Old 08-12-2018, 09:42 AM   #51
Atom D&D
Atom D&D's Avatar
Originally Posted by PAULDRIVER View Post
I must have missed another build id not seen ?
Can someone post a link to it ?
https://forums.tbforums.com/showthread.php?t=333984
Atom D&D is offline   Reply With Quote
Old 08-12-2018, 09:47 AM   #52
Atom D&D
Atom D&D's Avatar
https://jalopnik.com/true-hero-swapp...bmw-1826320988
Old 08-12-2018, 10:25 AM   #53
PAULDRIVER
Just been for a look, nice build,
I like your idea on the fuel filler neck, i have the same problem where to put mine, as same as yours it is opposite
Im jealous of your solid body, we need to do loads of bodywork yet, as uk climate is not friendly on classic cars
Some pics of my amazon on the floor for the first time, its very easy to push around now
WHALE OIL BEEF HOOKED
(use Irish accent)
PAULDRIVER is offline   Reply With Quote
Old 08-15-2018, 03:17 PM   #54
Atom D&D
Atom D&D's Avatar
Mine was rusted up pretty good too. The rail and floor going down under the car under the right side was cracked and separated. I just fixed my rust a few years back before I started all these shenanigans.
Old 08-17-2018, 08:28 AM   #55
PAULDRIVER
Mine was definitely beyond repair as a standard volvo, all main seams were swelled and just dropped to bits in your hands, ive saved it from certain death
Some pics of us lining the doors up, the bmw rear suspension arm mounts, are in our way
You can see it in our way !
Front door fitted and lined up, so no movement in body, braces worked, as expected
We were stumped on a way to sort our small problem of, not been able to close the rear door, due to the bmw rear arm mount,
So after a bit of brain storming, i remembered some slammed vw buses on air ride, and after tubbing out their front arches, they modified the inside of the door so it closed ?
So thats exactly what we did
Blue line is where we are at
PERFECTO !
We ll make a piece to fit back in and modify its door panel.
Door now closes
Its off for a sand blast on rear end to remove rusty crud and bondo/ filler
Will put some pics, up watch this space....
Old 08-17-2018, 11:01 PM   #56
Jack
junkman
Jack's Avatar
I like looking at your pictures but its a pain in the ass since they're huge, please make them slightly smaller
Old 08-18-2018, 12:32 PM   #57
PAULDRIVER
Will look into it, they re on photobucket.
Old 09-05-2018, 08:35 AM   #58
PAULDRIVER
Some more pics of our project...
Old 09-05-2018, 12:57 PM   #59
PAULDRIVER
Rear end after a quick sand blast, not pretty
Can you see all the screws to keep the arch in place
Next we made a start on the bulkhead, some of the bmw was removed to neaten it up.
Old 09-06-2018, 12:06 PM   #60
PAULDRIVER
Some pics of the amazon joined to the bmw in the engine bay.
Inside.
First few braces are now cut off
Front end will be done soon, rear end looks like, not a lot of fun
More pics soon.........
Old 09-06-2018, 01:40 PM   #61
Atom D&D
Atom D&D's Avatar
Progress is progress. Good job
Old 09-06-2018, 05:29 PM   #62
LC4CARL
Aero challenged
LC4CARL's Avatar
Wow. You get more done in a week than I do in a year. Looks like fun.
Life begins at 10PSI.
Old 09-07-2018, 11:41 AM   #63
PAULDRIVER
It is yes, and thanks for the positive comments, it drives us on
Old 09-07-2018, 12:10 PM   #64
PAULDRIVER
Thanks a lot, we try to crack on so keeps us positive, A small obstacle is round the corner and will slow us down, it is the rear corners, i need my friend to make me some repair panels for said area, you cant buy repair panels for what i need as it s literally dissolved away on the seams, will post pics of it, as and when,
For today a little more on the bulkhead was done, we warmed it up and shaped it just as we wanted it, more than happy with the results so far, once painted you would never even know what we ve been up to ?
Section of Amazon rear floor, we will use it later and incorporate it to keep it original
More to come soon...
Old 10-04-2018, 11:01 AM   #65
PAULDRIVER
Been busy last few weeks, but a bit more s been done on the amazon.
Rear end now well under construction,
We made some of our own repair panels as they dont exist
Panel behind rear bumper was bad, so we made one
This is for left side and bends round to meet panel under rear reflector, which was made as well.
Other side is same, (turd)
We will do the other side, exactly the same process
Old 10-08-2018, 11:44 AM   #66
PAULDRIVER
Some more pics of rear end under construction
AFTER
BEFORE
Old 10-08-2018, 05:52 PM   #67
nel621
Nice work on custom made panels. Looking good.
Old 10-09-2018, 11:41 AM   #68
PAULDRIVER
Thanks, we feel like we are making some progress, now we can see what we re up against,
Panels weren t to bad to make, we needed to fold a side, and use a shrinker to form it, so it followed same curve as rear wing.
More pics soon
watch this space........
Old 10-09-2018, 11:59 AM   #69
poulrais
poulrais's Avatar
Geez! This is awesome work!
Are you retired from work to have the time to tackle a project like this one?
Now you're going to need this:
1990, Volvo 740 16v +T
Old 10-09-2018, 12:46 PM   #70
PAULDRIVER
Im using an inline six from a 1996 volvo 960 24v
https://pl.m.wikipedia.org/wiki/Plik...-07-24)_02.jpg
whats that from ?
Old 10-09-2018, 01:12 PM   #71
poulrais
poulrais's Avatar
whats that from ?
1999 Volvo S80. B6284t. Cause is has these thicker 81mm walled bores. This one got its deck closed and shimed by DeeWorks so it'll take some boost without complaining.
Old 10-09-2018, 02:32 PM   #72
PAULDRIVER
Looks nice
Old 10-09-2018, 03:26 PM   #73
poulrais
poulrais's Avatar
How are you going to build your 960 engine to withstand 800 HP and stay somehow reliable? What 960 engine number do you have at hand? A B6304? These engines are not the best choice for a high output turbo T6 build imo...
Old 10-10-2018, 05:25 AM   #74
PAULDRIVER
Motor will be built very soon, it is just been mated to an M3 EVO six speed manual, and we can start to build it,
New rods, pistons, cams, valve guides, head work, crank work, big turbo, big injectors, usual stuff,
Im looking to hopefully twin turbo it, and use a smaller turbo to make it spin up quicker and reduce lag,
Same as a 2004 to 09 bmw 535d
Old 10-10-2018, 07:13 AM   #75
poulrais
poulrais's Avatar
Ok. By new rods I hope you meant forged H beam rods and forged pistons? Are you having anything done to the block itself?
