Old 07-25-2015, 05:05 PM   #51
Volvorules
Has a Built Trans!
Volvorules's Avatar
So one Buchka for removal, the other for installation?
Rob
Volvoless
how psi a stock can support?
Originally Posted by MrBill View Post
not even thieves like 7/9 series.
Volvorules is offline   Reply With Quote
Old 07-25-2015, 10:18 PM   #52
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
That's a pretty good system
Old 07-27-2015, 04:51 PM   #53
MikeJr.
Gloss Boss
MikeJr.'s Avatar
Did you guys make brackets for these seats? Are they C30 seats?
Old 07-27-2015, 05:01 PM   #54
Alex Buchka
8 cylinders
Alex Buchka's Avatar
Yeah, they're manual cloth c30 seats. The brackets are a derivative of the brackets Doug designed for his car.
Old 07-27-2015, 05:02 PM   #55
SquareD
An Anomaly
SquareD's Avatar
I wish I had a buncha Buchkas to throw at my car projects.
Old 07-27-2015, 07:34 PM   #56
Karl Buchka
Never go full retard.
Karl Buchka's Avatar
Put in a couple of solid days over the weekend and made a lot of good progress.
On Saturday we got the drive-shaft situation worked out. Using a stock Toyota yoke and an adapter u-joint mated to an M47 drive shaft, everything just bolted up. We pressed a new bearing on for the center support and started replacing the old u-joints. Might shift the center support bearing forward about 10mm to gain some slip yoke clearance as well. After that we yanked the engine out and cleaned up some accumulated mess.
Alex spent most of Sunday cleaning up the engine bay. It looks much better now. The battery area still needs more love, but right now it's about as clean as either of us feel like making it.
We went to the junkyard on Sunday morning and cut a rot-free front chassis harness out of a newer 240. I've started working on splicing that in to replace the old and busted wiring. Also got a replacement wiper motor, a round overflow bottle, and some 960 throttle cable bits. Combining a B21A throttle cable (for the correct length) with the plastic block and retainer clip from a 960 throttle cable makes everything mate up properly.
After that it was time to give the transmission some more love. This W58 has been death by a thousand cuts. Lots and lots of little piddly **** and nothing fits or works as-is. The shifter location was about 50mm too far forward, so we hacked up the rear housing and internal pivot bar to extend it. Also plugged the old mechanical speedo hole and made a 14mm banjo to -6AN adapter for the power steering.
Here's the only photo I have of that work (so far). In-situ linkage bar extendification action:
More pics to come as we finish it up.
Fake Race Car
Old 07-27-2015, 08:04 PM   #57
Tuff240
240 Ninja
Tuff240's Avatar
I'll be coming down in a couple weeks. Too bad it wasn't sooner because you guys are so close to fresh paint, I'd just bring my paint gun with me.
-Patrick
Old 07-27-2015, 08:10 PM   #58
Karl Buchka
That's an interesting offer. The boss man (Alex) will have to chime in with his opinion. He has final call on any work that drives schedule changes.
Old 07-27-2015, 08:28 PM   #59
pwschuh
Rolling...
Stop lettin' the MAN keep you down, man.
"No man would listen to you talk if he didn't know it was his turn next." E. W. Howe
Old 07-27-2015, 08:36 PM   #60
Tuff240
240 Ninja
Tuff240's Avatar
I know you had a schedule for when you wanted it done. I'd hate to be the reason it was held up.
Old 07-28-2015, 12:08 AM   #61
Hank Scorpio
I better get your project finished up.
Old 07-28-2015, 03:06 AM   #62
Tuff240
240 Ninja
Tuff240's Avatar
Danger is a brewin'
Old 07-29-2015, 07:49 PM   #63
Duder
Comes with a free Frogurt
Duder's Avatar
I snuck a sneaky peek at the cleaned up engine bay today. Looking good guys. With fresh paint it will be spectacular.
Also: what kind of POS "friend" would sell you such a rustbucket of a 242? I mean, there's some oxidation around the battery tray. You'll either need to do a frame-off restoration or save everyone the grief and just scrap the shell.
Old 07-29-2015, 07:51 PM   #64
Tuff240
240 Ninja
Tuff240's Avatar
This is where I'll throw one of the Buchka quotes back at them.
"Stupid enough to start, stubborn enough to finish!"
Old 08-05-2015, 05:40 PM   #65
Alex Buchka
8 cylinders
Short update. Here's a picture of the mocked up driveshaft, it's all rebuilt now with new u-joints and OEM center support bits:
Collected up a pile of parts that are getting dropped off at a plating shop tomorrow, going for clear zinc on everything:
Karl put some Deutsch DTM connectors on both the OE and CBR coolant temp sensors, featuring molded shrink boot action:
Also prepping for wheels V2. Picked up some wheel center forgings from a local forging shop. Pretty excited to make some chips:
Old 08-05-2015, 07:30 PM   #66
DNAsEqUeNcE
†John3:16
DNAsEqUeNcE's Avatar
How interesting
Old 08-05-2015, 08:19 PM   #67
Mark
sex lights
Mark's Avatar
My guess on the centers:
I'm surprised there's such a thing as a forging shop in North America, let alone having a local one. Is the price enough to make mere mortals shy away? Not that it really matters, I'm not gonna be turning any wheels on my Southbend 9a...
Seriously excellent work, as I've come to expect.
M.
Originally Posted by Double02 View Post
Classic TBricks - pages of discussion debating whether or not to spend $20. On a tractor.
Incorrect, the Frigidaire is Mark's 86 745. It's in appliance white and it is Best Car.
The Fridge; '86 745 DD-with full '94 LH2.4 swap. Now with M90!
2000 AMG E55 wagon.
'78 Honda GL1000- naked Goldwing.
'76 265 wagon with Megasquirted 350 chevy and T56. Scrapped
Mark is offline   Reply With Quote
Old 08-06-2015, 02:55 AM   #68
Arn02
Arn02's Avatar
Ambitious but rubbish.
The 245 GT
The Euromurican
Arn02 is offline   Reply With Quote
Old 08-06-2015, 11:11 AM   #69
SquareD
An Anomaly
SquareD's Avatar
Dibs on the 2 piece Gems.
Old 08-06-2015, 11:21 AM   #70
80/20 speed parts club
Second dibs.
Old 08-06-2015, 11:30 AM   #71
arsenix
How much does plating a box of parts like that run? I hate painting **** like that. Looks like cap after a few months usually.
88' 740 GLE Wagon - B230FT, T5 Trans, MSII-extra, G80, 3" T->T Exhaust
- - > Project Thread < - -
My new project - 1990 740 SE Wagon
arsenix is offline   Reply With Quote
Old 08-06-2015, 05:51 PM   #72
Tuff240
240 Ninja
Tuff240's Avatar
Depends on the shop you use for plating. A real high end shop will wire and dip each piece and that gets really expensive really fast because of labor.
Most places will also have a bulk or "bucket" rate and that is usually fine for most builds. They usually have minimums or $50-100. That stuff above would be under the minimum. I've done 2 engine bays worth of nuts/bolts/brackets for under $100 when they are all cleaned with a wire wheel and ready to go.
Old 08-06-2015, 06:01 PM   #73
Duder
Duder's Avatar
I managed to sneak all the underhood parts from my 242 into Alex's plating order, along with all the zinc parts from my '65 Honda motorcycle. He didn't have any issue hitting the minimum quantity :-p
Old 08-18-2015, 02:04 AM   #74
Alex Buchka
8 cylinders
Got the new thermostat housing bolted on with a new gasket.
Got my bits back from the plating shop. They did a kick-ass job, really happy with the results.
VDO Vision backlit fuel level gauge. I am installing an instrument cluster from a CBR-1000RR and it only has a fuel light so I had to add this for my own sanity.
Engine bay got some attention.
I was about to hit the bad spots in the engine bay with a spray can when Pat showed up and set me straight. He did an absolutely amazing job on the engine bay and hood. I can't thank him enough for lending his expertise to a paint and body-neanderthal like me.
Look out, he's got a gun!
Old 08-18-2015, 02:17 AM   #75
Tuff240
240 Ninja
Tuff240's Avatar
I had a fun time. Thanks for taking a pic of me when I'd been up for 24hrs.
