Old 02-21-2019, 10:16 AM   #51
LS_swapped
got car loaded up and to the muffler shop... turned out pretty good!
LS_swapped is offline   Reply With Quote
Old 02-21-2019, 12:30 PM   #52
Vol242vo
Keep it clean...
Vol242vo's Avatar
Looks good!
Derek
1980 242
-Project Thread-
Follow on IG: @vol242vo
Old 02-22-2019, 10:09 AM   #53
LS_swapped
Thanks man, been a while since i updated. but the car does run. Needs a tune bad...
ordered shifter and some stuff to hopefully get this thing driving.
Old 03-05-2019, 02:29 PM   #54
LS_swapped
few updates
mgw shifter came in
radiator mounted... moved it forward a good bit. I like how it turned out...
getting closer, should have a tune next week and some hoses for radiator. ready to hear it idle and run
Old 03-05-2019, 03:29 PM   #55
M.H. Yount
M.H. Yount's Avatar
I moved the horns down below the front bumper - even more free flow across the rad.
Old 03-23-2019, 02:03 PM   #56
LS_swapped
Flashed the tune and got the drive shaft in, got to drive it off the trailer. It moves on its own power now
got the tach working, temp gauge working, and also got this beer tap ordered so i can make it my shift knob. haha something different
Still got to fix brakes, master cylinder is shot and booster is full of fluid. So got to get all that ordered and hope it will be on the road soon working all the bugs out and fine tuning it
Old 06-04-2019, 09:33 AM   #57
LS_swapped
well guess i can update this a little... car is currently apart again. Sold the motor, trans, harness, and all. decided the ls1 and 6 speed was quick enough. new stuff currently consist of...
6.0/4l80
80mm billet VS turbo
Holley terminator x max wiring.
Will get some pics soon. Anyone know a decent place to upload pics other than photobucket?
Old 06-04-2019, 10:20 AM   #58
Vol242vo
Keep it clean...
Vol242vo's Avatar
I use PostImage.org super easy to use and creates links for you...
https://postimg.cc/files
Old 06-04-2019, 01:07 PM   #59
LS_swapped
awesome, thanks. Ill get some new photo up loaded here after while
Old 06-04-2019, 01:27 PM   #60
LS_swapped
ls1 just wasnt enough... So i sold it and the t56
New motor and trans from 2006 chevy 2500
holley knock off pan from poormanmotorsports 224 bucks shipped, comes with gaskets, bolts, and everything. i even like that u can use 2 bolts on the oil pump with this!
few goodies going on the car this go around... vs racing 80mm billet turbo... plus started gathering parts for the hot side. 2.25" to 3.5" y for the merge
also got griffins 8.8 swap mounts
last i went ahead and bought the holley terminator x max kit! very very nice stuff.
Old 06-05-2019, 06:15 AM   #61
DrHutch
Definitely upgrading! Can't wait to see it finished. Do you have anymore info on those 8.8 mounts?
DrHutch is offline   Reply With Quote
Old 06-05-2019, 06:52 AM   #62
M.H. Yount
M.H. Yount's Avatar
Hutch - https://www.stsmachininginc.com/prod...x-motor-mounts
Old 06-05-2019, 10:25 AM   #63
LS_swapped
Yes sir, they are from griffin's performance shop. Check him out on facebook. Hes got alot of nice parts. Ill be getting his 4l80e crossmemeber soon so i can get this motor and trans in
Originally Posted by M.H. Yount View Post
think hes talking about the rear end mounts not motor mounts lol
