Old 04-18-2019, 11:09 PM   #201
matt b
Semi gloss hides dirt better.
Old 04-18-2019, 11:13 PM   #202
Jack
junkman
Jack's Avatar
What was it originally?
Old 04-18-2019, 11:38 PM   #203
Pretty sure it's silver cad plate.
http://volvo1800pictures.com/bros/64...202.%2063a.pdf
Old 04-18-2019, 11:47 PM   #204
Jack
junkman
Jack's Avatar
Oh cool! I’ll do it the same grey my valve cover is
Powder coated wheels just wash off with my pressure washer. Even the ****ty brake pad dust that came with car (super dusty) comes out with no effort
Old 04-19-2019, 11:33 AM   #205
matt b
If you're doing PC, then I agree that you're fine with whatever you prefer. This car had a PC'ed grill, since I couldn't find anyone capable of polishing the aluminum 5 years and many states ago.
IMG_8978
Old 04-20-2019, 08:59 PM   #206
Jack
junkman
Jack's Avatar
^love that color
only minor stuff today
before
after
Old 04-20-2019, 10:20 PM   #207
Vol242vo
Vol242vo's Avatar
Fun and noticeable changes like those are the best!
Derek - 1980 242
Old 04-22-2019, 12:24 AM   #208
Jack
junkman
Jack's Avatar
yeah exactly. Lots of little free stuff like that adds up adds up
Just now. I decided to replace the rear panel for Davis. I knew there was tons of bondo there but jeezz dude. The driver tail never fit well. The fuel filler surround is pushed in... lots of cracking. I got tired of looking at it... maybe I'll get to the trunk replacement also.
Need to drop the fuel tank
I'll take better pictures tomorrow
there was 1/4-1/3 inch of bondo in places
Old 04-22-2019, 03:18 PM   #209
Jack
junkman
Jack's Avatar
better idea of the poor repair
got myself a set of harborfake hammers
side - sanded it one way to show low spots
after some tappy tap tap
Old 04-22-2019, 09:06 PM   #210
Jack
junkman
Jack's Avatar
keeping the inner support panel - got spot welds out
this is on the replacement piece - Im sanding down the left over panel. I'll have to repeat the same thing on the car.
old panel out - tomorrow i'll be sanding the remaining panels and hopefully welding everything back on
Old 04-22-2019, 11:07 PM   #211
matt b
Hit the inner portion of the panel with some acid or rust treatment. Good on you for doing the work properly instead of slapping body filler in there and making a Bondo sculpture.
What are you using to drill out spot welds ? The HB tool or a regular drill bit ?
Old 04-22-2019, 11:38 PM   #212
chronicrhythm
Your body work is incredible. Looks really nice!
chronicrhythm is offline   Reply With Quote
Old 04-23-2019, 01:27 PM   #213
stick70
All the gauges
stick70's Avatar
Good on you for fixing it. I think all old body work is just get it close with the snatch hammer and slather the bondo on.
stick70 is online now   Reply With Quote
Old 04-23-2019, 04:27 PM   #214
Jack
junkman
Jack's Avatar
For sure on rust converter. Thanks I enjoy welding and I have the parts to fix it right. Got some good drill bits from Fastenall as they are 2 blocks away from home rather than ~10 Harbor Fake is
I only drilled out the spot welds on the inner panel. All others I cut close to the seam and sanded it down with 40 grit pedicure wheel
Thank you for your kind words. Keep the thread going is making me work more on the car also
Thank you
Not many wanted these even few years ago, bondo is a whole lot cheaper than actual body work
Super hot today - 88F - goodbye spring in Butte Co.
Finished grinding down the car and replacement panel. Sprayed it with rust converter. It says to wait 24h but I should be fine in a few to paint with primer. Next I need to drill holes on the bottom of the replacement piece
this gives you an idea on how Im removing the old sheet panel without drilling out the spot welds
waiting for rust to convert
Old 04-23-2019, 06:16 PM   #215
matt b
What do you call a pedicure wheel ? Looking at your tools, it looks like we're using the same things on your Amazon and my blue 1800S. I think 90% of what I cut turns itself into a 1/4 inch layer of pulverized metal and rust and lays itself all over my garage.
Old 04-23-2019, 09:07 PM   #216
Jack
junkman
Jack's Avatar
same here, stuff gets everywhere too
no used replacement panel would be normal without some sort of damage. The filler neck hole was a little off
ehh good enought
5 seconds into spraying primer - pop, I loose the nozzle
waiting on primer to dry, I went and drilled welding holes
test fit - current trunk is all dented up. I pulled one from my burned coupe because there's no dents. My other 3 all have some issues
test fitting with correct trunk (will be modifed to fit the older handle)
welded up and removed most of the paint
Old 04-23-2019, 10:19 PM   #217
2turbotoys
Salaminizer
2turbotoys's Avatar
Very cool car, glad it's in the hands of someone who can give it the love it deserves. Nice work so far!
2006 V50 T5 AWD 16 PSI +
Old 04-24-2019, 03:55 AM   #218
Sander
Good news everyone!
Sander's Avatar
Nice work on the repair!
Old 04-24-2019, 02:09 PM   #219
matt b
Sweet! Nicely done!
Old 04-24-2019, 03:01 PM   #220
Jack
junkman
Jack's Avatar
Sweet! Nicely done!
Thanks guys.
Attempted to do bondo work - second time in my life. Some places came out well while others need to be touched up. Waiting on primer to dry then body sealant this evening
Too damn hot today
Old 04-25-2019, 02:30 AM   #221
Scaramanga
Well done!
Volvo 142 1968, 145 1972, 245 GLT 1991
Scaramanga is offline   Reply With Quote
Old 04-25-2019, 10:39 PM   #222
Jack
junkman
Jack's Avatar
Originally Posted by Scaramanga View Post
Well done!
Thank you and everyone for checking in periodically, it actually motivates me to get stuff done
I had to reflow the solder on the filler neck - the neck wasn't centered in the body panel, I fixed that.
Paint came off the gas tank - kids, that's why you should use primer
quarter panels will be sanded and painted at some point.
quick sandblasting on trunk
neutralized remaing the rust and sanded with 220.
couple of pin holes, welded up now. (trunk face wasn't happy)
outside of trunk
in primer, watching paint dry
Old 04-25-2019, 11:43 PM   #223
vwbusman66
Eisen-Stein
vwbusman66's Avatar
Location: Kingsville, MD/Morgantown, WV/Your mom's house
Awesome work!
Old 04-26-2019, 01:10 AM   #224
Vol242vo
Vol242vo's Avatar
Much respect Jack.
Old 04-26-2019, 07:27 PM   #225
didenpx
didenpx's Avatar
Really enjoying watching this; such great work!
My feedback: http://forums.turbobricks.com/showth...hlight=didenpx
1970 1800E (Project Roedluvan:http://forums.turbobricks.com/showth...highlight=1970)
1977 242DL "Senf" (Summer Cruiser)
2x1973 1800 ES (Project Reanimator; coming 2019/2020)
didenpx is offline   Reply With Quote
