Old 07-02-2018, 01:05 PM   #176
hackster
Well, managed to get the driver side suspension all buttoned up and installed. This sides bearings went on much better than the driver side. I fought with the spindle on that side for hours.
Waiting on tender springs for the front to show up from Eibach and I can bolt in the upper struts for good.
I was planning on just leaving the Dana 30 in the rear, but I just cannot do it, I am too deep in this project to cut corners now.
So last Thurdsay I called around with not much luck finding an 8.8. Did a little junkyarding and found a killer junk yard here in Eugene that had several 8.8's. I lucked out and found one with 3.73's and a limited slip, 31 spline and all. They even had another one next to it that I was able to pull the short side shaft out of.
Took a few days off and visited the coast with the wife, did some hiking (hard on the busted up knee) and had a nice few day break.
Got out in the shop early yesterday and got to work. Unloaded from the truck with the cherry picker and onto jack stands.
For those of you not in the know. This axle is from a 95 to 2002 I believe Ford Explorer, its too wide in stock form but has an offset center section. You can cut down the long side of it and run 2 short side axle shafts and narrow the rearend 2-7/8". These are a disc brake 8.8 rear axle and are very, very tough, 31 spline, factory limited slips and are very well supported by the aftermarket.
Tear down of anything removable from the housing ends.
Then the fun began. Even with a plasma cutter and good grinder this was a pain.
Void of all bracketry and cleaned up for the next steps. I followed a good write up and it worked out far better than anticipated.
Marked out a centerline for alignment, then got my hose clamps out, they make for a nice straight guide line.
Marked up and ready to chop out a section. I cut the end piece off first, trusty grinder with a cut off wheel worked better than expected.
I cut 2-7/8" out and it was perfect.
Ends of the tube got faced and beveled with an 1/8" land and got to jigging everything up to get tacked together.
I used 2- 12" long pieces of 3" C channel and 2 large metal clamps and a quick clamp to hold it together while I got the screw clamps on. It worked good. Clamped this way and tacked, then removed, rotated 90 degrees, re clamped and tacked again.
Once tacked together, I put everything back together to make sure I was able to get the C clips back in and the brakes on, with the shafts.
Everything looked great, tore down, and welded.
Reassmbled everything so I can measure for tabs to go on. Scott is burning out some new tabs that might work for me, hope to have them this week.
Fuel tank should be here today, might be able to get this under the car, fuel pump installed and lines buttoned up by the end of the week.
Rear brakes are ordered, e brake cables, diff cover, fluid, gaskets. Need to figure out some rear coilovers quickly.
Sean
hackster is offline   Reply With Quote
Old 07-03-2018, 07:46 AM   #177
slow240
Home Schooled
slow240's Avatar
I did something really similar when extending the strut tubes on my old 244, 2 pieces of angle iron and some hose clamps held everything straight while I welded it up.
Looks awesome man
I'll polish your face
Old 07-03-2018, 08:44 AM   #178
Andrewhans
Turbo LS ****poster
Andrewhans's Avatar
I'm about to start the same thing for my piece of junk. I've seen a few youtube videos but I like write-ups more. You happen to have a link?
BTW your build is beautiful and I can't wait for LSA numbers. The torque should be a blast.
Current setup - Aluminum L33/Summit Turbo Stage 2, single Walbro 450 and Dual AEM 400's, Bosch 210's
3060lb no driver
3240lb with driver
Old 07-04-2018, 07:15 PM   #179
brendon_ak
Incredible! Are you going to box the front arms, or did I miss that part?
I'm just up in Salem, I'd love an excuse to come down and lend my hands!
Old 07-05-2018, 12:13 PM   #180
hackster
Looks awesome man
Thanks, It worked far better than expected. I used 3" C channel and 3 big clamps and was shocked at how well it held everything together. Ill be using it again in the future.
Thanks, the torque numbers should be really fun from down low. No idea how its going to put power down though =)
The Fabrication Series is the write up that I followed most closely. He does a killer job. Link to part one below, you can link to the rest from there. Its a very hand guide.
http://thefabricatorseries.com/build...prelude-and-qa
I didnt box them, and for a couple reasons. I have seen several 240's go off the designated path and be able to just replace the lower control arm and some steering parts and maybe a bent strut housing but have zero damage done to the structure of the car. My fear of boxing them is that if I have an off track experience that the structure of the car would be damaged by an curb incident. I think of it as a fuse.
Ill hit you up one of these days, its pretty chill at my place.
Sean
Old 07-05-2018, 12:31 PM   #181
hackster
Well I did a horrible job the last few days of taking photos....sorry for the build thread.
I received the Spectrum replacement fuel tank on Monday and got to work mounting up my new fuel system. The tank is far nicer than expected, even came painted a satin silver that will totally work with my scheme here so saved me some time and money.
Located where the new setup will go, marked the location and drilled a 3.25" hole for the new assembly to drop into. This puts the pump out of the way of the stock float for the fuel level and gives me a great location for the Holley Hydramat to lay out as well as miss the factory filler neck too.
Followed the ****ty instructions that came with the pump but it worked just fine. This is a big single pump, 450 with an internal regulator regulating the output to 60 PSI. The only fittings coming from the new pump is a supply line and a vent. The vent will be hooked to the factory filler neck opening.
The new assembly all bolted down to the tank.
I abandoned the stock fuel line connections on the tank but am utilizing it still for fuel level sender. I am waiting on caps to show up to plug them off. Should be here today, new level sender is installed as well as a new o ring and lock ring, its a clean looking setup and should be plenty for what I am doing.
Scott from STS Machine and I had been going back and forth for a few weeks on 8.8 stuff, he had some killer lazer cut brackets made for the 8.8 to 240, so while in Portland Tuesday and stopped by his place and picked them up with a 25mm front v8 sway bar. I also snagged some 3/4x3/4 heim joints, some bushings, tube and weld inserts.
I got to work yesterday, yarded out the factory Volvo rear axle and got to work locating all of the brackets and getting things tacked up. I spent a little more time than I probably should have but it all worked out.
I ditched the factory lower arms all together. It just didnt make sense, I was going to have to cut them down, buy new bushings for the front, Bens Spherical bearings for the rear and then chop off the back and plate it, then build mounts for the coilovers. It was too complicated for something so simple.
I used some Heim joints at the axle, 1.75OD bushings x3" wide and a piece of 2" .120 tubing for the front bushing at the car. a piece of 1.5" .120 DOM tubing for the lower control arm and a 1.25" weld insert for the heim. It worked awesome and I was able to just use some off the shelf 3" laser cut tabs for the lower link mounts. Now everything on the rear is more conventional.
I have rear coilovers on order, upper and lower shock tabs on order, brakes are shipped, rear ARP wheel studs are on order, I think I am making some progress.
The axle is actually under the car now at ride height, I shortened the lowers .75" and have adjustment to go longer or shorter still. Ben's comfort uppers are in place as well, they have just enough adjustment on them to make the shortened lowers work.
I am hoping that I can set this thing on its own weight next week some time with the fuel system all buttoned up and the suspension mostly buttoned up.
I am getting tired though, been busting my ass lately.
Sean
Old 07-05-2018, 12:48 PM   #182
73amc
Looks great bud! Kramerklassykustoms on IG.
73amc is offline   Reply With Quote
Old 07-09-2018, 12:39 AM   #183
hackster
This project is turning out to be bigger than anticipated. Got shocks and tabs on Friday and got to work for a little bit.
I ended up not using any of the tabs as the shock really needed to be king of low to get some reasonable travel out of them.
I am running a ride tech adjustable coilover. These are very high quality shocks and are 100% tunable. Guys like Ron Sutton can valve them however you want them to be and I want to be able to fine tune them in the future.
its a 4.1" Travel shock, ride height is set at 4.5" from rocker to ground on a 25" tall tire. I am 2.25" of uptravel at that level.
I ordered up a bad ass mosier diff cover, unfortunately it does not clear anything so looks like Ill need to just run the stamped steel diff cover, it has like .25" clearance at the tightest spot.
So built all of my brackets, got everything tacked in, pulled the entire assembly back out, and got to welding. I added gussets to the back and bottom of the shock and lower link tabs to be 100% sure that dont have any flex, pretty sure they are not going anywhere. Also this tied in the two sided of where I shortened the rear axle.
I got the stock wheel studs pressed out and the new ARP long studs pressed in, cleaned up the faces and slid them in temporarily. I am waiting for brakes to show up should be here this week. I have the new flex lines from the car to the axle made already.
Kind of running out of steam at this point Now I gotta start on the rear wheelwells to get some real tires in there, its going to be a fair bit of work.
Sean
Old 07-09-2018, 12:02 PM   #184
slow240
Home Schooled
slow240's Avatar
That is precisely how I was planning on handling my 8.8 swap. I've seen people put the coilover mounts on the lower arm, but I don't see a huge benefit.
That being said I've also seen people cut a square hole in the bottom of the fram rail so the upper mount can be recessed like 2" into the rail, improving travel. I'll see if I can find a photo.
Edit; like so
Old 07-09-2018, 06:50 PM   #185
towerymt
the real Towery
towerymt's Avatar
Maybe the photo is deceptive, but do you have room for a spring around that shock without hitting the axle tube?
4.1" travel sounds really short...but I couldn't find where Bne (blkaplan) mentioned the various travel lengths he tried on the behind-the-axle shock setup on his 245. Keeping the inside rear tire planted on the ground in hard cornering was the challenge. I thought he had gone to 5"+ travel rear shocks at some point.
Old 07-10-2018, 06:24 AM   #186
slow240
Home Schooled
slow240's Avatar
I know that car personally and it does clear, he's got quite a few miles on it now. I do know in conversation he's mentioned if he were to do it again he'd do a different design on the trailing arms side of things.
Old 07-10-2018, 09:50 AM   #187
towerymt
the real Towery
towerymt's Avatar
Oops, meant Sean's. The one you posted, there's a bit of shadow that suggests a gap. I can't tell from Sean's picture though. The side w/o the shock installed makes it look like there might be space.
Old 07-10-2018, 09:58 AM   #188
hackster
I mocked it all up with the tender spring and have plenty of clearance as well as room to move the axle back some to get it centered in the wheel well. I also double checked last night and have plenty of clearance clarence As far as the short travel that might be 100% the case and I may have to chop holes in the trunk and run longer shocks, but for now, this will have to be a starting place.
Attaching the coilover to the trailing arm as he has it is problematic, its the reason I ditched the stock trailing arms. You are relying on just the front bushing (if you have a heim or spherical bearing at the axle) to keep the arm from rotating left to right so now instead of just locating the axle you are trying to accomplish two different tasks with one part. It will try to flop the control arm to one side once you have the spring pressure on it.
We good, thanks for double checking me, never hurts.
Sean
Old 07-10-2018, 10:28 AM   #189
4.1 is very short and will lead to sketchy handling.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 07-10-2018, 11:39 AM   #190
122power
dude
122power's Avatar
All this suspension talk is more exciting than the engine. Good info.
Save the Volvo's.
Ring,ring,ring
"Hello"
"Do you work on Volvo ...
*Click - bzzzzzz*
Old 07-10-2018, 11:52 AM   #191
It's only problematic if you do it wrong,
If you are careful and keep tracking of the location of your pivots, you don't have a significant moment or movement created by the coilover forces. Its easy to get it wrong and have those problems but if the parts are designed and installed correctly, theres no reason they wont work. They also have worked fine in the past.
The only time I heard of them not working is when Bergen welded his axle wrong and the pivots were spaced 3" too wide. That **** wont work.
Also if you run any type of rear swaybar, even just a 15mm rear bar... that prevents any rocking from happening.
Old 07-10-2018, 12:49 PM   #192
hackster
What travel length do you recommend for the rear coilovers? What length were you recommending with your rear trailing arm setup?
Fun yes, super frustrating for the guy building it wrong....yes as well.
I guess clarification is needed. I did not want to add that complication to my setup and the possibility of it not working properly. I truly believed I was heading down a better path with this setup than the stock setup, I am totally second guessing my decision now.
Old 07-10-2018, 01:13 PM   #193
Hank Scorpio
Chubfest 2009 Survivor
Hank Scorpio's Avatar
I'm a little curious about this too, other than how to do the sway bar, seems like this would be the easiest way to swap in an 8.8. It's a basic 4 link after all, super common setup.
Course I'm not interested in autoX levels of handling, mostly just hooking up and modern'ish levels of handling.
Old 07-13-2018, 04:21 PM   #194
hackster
After quite a bit of critisism on my rear shocks and suspension design but very little suggestion on how to correct it, I have decided to take a break from this project. Get a clear head and figure out what I need in the rear suspension. Maybe Ill report back on my progress when I get back on it.
Hope everyone has a great Friday!
Sean
Old 07-13-2018, 04:50 PM   #195
t8fanning
8v are still cool, right?
t8fanning's Avatar
Don't get discouraged! This is one of the best builds I've ever seen.
Haven't people recommended putting the coil in front of the axle? You could do something like this guy:
http://www.volvere.fi/262C-coilover-1.htm
https://forums.tbforums.com/showthread.php?t=273365
1982 242 Turbo.
Old 07-13-2018, 05:05 PM   #196
MikeSr.
What, me worry?
MikeSr.'s Avatar
Ever thought about truckarms to replace the lowers? Like Hot Rods to Hell or NASCAR style?
I coulda had a V8!
MikeSr. is online now   Reply With Quote
Old 07-13-2018, 05:07 PM   #197
t8fanning
t8fanning's Avatar
Wouldn't that cause even more clearance issues? Seems like you'd have to cut the floor to fit the top arm above the diff.
Old 07-13-2018, 05:46 PM   #198
M.H. Yount
M.H. Yount's Avatar
I don't think there is a "top arm" with the traditional truck/long arm set up.
Coils and shocks behind the rear axle take advantage of the suspension arm "lever" - takes less spring rate and less damping force to provide the same wheel rate compared to mounting things in front of the axle.
Old 07-13-2018, 07:11 PM   #199
PeaceEngineered
Sarcastic Optimist
PeaceEngineered's Avatar
Cosbysweater added coilovers to the rear of his 244. Although I would have done it a bit different, he did use the stock arm and modified. He has beat the hell out of the car too.
Page 1 of his build thread...
http://forums.turbobricks.com/showthread.php?t=334045
2013 Audi Q5
Sold- 2006 V70R
PeaceEngineered is offline   Reply With Quote
Old 07-13-2018, 07:33 PM   #200
Sgt Savage
Hackster,
Is there a reason you didn't go with the ZL1 lid? Clearance I'm guessing but it would be cool to know one way or the other.
Sgt Savage is offline   Reply With Quote
