Old 05-01-2019, 10:02 AM   #101
Jerd
Jerd's Avatar
Brake master cylinder apears to be going out. The pedal slowly sinks at a stop with light pedal pressure. Sourcing an ABS master should be fun. Borrowing a cam shim kit from a buddy, I’m hoping incorrect valve lash is contributing to, or causing the rough idle that has plagued this car since I bought it back. The guy who had it for a while put a B cam in it. Planning building the exhaust this weekend.
Old 05-01-2019, 12:35 PM   #102
80/20 speed parts club
No 15g and t cam?
Maaaaan
Old 05-05-2019, 11:58 PM   #103
Jerd
Jerd's Avatar
Threw together an exhaust, turned out alright. Like usual, there are a few things I’d do differently if I did it again.
I also checked valve lash and discovered one valve was .002” too tight. Yah that’s a little bit of a bummer because I still don’t know why this thing idles like garbage.
Old 05-06-2019, 11:43 PM   #104
Jerd
Jerd's Avatar
I got a brake master from O’riellys. Guess I’m doing that this weekend. I have some stainless braided brake lines I have been meaning to put on. Anything else brake related you guys think I should check/do while I have the system open?
Old 05-07-2019, 06:31 AM   #105
slow240
Home Schooled
slow240's Avatar
Buy motive pressure bleeder and never look back. I just bought one after borrowing a buddies, had the 245 bled in 20 minutes, by myself. Totally worth it.
Old 05-07-2019, 08:34 PM   #106
Jerd
Jerd's Avatar
Glad you mentioned that, i asked around and a buddy is loaning me his.
Old 05-09-2019, 08:05 PM   #107
Jerd
Jerd's Avatar
Met a really nice guy named Luke got an m47, STS flywheel, pedal box, front shaft, and a clutch cable. Making a shopping list for the ipd garage sale.
Old 05-09-2019, 08:46 PM   #108
Yay Luke Jones!
What do you need? I'm at a surplus for parts...
Old 05-09-2019, 10:15 PM   #109
Jerd
Jerd's Avatar
I didn’t catch his last name. He has a 244 for sale, the body damage is a real bummer, car was super clean otherwise. https://portland.craigslist.org/clk/...882762565.html
Cool I’ll have to get my list together and send you a message.
Old 05-10-2019, 11:30 PM   #110
Jerd
Jerd's Avatar
Replaced master cylinder and installed braided brake lines. Feels so much better!
Decided to toss together a strut tower brace with some material I have had laying around for years.
Old 05-10-2019, 11:46 PM   #111
holtzboy
Honda CRV DD WTF
holtzboy's Avatar
You got to be careful with the new style clutch cables, they like to stiffen up and bend the firewall plate. Kjets on a Plane might have a used old style version for sale.
1. 86 244DL- 1st car & owned for 16 years, 25mm sways, back to stock springs w/ KYB shocks, b-cam, EZK 117K, M47 swap, 100a intake side alt, No PS/AC
2. 87 244DL - Sister-in-law's DD
3. 93 244DL - Step daughters DD
4. 84 242DL - Next project car
My feedback thread
holtzboy is offline   Reply With Quote
Old 05-11-2019, 12:49 AM   #112
Jerd
Jerd's Avatar
Good to know, I wonder why? He had an old one too that I grabbed.
Old 05-12-2019, 09:19 PM   #113
Jerd
Jerd's Avatar
Went to hop in the whip to make a beer run and the door handle broke. None of the near by junkyards had a 240 so I gave welding it a go. It worked but omg was that material nasty. Reinstalled and it’s operational, should probably pick up a spare Incase it breaks again.
Old 05-18-2019, 10:34 PM   #114
Jerd
Jerd's Avatar
Old 05-19-2019, 04:52 AM   #115
MadDog_945
Våga Vägra 8V
MadDog_945's Avatar
i am missing pipes through passenger compartment ;)
Old 05-30-2019, 10:43 PM   #116
Jerd
Jerd's Avatar
Tachometer installed.
Old 06-08-2019, 12:31 AM   #117
Jerd
Jerd's Avatar
Drilled
Broke
Dog
Welded
Third pusher
Old 06-17-2019, 03:54 PM   #118
Jerd
Jerd's Avatar
Most are wise enough to pull the springs and cycle the suspension while building an over axle exhaust. I on the other hand, like doing things twice. Pan hard rod would contact the exhaust about a half inch before bump stops. Re-did the exhaust and have plenty of clearance now.
Old 06-19-2019, 05:18 PM   #119
hackster
Nice work!! Glad to see you chomping away on this thing again. Let me know when you are ready for the long travel setup in the front. Pretty sure we can do center mounted arms off a new crossmember and make it drive well.
I also like doing things two times......it doesn't get better with age.
Sean
hackster is offline   Reply With Quote
Old 06-20-2019, 06:26 AM   #120
slow240
Home Schooled
slow240's Avatar
Sean
I've wanted to do a long travel setup in the front for a while now, but I never could figure out where the rear pivot points would go. Front pivot is easy, you could even use the stock Kmember with some modifications. But those rear bushings that you've been fighting with, I never could come up with a design for it.
Unless you went with a 7/9 style control arm with a stay rod, but even then, the pivot point has to be on the same plane as the front.
Idk, if someone figures it out it'll be you lol
Old 06-24-2019, 11:44 AM   #121
Jerd
Jerd's Avatar
Seems to me like you either keep factory control arm mounting points and shoot for 11-13" of wheel travel with a McPherson strut. Or get silly with some tubing and double A arms for 15-20" travel. Being budget limited and attempting to keep my goals realistic im leaning towards staying McPherson. I think 14-18" of rear wheel travel is attainable and more than that will become difficult without just continuing to increase ride height. I think 12ish up front and 16ish out back sounds good.
For the front, i found a long travel strut for the rear of a Subaru forester made by hotbits with 316mm of travel. JohnV made some 240 steering knuckles with a billet machined insert to adapt to a modern strut assembly, so thats not unrealistic. I need to take a lot of measurements and check for limiting factors such as ball joint, and tie rods. Control arms will need to be longer.
Im not expecting the rear to be difficult but i have not looked into what that kind of travel will do to the driveshaft/pinion angle.
Probably going to run a 215/75/15
John V bits, i could copy this idea to run a suby forester strut.
Hot Bits 316mm travel strut for the rear of a suby forester, they build to order and will custom valve. They have a single adjust and a double adjustable option. Still need to contact them and see what all the options are.
Still just spit balling at this point... Opinions?
