vintagewrench
vintagewrench's Avatar
Looking good, its going to start looking great soon.
Old 03-04-2019, 08:46 PM   #181
didenpx
didenpx's Avatar
Thanks! Am now wishing that I'd been plugging away at the parts detailing; in a time crunch and all my free time is spent over buckets of Simple Green and 35% vinegar concentrate. When I want to get some fresh air I spray Rustoleum.
Old 03-05-2019, 07:41 PM   #182
didenpx
didenpx's Avatar
I'm amazed at the cleaning power of the 35% vinegar. Never used it before but I'm now sold on it; parts that looked like junk are shiny new after a good soak and some gentle brushing.
Before:
[IMG]Untitled[/IMG]
After soak, brush, spray with high temp clear and repaint of the bracket:
[IMG]Untitled[/IMG]
[IMG]Untitled[/IMG]
Old 03-05-2019, 09:36 PM   #183
2 old for this
Very impressive! I started working for a dealer when these were almost new. E f I was a total mystery. But with the help of the little cartoon book some actually got fixed. These were a very high cost to produce. Steel came from West Germany,sent to Plate Steel Stamping in England.. Is the plate still in yours? Body was built then sent back to Sweden for completion.
Old 03-06-2019, 03:54 AM   #184
mocambique-amazone
Do yourself a favour and connect the fuel system. Pump, lines including regulator (fpr) ,damper, filter and injectors. Run and flush it. Nothing won't stay the vinegar. I prefer to use high quality fuel and add two stroke oil 1/150. Get out the water and rest of the vinegar. You are able to check for leaks on the bench. Especially cold start injector and the 4 injectors. At 12v to open them. Do it outside!!!!! Fire at your workshop otherwise. There is "testfuel" available, expensive and won't burn. Bad part: this stuff tacks/glues the valves if stored too long. Prepared of leaks and fire
Good luck, very good result in cleaning. I'm impressed, Kay
Old 03-06-2019, 08:06 PM   #185
didenpx
didenpx's Avatar
Originally Posted by 2 old for this View Post
VIs the plate still in yours?
I'm no expert but I believe the body production shifted to Sweden with the 1800S models and later.
As for the FPR and the vinegar: I figured acid would be no good for the guts of it so I looped a piece of hose between the two nipples and clamped it down before the vinegar soak...
Old 03-07-2019, 02:37 PM   #186
Duder
Comes with a free Frogurt
Duder's Avatar
Bodies were still stamped by Pressed Steel in Scotland even into 1800S production. Final vehicle assembly shifted from Jensen (P1800) to Volvo (1800S). But by 1970 the body stamping may have moved home to Volvo as well, I don't remember.
This thing is looking significantly nicer than a "driver restoration." Exciting!
Old 03-07-2019, 07:51 PM   #187
didenpx
didenpx's Avatar
Thanks for clarifying Duder....and yes, thread title is misleading at this point. There's obviously been significant scope creep since this got (ever so slowly) rolling. I'm now aiming for a ~Condition 2 vehicle that can be driven in nice weather.
To that end, got the air cleaner assembly finished today with the arrival of a nice repro sticker from Deanoko on Ebay:
[IMG]Untitled[/IMG]
Have a parts order coming in tomorrow and should have the heater assembly put back together this weekend.
Old 03-10-2019, 07:52 PM   #188
didenpx
didenpx's Avatar
[IMG]1800E Ready for Body Paint[/IMG]
[IMG]Untitled[/IMG]
The only really visible progress....spent the weekend cleaning and scrubbing over vats of vinegar and Simple Green again. Nearing completion of the parts detailing.
Old 03-17-2019, 06:33 PM   #189
didenpx
didenpx's Avatar
[IMG]Untitled[/IMG]
[IMG]Untitled[/IMG]
[IMG]Untitled[/IMG]
[IMG]Untitled[/IMG]
[IMG]Untitled[/IMG]
[IMG]Untitled[/IMG]
Old 03-17-2019, 08:27 PM   #190
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
Stunning!
Old 03-17-2019, 09:03 PM   #191
The Librarian
Old 03-17-2019, 09:06 PM   #192
didenpx
didenpx's Avatar
Now I’m really pumped! Thanks for the sneak peek Eric!
Old 03-18-2019, 01:22 AM   #193
Sine Qua Non
American Psycho
Sine Qua Non's Avatar
What cam are you using?
Crush them all!
Sine Qua Non is offline   Reply With Quote
Old 03-18-2019, 12:19 PM   #194
The Librarian
It's getting a D cam because it works best with D-Jet injection.
Old 03-18-2019, 12:29 PM   #195
JohnMc
JohnMc's Avatar
The D-Jet case could certainly hold a stealth Megasquirt install.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 03-18-2019, 02:04 PM   #196
The Librarian
Old 03-18-2019, 02:15 PM   #197
planetman
planetman's Avatar
I'm pretty sure that he wants to keep the car as original as possible, hence the request for good used hose clamps in the Wanted thread.
Eric
Torrance, CA 90502
Old 03-18-2019, 02:54 PM   #198
didenpx
didenpx's Avatar
As the Norse Gods intended.
I hope they approve of the 123 dizzy...��
Old 03-18-2019, 02:56 PM   #199
didenpx
didenpx's Avatar
Originally Posted by Hank Scorpio View Post
Stunning!
Tks Doug!
Old 03-18-2019, 03:04 PM   #200
matt b
Absolutely amazing, first the paint looking perfect and then the engine looking brand new! This will have been a great restoration, I can't wait to see more progress.
