Old 01-08-2019, 11:28 AM   #201
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Originally Posted by Tfrasca View Post
This is inspiring. I'm so ready to get rid of LH.
Do eet, no reason not too, I will even send you my tune if you can use it as a baseline of sorts.
Originally Posted by Duder View Post
Nice progress here. Tuning is always fun once you get "stuck in" and comfortable with what's going on. Enjoy the process!
It's a rabbit hole for sure, I watched a lot of youtube videos on tuning, They are almost exclusively for Miata, so the translation is odd, but the principles apply.
1980 242 Turbo
2004 V70R
Old 01-21-2019, 10:20 AM   #202
Uncleknucklez
bruspeed
Small update, I threw a bunch more timing at the ign map, really woke the car up, also had a few pings, so I have been tuning the fuel map to match. Slowly but surely. Car fires right up every morning, and the cold starts are much better.
This weekend I installed my Kap Hybrid torque rods #bnecomfort
If you drive your 240 daily I HIGHLY recommend them. Smooooth vibes.
However, they are a touch long for guys who have shortened their trailing arms, and I wished the internal threads were deeper in the arm so we could use them with a lock washer or something to take another 1/4" out of the length. As of now I bottomed them out and shimmed up my trans to make the angles work.
I did the other side too, It's just hard to photograph because of the exhaust
Old 01-21-2019, 11:23 AM   #203
LC4CARL
Aero challenged
LC4CARL's Avatar
Your car is too clean.
Life begins at 10PSI.
Old 01-21-2019, 11:30 AM   #204
Uncleknucklez
bruspeed
Thanks Carl!
I have a couple other recent pics for the thread
View post on imgur.com
Old 01-21-2019, 01:26 PM   #205
dbarton
Dejected by Volvo
dbarton's Avatar
Originally Posted by Uncleknucklez View Post
This weekend I installed my Kap Hybrid torque rods #bnecomfort If you drive your 240 daily I HIGHLY recommend them. Smooooth vibes.
Definitely on my shopping list. I see they're offered with the Meyle bushings or the Volvo bushings for $80 more . Of course Genuine Volvo bushings would be more, but could they we worth $80 more for two? Curious is anyone is actually opting for the more expensive bushings.
Dave
Old 01-21-2019, 01:42 PM   #206
Uncleknucklez
bruspeed
Dave
I spent a ton of time going back and forth, AND trying to decide if having all of the flex and shock going into one bushing would be to it's detriment (I was working under the assumption that the stock rods having rubber on both ends splits the shock between both bushings).
I took a gamble and went with the Meyle bushings, What could be cool for this application is some poly "inserts" or something that could take up the void in the rubber, and pottentially take up some of that area and help save the bushing.
I will say that the rear of the car has tons more grip, it doesn't groan and creak driving in and out of my driveway, and generally doesn't feel like a drift car anymore. I like 'em.
oh... AND the T5 rattles are no longer being transferred through the rear end to the back seat area and has reduced that noise dramatically.
Old 01-21-2019, 02:08 PM   #207
dbarton
Dejected by Volvo
dbarton's Avatar
Without more info, I would assume the Meyle's are just fine. Maybe he's offering Volvo ones for certain picky people who are allergic to aftermarket bushings? That's my guess. I'm pretty sure he would not offer substandard bushings on such a nice product.
Old 01-21-2019, 03:01 PM   #208
Uncleknucklez
bruspeed
Agreed, I am not allergic to anything, so Meyle it is.
Old 01-21-2019, 04:53 PM   #209
JW240
All idiot, no savant
JW240's Avatar
Nice TQ-rods. Good to hear about the positive influence on comfort and grip. I like the idea of rubber bushings instead of poly. Maybe I'll do that with my (home brew) hybrid set too. The spherical bearing at the chassis side is also nice, keeps it much cleaner. Good stuff!
Old 01-21-2019, 06:04 PM   #210
gsellstr
gsellstr's Avatar
Definitely nice to hear the tune is coming along as well. I'd be curious to see what you have for a map on it at this point compared to what we've played with on Ryan's car...
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 01-21-2019, 06:23 PM   #211
Uncleknucklez
bruspeed
Take a look at where I'm at, I have done some pretty wide swings with ign timing trying to find a little det and then back it down, The car scoots pretty good with these numbers and not a hint of detonation after I reduced timing a couple degrees up top.
For the record, I did start with some pretty decent maps, and comparing them to what is floating around on here, and the link you sent with the stock ign maps I arrived at these numbers.
Specs:
B230FT
IPD Cam advanced a couple degrees as I recall
Ford Motorsports 39lb/hr Cobra injectors
16T running 17-18 PSI
3" turbo back, single muffler
Old 01-21-2019, 09:05 PM   #212
The Full Banana
not yet good enough
The Full Banana's Avatar
I... I got the Volvo bushings.
-Tom 1980 242 T5
Old 01-21-2019, 09:06 PM   #213
Stiggy Pop
Stiggy Pop's Avatar
Originally Posted by the full banana View Post
i... I got the volvo bushings. :-p
predictable
'79 242
943 pickup
Stiggy Pop is online now   Reply With Quote
Old 01-22-2019, 01:36 AM   #214
gsellstr
gsellstr's Avatar
I'd recommend dropping that timing a bit in boost or tweak your timing retard based on temp. We're on winter gas and cold temps, pretty sure you're going to get a bit of detonation at those levels on summer pump. Low load, add a little more in honestly. You saw the EZK map I've got, that seems to be running pretty well, with a little better mileage and response as well. 50kpa and up, give it another 2-3 degrees.
Looks good otherwise!
Old 01-22-2019, 04:31 AM   #215
cosbySweater
cosbySweater's Avatar
yea thats alot of timing in boost. no reason to run that much when the engine isnt efficient enough to support that amount, im willing to bet you can pull between 6-8 degrees of timing out of it and you wont loose any power
1990 Volvo 245, Efan conversion, tcam, Aw71 FOR SALE
1982 Ford Fairmont Futura. 3sge Beams, j160 6speed, full aje suspension and tubular arms everywhere
1995 Porsche 993
2013 VW Passat TDI
Old 01-22-2019, 08:49 AM   #216
Old Iron
I Roll
Old Iron's Avatar
Hey are those torque rods worth dumping my IPD ones for?
Turbobricked
Old 01-22-2019, 11:04 AM   #217
Uncleknucklez
bruspeed
I will revisit my advance table and take those suggestions into consideration. Thanks gents.
Really my goal is to make 17-18 psi and beat on it everyday, So I am ok with a little more conservative spark table.
Old 01-22-2019, 11:05 AM   #218
Uncleknucklez
bruspeed
Yes. Totally.
Old 01-22-2019, 03:56 PM   #219
gsellstr
gsellstr's Avatar
I actually found on mine, same boost level, I had better response with a little less timing as well, still ripped when you got on it, spooled up a bit faster, with a very minimal different in power on the butt dyno. Even on EZK, dropping a degree or two on the transition really picked up the spool but at that level you can feel the power difference.
Old 01-22-2019, 04:20 PM   #220
JW240
JW240's Avatar
Nice to see the MS swap too. Debating on which direction to go with aftermarket ems.
10000%
Old 01-24-2019, 10:56 AM   #221
Uncleknucklez
bruspeed
Small update, I installed a bluetooth module from evilbay in my MS box, works great, wireless connects right up to my laptop or the fire tablet that I have been running "Realdash" app on to monitor inputs.
21st century bricking.
Old 01-24-2019, 10:59 AM   #222
gsellstr
gsellstr's Avatar
I grabbed one as well a while back, never got a chance to use it. I figured I'd play with it on my older Fire as well, good to know it works! I may reconfigure mine for the MS1 box in the 140...
Old 01-24-2019, 11:05 AM   #223
SquareD
An Anomaly
SquareD's Avatar
Dang, that's pretty sweet. You're kinda making me want to ditch LH.
Old 01-24-2019, 12:02 PM   #224
Uncleknucklez
bruspeed
Here's a vid, I am a child and elected for the racecar dash, but this app has a ton of options and can control a bunch of different things if you'd like it to.
I bent a piece of aluminum and slipped it over the stock cluster. One of my issues is that you can't charge it where it is currently, so I will have to come up with a solution for that.
Old 01-24-2019, 12:26 PM   #225
Uncleknucklez
bruspeed
It's pretty cool and relatively easy to get running!
Honestly, my car may not be faster than a proper running LH car, but it is fun to mess around with, and the information available to me now is really cool!
