Old 02-07-2019, 11:43 PM   #151
BR1CKHOUS3
I like the tuna here
BR1CKHOUS3's Avatar
Nice score! Reminded me to dig for some of your wanted parts too
We don't do it for the glory.
Only two ways to find out...18 bolts or 18psi
BR1CKHOUS3 is offline   Reply With Quote
Old 02-09-2019, 10:32 PM   #152
2turbotoys
Salaminizer
2turbotoys's Avatar
Thanks, let me know if ya find any. I pm'd ya a while ago, did ya get it?
Chopped and painted 740 T from my old car lives on..
Ya I got the Stack gauges...never seen that many wire on a gauge before haha, will be adding a matching coolant temp gauge.
Holes to put gauges into, need those I guess, the pillar will be AFR and boost
Some NOS fender emblems, these jumped out at me because there is no engine size on the bottom, which is odd. Needs a 5.3 there!
1978 242, getting prepped for LS
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
2turbotoys is online now   Reply With Quote
Old 02-09-2019, 10:35 PM   #153
M.H. Yount
M.H. Yount's Avatar
It's do-able.
Old 02-09-2019, 10:36 PM   #154
2turbotoys
Salaminizer
2turbotoys's Avatar
Nice! is that paint or vinyl? Font?
Old 02-09-2019, 10:45 PM   #155
M.H. Yount
M.H. Yount's Avatar
Vinyl - Dave Barton did 'em for me. I think he attempts to come close to the original font. Your 2's and mine/his look pretty similar.
Old 02-09-2019, 10:48 PM   #156
2turbotoys
Salaminizer
2turbotoys's Avatar
Dave is the man, he nailed on your emblems I think. I'll hit him up. Thanks!
Old 02-09-2019, 10:52 PM   #157
M.H. Yount
M.H. Yount's Avatar
Shouldn't be a problem. I cleaned the emblem up, painted it, detailed the 'dental molding' at the top - and then stuck on his decals.
Old 02-09-2019, 10:58 PM   #158
2turbotoys
Salaminizer
2turbotoys's Avatar
Perfect, thanks for the tip. These are NOS emblems with a touch of shelf wear so shouldn't need much.
Old 02-09-2019, 11:29 PM   #159
Old Iron
I Roll
Old Iron's Avatar
Is that a legit three pod or a repro?
Turbobricked
Old 02-10-2019, 09:40 PM   #160
2turbotoys
Salaminizer
2turbotoys's Avatar
It's an Autometer, fraction of the cost, not as cool, but I just am having trouble justifying the cost of the repop, and original is inunobtainium and even harder to justify the cost. I can see it if you are doing a real restoration, but this is just a "resto-mod" car. I will have to make a nice plate to mount it to. Dave Barton made a very nice one off repop of the rally gauge, and I will probably mount it in a similar way to his, but black anodized aluminum base and maybe a textured wrap over the pod.
Old 03-05-2019, 09:24 PM   #161
2turbotoys
Salaminizer
2turbotoys's Avatar
Hmmm, that doesn't fit very well... Trying to get a rough idea of where things end up with a 17x10" rim, so I borrowed a damaged wheel from a friends BMW race car, Hoosier 275/35-17. It is touching the studs of a 32mm spacer. Lowering the car down, it can go inboard about 1".
Also trying to determine how wide I want the rear to be, as well as the backspacing of the wheels I have to order so I can lose the spacers.
Old 03-06-2019, 11:33 AM   #162
RvolvoR
for a 10" wheel to fit up front, you need a wheel with around a -5mm offset.
Old 03-06-2019, 12:33 PM   #163
Yep, thats correct. Also 10" wheel et0 in the back seems to be a good amount if you have a coilover conversion and skinnier trailing arms.
8.5 width is really the max you can do without committing to major body work. unless you really stretch a skinny tire on.
Driving a 240 with 10" wide wheels is an awesome experience but sometimes unless you are racing the car, i wonder if its worth it.
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 03-06-2019, 01:03 PM   #164
RvolvoR
yep, plus the added scrub radius on the street can make for some...interesting...handling characteristics
Old 03-06-2019, 09:00 PM   #165
2turbotoys
Salaminizer
2turbotoys's Avatar
I will have your adjustable arms and JRZPro coilovers, ordered them and just waiting for them . I'm pretty sure it doesn't need 10" wide wheels on the front, was going to go 9". It just seems you need a 10" in the rear to have enough rubber on the road.
My current rear rims are about ET6 and are really really close on the inside of the wheelwell with 8" wide rims and a 245/40-17 tire...also if I remember correctly the 9" rear is going to have a wider track than the stock one by a few inches, I gotta look that up again.
I hope the handling doesn't get "interesting" in a bad way..
Old 03-07-2019, 11:50 AM   #166
a 17x9 can run a 255 40 17. Those are a really nice size tire. Much less intrusive amount of work then a 17 x 10 and something like a 295.
Old 03-07-2019, 09:59 PM   #167
2turbotoys
Salaminizer
2turbotoys's Avatar
Hmm, I'll look at that. I just want to be able to launch really hard...
Old 03-07-2019, 11:35 PM   #168
M.H. Yount
M.H. Yount's Avatar
What kind of et’s and mph are you anticipating? Andrew W. ran 9.99 @ 141 with a 1.6’ 60’ on 235 street radials.
Old 03-08-2019, 10:26 PM   #169
2turbotoys
Salaminizer
2turbotoys's Avatar
Unless I start planning a cage I only have 1 shot at a good drag run haha, my local track is Maple Grove Raceway and will boot you in a second for running faster than your gear. I have to find out what they require, the NHRA rulebook is a little different than track rules, and I am not sure if I can just get away with a rollbar or not. That being said I have no real goals as far as et goes, I would love to hit the 10's though, I don't know if that's realistic with the mere 450 NA hp the car is starting off with.
I do know what a 1.6 60ft feels like, doing that on the track vs from a stoplight does require a bit more traction though.
Old 03-11-2019, 08:29 PM   #170
2turbotoys
Salaminizer
2turbotoys's Avatar
Got my steering wheel from Mota Lita today, check out the nice metal horn button emblem!
Old 03-11-2019, 11:43 PM   #171
cosbySweater
cosbySweater's Avatar
Run half track passes and dial in 1/8th mile. Then give it the beans
1974 AMC Gremlin, 401 v8, 727, 8.8
1995 Porsche 993
2013 VW Passat TDI
Old 03-12-2019, 08:11 PM   #172
2turbotoys
Salaminizer
2turbotoys's Avatar
Haha, good idea
Old 03-22-2019, 11:08 PM   #173
2turbotoys
Salaminizer
2turbotoys's Avatar
New Mota Lita steering wheel installed...
And failed at installing wagon springs, I read a ton of threads about this and decided 1.5 coils cut off was a good way to go, but didn't consider those guys were using a more stockish wheel/tire combo. I figured I gotta add my mistakes to my build thread...I ordered IPD lowering springs hoping they are tall enough. Oops, shoulda left them alone and had the rear jacked up a bit temporarily.
The reason I'm doing any of this at all is because the factory springs are so worn that my tires bang into my fenders over bigger bumps. I am waiting for my rear coilover/suspension parts to arrive but need to do something to have the car driveable. Its obviously not at the moment...
Shop manager B had to add a bloop to this
Old 03-31-2019, 09:49 PM   #174
2turbotoys
Salaminizer
2turbotoys's Avatar
The IPD lowering springs helped a bit, stiffer, but it is only about 1/4" higher. They sell 1/2" spacers to raise it up a but, but don't give a p/n, so I sent an email. They replied to me several times trying to diagnose why my cars wheels are so far back in the wells, and why I am scraping, I appreciate they are so helpful but I already know the answers to all that (which I explained fully), I just want the dam spacers so I don't ram my tires into the arches for the next couple months till I get my rear coilover parts. I still have not got a part number or invoice for the parts I want.
On my test drive today, for some reason the car decided it need to shimmy hard under braking, it sat for 2 months, and was fine before that. I did nothing to the front suspension or brakes in that time. So gotta dig into that wtf
How it sits now:
Old 04-11-2019, 08:44 PM   #175
2turbotoys
Salaminizer
2turbotoys's Avatar
Some small progress updates, brake shimmy fixed itself after a bunch of miles, my engine is now at the shop and I will be swapping out the bolt on stuff (oil pan, headers, etc.) this week as I am currently in between jobs. Amazing how much you can get done if you don't go to work...
Since I'm sure no one remembers (this project is taking forever...) I bought a use factory gas tank to replace mine because the tabs that hold the sending unit in place are too beat up to keep the sending unit in place. I stripped the undercoating off using a heat gun, an expired Subway gift card, and acetone for the little bit of residue left. If anyone else does this I would suggest MEK instead of acetone, it doesn't evaporate immediately leaving smears all over.
I then took it to my local radiator repair shop because they have those big ass dip tanks to clean stuff in. They cleaned and coated the inside, and I picked it up this afternoon.
During the undercoat removal. Ya I know there is weird stuff in the background, previous homeowners did some hippy paintings on my garage door.
An entire spraycan of Krylon Automotive self etching primer applied
An entire can of Rustoleum satin black enamel applied to the top, will repeat that tomorrow on the bottom half
Coated tank guts. I forget what it is exactly, but it is reparable if something happens to it.
