Old 10-25-2018, 09:23 PM   #26
LS_swapped
Well things are about to get serious
LS_swapped is offline   Reply With Quote
Old 10-26-2018, 08:55 AM   #27
Unqualified
Going to be using this as a guide for when I get a wagon and ls swap! Good luck with it, seems well thought out.
Unqualified is offline   Reply With Quote
Old 10-26-2018, 01:54 PM   #28
LS_swapped
thanks, there are alot of good build threads on this forum!
Old 11-13-2018, 03:06 PM   #29
LS_swapped
rear suspension done for now... just need to get a sway bar and adjustable uppers. Haven't done that yet just because the uppers are brand new on the car. Maybe i can get the motor and trans in this week!
Old 12-17-2018, 01:07 PM   #30
LS_swapped
Finally a little progress... clutch is here. Fuel fittings are on and just need to run lines up to the filter. Holidays are slowing progress up... after Christmas that will change.
Old 12-18-2018, 10:25 PM   #31
RustoGusto
Subscribed!
RustoGusto is offline   Reply With Quote
Old 12-19-2018, 09:47 AM   #32
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Originally Posted by LS_swapped View Post
Can you supply a part number for those fittings?
1980 242 Turbo
2004 V70R
Old 12-19-2018, 10:18 AM   #33
LS_swapped
Earls AT165056ERL - 5/16 to -6an
Old 12-19-2018, 11:05 AM   #34
Uncleknucklez
bruspeed
Great thanks! Turns out those were already on my Summit wish list
Old 12-19-2018, 02:30 PM   #35
LS_swapped
hahaha nice!
Old 12-19-2018, 02:34 PM   #36
LS_swapped
Not much, but its progress... got my throttle cable mount in and a few other things yesterday. Motor and trans going in this evening after work!
Old 12-20-2018, 10:14 AM   #37
LS_swapped
got a little done yesterday
and a cool shot of my buddies truck and the car, yep snapchat saw it first
Old 12-27-2018, 10:44 AM   #38
LS_swapped
little more progress... hoping to get the fuel lines on and wiring routed this weekend. Ready to hear this thing run again
Old 12-27-2018, 11:12 AM   #39
Texas240
Prius Owner
Texas240's Avatar
whats your clearance between manifold and steering column?
93 245 LS Engine Swap Project
Old 12-27-2018, 06:57 PM   #40
LS_swapped
maybe a **** hair between it, you can see where it was touching before on the old shaft...but its still really close with the new one. i figured it would have way more clearance. i do need to move my motor back a little bit. if i remember right there there will be a little bit more clearance if i do.
Old 12-27-2018, 07:02 PM   #41
M.H. Yount
M.H. Yount's Avatar
If you haven't done it yet -- loosen up the fasteners holding the column and you can shift the column a bit towards the driver's side - that should free you up a bit of clearance as well.
Old 12-27-2018, 08:19 PM   #42
Texas240
Prius Owner
Texas240's Avatar
Wont be much. Does your squeak now when turning at slow speeds?
Old 12-27-2018, 10:12 PM   #43
M.H. Yount
M.H. Yount's Avatar
Mine moved a lot more than I was led to believe based on others' experience. No squeaky.
Old 12-27-2018, 11:15 PM   #44
Texas240
Prius Owner
Texas240's Avatar
everything you do I have the opposite. This is some bullsh_t dude
Old 12-27-2018, 11:55 PM   #45
LS_swapped
Yeah I'm hoping I wont have to mess with the column
Old 12-28-2018, 02:05 AM   #46
M.H. Yount
M.H. Yount's Avatar
As I recall - 2 fasteners where column passes through and smack it with my hand; took all of 45 seconds and shifted the column maybe 1/4” away from the manifold.
edit - clarify - 1/4" gained where the column comes through the firewall; less than that out at the manifold, but most of us will take what we can get.
tx240 - LOL; maybe someone had already moved yours in that direction before you tried. Can only tell you what happened on mine. Apparently one size does not fit all. I used different manifolds than shown here so my clearance issues were entirely different/different solution. I also offset the motor 1/2" towards the passenger side.
Old 12-28-2018, 08:20 PM   #47
Texas240
Prius Owner
Texas240's Avatar
There you go.
Old 12-28-2018, 10:16 PM   #48
M.H. Yount
M.H. Yount's Avatar
Originally Posted by Texas240 View Post
There you go.
Ours is apples/oranges anyway because of manifold choice alone; engine height likely also different, that affects clearance as well.
Old 12-29-2018, 03:35 PM   #49
LS_swapped
throttle cable on and fuel lines are done as of yesterday... going to try and get the harness on the car and the clutch hooked up. Getting close
Old 12-31-2018, 10:21 AM   #50
LS_swapped
little more progress this weekend...
clutch hooked up
wiring harness ran through the fire wall
