Old 06-13-2015, 08:57 PM   #51
haltechsupra
haltechsupra's Avatar
http://www.theturboforums.com/thread...part-2-to-come
Just my style.
haltechsupra is offline   Reply With Quote
Old 06-20-2015, 03:44 PM   #52
haltechsupra
A video of new knock detector. part throttle with 3 gallons of pump gas and one gallon of e 85 just to see how well it works, and to duplicate knock. https://www.facebook.com/kris.d.weld...5750079702784/
Old 06-22-2015, 06:52 AM   #53
MikeSr.
What, me worry?
MikeSr.'s Avatar
Awesome
I coulda had a V8!
Old 06-25-2015, 04:00 PM   #54
haltechsupra
Old 06-25-2015, 06:07 PM   #55
haltechsupra
https://www.facebook.com/kris.d.weld...5707245151947/.
Old 06-29-2015, 06:22 PM   #56
haltechsupra
https://www.facebook.com/kris.d.weld...5662913963695/.
Old 07-05-2015, 04:05 PM   #57
haltechsupra
https://www.facebook.com/kris.d.weld...5579770845169/.
Programming launch control..
https://www.facebook.com/cris.monsiv...2895224389535/
Old 07-06-2015, 03:29 PM   #58
haltechsupra
Old 07-27-2015, 04:34 AM   #59
haltechsupra
Vcoa meet in columbus Tx at Nils ranch
https://www.facebook.com/kris.d.weld...5624095433256/
Old 07-27-2015, 04:44 AM   #60
haltechsupra
Default carnage
Frank Yee and voodoo racing pulling out of my garage.
https://www.facebook.com/kris.d.weld...5438097903434/
Old 07-27-2015, 08:27 PM   #61
gross polluter
They see me trollin'
gross polluter's Avatar
Originally Posted by haltechsupra View Post
Extrude hone
http://extrudehoneafm.com/
So you pumped a bunch of abrasive mud through your engine?
Old 07-27-2015, 09:01 PM   #62
culberro
culberro's Avatar
Well that's one way to make sure you have piston to valve clearance.
Old 07-28-2015, 03:16 AM   #63
cosbySweater
cosbySweater's Avatar
probably would have been quicker on a lathe
1974 AMC Gremlin, 401 v8, 727, 8.8
1995 Porsche 993
2013 VW Passat TDI
Old 08-12-2015, 05:33 PM   #64
haltechsupra
LOL
Old 08-12-2015, 05:44 PM   #65
haltechsupra
Old 09-30-2015, 02:35 PM   #66
haltechsupra
Old 09-30-2015, 02:38 PM   #67
haltechsupra
Old 10-04-2015, 01:47 PM   #68
haltechsupra
Old 12-03-2015, 04:53 PM   #69
haltechsupra
Default new rods, newish motor
Back when i had corner lights.
Old 12-05-2015, 01:50 PM   #70
haltechsupra
Alcohol jet.
Old 12-08-2015, 05:23 PM   #71
haltechsupra
On up to about 20/24psi depending on temp and environment/humidity, and compression/turbo choice,tune- alcohol let my stock over used and abused, junk survive. Anything over that and pump gas just couldn't hang ,here in houston TEXAS.
I still run this kit with great results on e 85 with my fresh forged bits. I get the alcohol from walmart -93 percent(IIRC), and i freeze it when i really want to beat on the car for added insurance and added power- because i am a sneaky bastard.BTW e85 loves it as well.
Because alcohol does NOT freeze, it makes for a very cold alcohol injection that you can feel when left in the freezer. The alcohol makes things happen much quicker, much smoother, and it keeps everything in the engine pretty nice and spiffy.My customers and I love it and it's well worth the price and labor to install. But don't believe me try it yourself and prove me wrong. ;)
My Devils own kit has a progressive pump controller, two knurled knobs on the controller , one is for what boost level it starts working, the second is what boost level it sprays the maximum amount of alcohol.There is a green led to let you know when it starts spraying and it even has a tank empty indicator if you so opt to use. The kit also has a pump pressure adjustment on the pump itself with the smallest allen wrench head i have ever seen, and of course you can change jets, and adjust the knobs, so adjustability is quite infinite.The controller has a map sensor built into it that goes up to 35psi. If you haven't got this for your turbo car, no matter how much, or how little it is modded, you are missing out, I dare you to try it, you will be impressed. Guaranteed!Turbo car must. Here's my janky install.
Old 12-08-2015, 05:54 PM   #72
haltechsupra
Customers cars i have been working on meanwhile.Installed fog lights and power steering pump on this sweet 242.
Too much to list done on the supra and 850r, 78c10 is my volvo back up, red 740 is a 350 conversion, that i helped convert to 5.3 ls.
Helped these guys who were stranded, in the road, my good deed I guess.
Smoked a s60r and found a few leaks
I rebuilt and sold this 7.8 1/8th mile car
Bought this and sold it after i repaired somethings, has a 16t on it on a na block,Lh converted by Kyle, 13psi with alcohol kit of course, this car will catch you slipping. Shane and Desmond had some fun helping build this one with me.This car is a bit faster than it ever should have been.
Shorter truck oil pan fabbed up with pick up tube for 7 series.
Old 12-10-2015, 06:24 PM   #73
haltechsupra
Beginnings of up pipe from 91 stock manifold..
Old 12-10-2015, 06:29 PM   #74
haltechsupra
More customers worth sharing.
Old 12-10-2015, 07:05 PM   #75
haltechsupra
And of course this one.
