Old 10-10-2018, 07:44 AM   #76
DanMarino
Amazing work. I can't do any of that stuff. Keep it going!
DanMarino is offline   Reply With Quote
Old 10-10-2018, 08:11 AM   #77
PAULDRIVER
Originally Posted by poulrais View Post
Ok. By new rods I hope you meant forged H beam rods and forged pistons? Are you having anything done to the block itself?
Sorry i meant forged H beam rods and forged pistons obviously,
The block itself i may need to fit some bore liners ?
But id not even looked into any of it as A. loads of bodywork to do, B. motor is been mated up to our bmw evo trans,
Will let you know as i go.
WHALE OIL BEEF HOOKED
(use Irish accent)
PAULDRIVER is offline   Reply With Quote
Old 10-10-2018, 08:15 AM   #78
PAULDRIVER
Will do, and thanks for the positive comments,
Watch this space...........
Old 10-10-2018, 08:20 AM   #79
PAULDRIVER
It will be like this motor
http://www.speedhunters.com/2015/01/...-24v-turbo-11/
Old 10-10-2018, 09:10 AM   #80
poulrais
poulrais's Avatar
Originally Posted by PAULDRIVER View Post
Yeah I've seen that one. But the article does not specify which T6 engine was used from the 960 as a 2.5L version was available in Europe.
You will really have to address the bore thickness issue if you have a 2.9L motor at hand and have high boost figures in mind.
But looking at the metal work you've so far I'm sure you will do your homework right!
Can't wait to see the updates on that build!
1990, Volvo 740 16v +T
Old 10-10-2018, 01:01 PM   #81
PAULDRIVER
It is a 2.9 used,
A few pics, rear corner almost done.
Underside
More to come soon.........
Old 10-20-2018, 04:50 AM   #82
PAULDRIVER
Update.....
Left rear now under way
Sill now looks nice
Same as opposite side,we needed to address bmw rear arm mount,as door wont close
Opposite sill
Door mod so it will close
Mod successful !
Door closed and all lined up !
Next week we will join amazon rear to bmw inner, as our body was so turd we d loads of bodywork to do before we could actually join em.
Seemed like we were doin not a lot, but we can see a bit clearer now.
Old 10-21-2018, 12:27 AM   #83
NONHOG
equal opportunity car guy
NONHOG's Avatar
Looking good, thanks for the thread!
Old 10-21-2018, 06:47 AM   #84
PAULDRIVER
No probs, some more pics for you....
Some more will be done very soon
Old 11-07-2018, 01:09 PM   #85
PAULDRIVER
Update..........
We started to join our rear inner arches to the bmw chassis.
From inside.
Boot floor saved from earlier, we want to use it, so it looks like its from sweden still.
Nice fit, perfecto.
All cut away now
We are about to construct our spare wheel well, so will put some pics up ASAP
Rear end is now a lot more sturdy, you can see the bars to keep it all lined up are now removed .
Old 11-09-2018, 06:00 AM   #86
PAULDRIVER
We cut all boot floor out, as we decided it would be easier, and look better if we made our own
We folded some steel, to use for our floor support
X2
All cut back to near rear diff
We folded some more steel, we will use it later...
More to come, today we are about to bead roll some steel sections of our boot well,
We plan for it to look as cool as we can
Old 11-14-2018, 01:18 PM   #87
PAULDRIVER
update.......
We made our spare wheel well, and are pleased with the results
Opposite side
Cut out and ready
VW T3 motor lid, we will use it in a minute
Mocked up, ready to bead roll
Bead rolled
VW T3 motor lid, cut for our spare wheel floor
Number 2x bead rolled
3rd panel bead rolled, all blasted and zinc primed ready to fit
Old 11-14-2018, 01:31 PM   #88
PAULDRIVER
Some more of our project.....
Before we blasted them, you can we ve marked for it to be rolled
Trial fit before official install and bead roll
Sides and rear piece all welded in, our well base AKA...VW T3 motor lid is just sat in and screwed, we need to square it up properly and we can proceed to weld er up.
More to come soon
Old 11-16-2018, 12:25 AM   #89
Harry Tuttle
Incredibly awesome what you are doing. How many would have even saved that car as stock?
Originally Posted by dl242gt
It's always better to get into a turbo volvo and drive.
Old 11-18-2018, 01:59 PM   #90
PAULDRIVER
Thanks for your positive comments
I know, it was a turd, next stop was definitely a scrap yard,
But ive saved it, and it will be more awesome than ever.
I look forward to when all this bodywork is done,
We should be able to fit the motor soon
Old 02-24-2019, 07:52 AM   #91
PAULDRIVER
We ve been busy on other projects, so not done a lot recently,
But now our new panels have arrived, we re back on with it.
Also our motor is back, a clutch and conversion plate was made to take our 6 speed e36 M3 EVO transmission
Transmission we will use, m3 evo
Back corner is almost restored, it looks really nice !
Will put some more pics up soon
Old 02-24-2019, 02:00 PM   #92
Duder
His Dudeness, El Duderino
Duder's Avatar
The rear of this thing turned out to look pretty incredible. Kudos on solid ideas and execution! Pretty brilliant to use the Volvo load floor and VW engine lid in the way that you did.
Old 02-25-2019, 12:22 PM   #93
Vol242vo
Vol242vo's Avatar
Nice to see an update on this one, looking really good!
Derek - 1980 242
Old 02-25-2019, 12:52 PM   #94
stick70
All the gauges
stick70's Avatar
Hows the fit of those new front panels? Typical reproduction fit issues or worse? I'm considering getting a new nose for my car since mine is so bent, but I'm always skeptical of aftermarket panels.
Old 02-26-2019, 05:44 AM   #95
PAULDRIVER
Panels fit perfect as in, they are genuine OEM VOLVO panels
We ve been sat since September, waiting for Volvo to send their presses back from Poland to Sweden, and re start production,
Its totally delayed our amazon project, so now we need to act fast
Now we can line our front end up and proceed with our project,
Amazing you can order new panels, as mine were terrible and to find replacements is near impossible, you can order fibreglass ones, but to me dont look right
Old 02-27-2019, 02:35 PM   #96
PAULDRIVER
Some more pictures.....
Box for front panel
Left rear corner almost completed
Old 02-27-2019, 03:45 PM   #97
stick70
All the gauges
stick70's Avatar
Well that is very good to hear, thanks!
Old 03-12-2019, 09:46 AM   #98
PAULDRIVER
We removed our support bars now its welded up,
You can see up front we left some in, we d not done completed the bulkhead/firewall, and those support our hinges for our hood, so will be removed once we know all is ok
Old 03-20-2019, 06:20 AM   #99
PAULDRIVER
More pictures...
We made our battery box lid
Back on to our front end now for a bit
Inner panels and cross member to finish
All braces now removed, and we trial fitted our strut brace to see if our hood will close ok, and it does
Inner panels more or less done
We decided to fit our motor
Its just sat in place on a piece of wood.
You can see old mount and where it needs to be
Opposite side, volvo mount is removed
Opposite side
Old 03-21-2019, 02:39 PM   #100
PAULDRIVER
A few more pictures.
We made our motor mounts.
Looks almost perfect
Opposite side, we needed to keep clear of our UJ so we can still steer.
Next job is to complete firewall.
More soon...
