Old 04-12-2019, 07:44 AM   #1
Hutch.
Hutch.'s Avatar
Default Sudden Power Loss After Long Drive
So, I drive my 87 244 +T between Savannah and Atlanta weekly. It runs fantastic until around 2 hours into the drive. At this point it will sporadically go very lean, lose power, then recover, and run fine for a while. Then it happens again. It seems to occur mostly when hitting traffic after a long stent at 80+ ~ 3000RPM. After driving slow for a while the problems cease. This has been an issue for over a year and before the +T.
Over the last several months I have changed the following for one reason or another. Frankly, I donít know whatís left to look at.
LH2.2 Chrysler swapped to EZK
Both fuel pumps and filter
3 Bar FPR
Injectors
TPS
IAC
Coil, wires, cap, rotor, and plugs
Thoughts?
The Mighty Herc:
17,200shp
78,400in/lbs
Will fly for parts.
Hutch. is offline   Reply With Quote
Old 04-12-2019, 09:46 AM   #2
iHateVolvoPeople
Powerstage overheating? How’s the wiring the the tank pump? Mine would die when warm due to crappy wiring.
Feedback Thread
Current:
'93 244T M47
'95 Camry A140E, 254k
'99 Camry A140E, 256k
Old 04-12-2019, 10:27 AM   #3
NotSoFresh
Sick ****** T-Brick Prick
NotSoFresh's Avatar
Is the evap system plugged? As the fuel level drops if no air can get in, the tank can go under vacuum, making it harder for the pump to pump out fuel, and thus a lean condition. I suppose the extra load on the pump could cause it or its wiring to overheat as well. Open the gas cap next time it happens, If you hear a woosh of air, that may be part of the problem.
Fuel tanks can collapse or split if the vent/evap system doesn't work correctly.
Old 04-12-2019, 12:14 PM   #4
Mr. V
Mr. V's Avatar
The link given below might give you some ideas as to how to approach the problem:
https://www.volvoclub.org.uk/faq/Ele...lIgnition.html
Old 04-12-2019, 04:20 PM   #5
Hutch.
Hutch.'s Avatar
Thanks fellas. I’ll check the wiring in the tank but, it seemed ok when I replaced the pump. I don’t think it’s the power stage because it was happening before I went to EZK.
I hadn’t thought about the tank venting correctly. I’ll check that out too. Doesn’t seem to be related to fuel quantity though.
Old 04-17-2019, 08:34 AM   #6
dbarton
Dejected by Volvo
dbarton's Avatar
Originally Posted by Hutch. View Post
Thanks fellas. Iíll check the wiring in the tank but, it seemed ok when I replaced the pump. I donít think itís the power stage because it was happening before I went to EZK.
I hadnít thought about the tank venting correctly. Iíll check that out too. Doesnít seem to be related to fuel quantity though.
If it was failing spark I think it would go rich, not lean. If that's correct, then it's an issue with fuel delivery.
Since it only happens during driving after a long period it's hard to duplicate in your garage, but you might try hooking up test lights to your fuel pump circuits so you can see them when driving. Then you can verify that power to the pumps isn't becoming intermittent when the problem occurs.
Dave
'84 242ti, owned since 2003. Always garaged since brand new. Old-school rounds because. B21FT, SDS EFI/IGN, TD04HL-15G, T5Z trans with 0.73 OD, 3.91 diff with unmodified G80.
Volvo Seeks Divorce from Volvo Enthusiast Community: www.prancingmoose.com/#novolvo
Alternator Idler Pulley Project: https://forums.turbobricks.com/showthread.php?t=350085
dbarton is online now   Reply With Quote
Old 05-12-2019, 08:19 PM   #7
Hutch.
Hutch.'s Avatar
I’m going to try the test lights tomorrow. Last couple weeks I’ve been making the drive at night so it wasn’t an issue. Now however, it seems to be happening even when the car is cold.
Old 05-16-2019, 07:59 AM   #8
dbarton
Dejected by Volvo
dbarton's Avatar
Curious. What air/fuel gauge are you using?
If it's by chance an Innovate, I've had several of them fail, causing random rich/lean spikes during cruise. If by chance your LH was using an O2 feed from the controller, it could be affecting LH.
Dave
Old 05-16-2019, 08:35 PM   #9
Hutch.
Hutch.'s Avatar
I’m using an AEM gauge with the wideband but still using the factory O2 sensor for engine ops. The wideband is independent, just for SA.
Haven’t had a chance to look at the fuel pumps yet. Hopefully I can get on it this weekend.
Old 05-17-2019, 08:05 AM   #10
dbarton
Dejected by Volvo
dbarton's Avatar
Good. The AEM is replacing the Innovate in my car.
Old 05-17-2019, 09:23 AM   #11
240240
Poobacca wil survive 2020
240240's Avatar
I had this issue before.
I was getting vapor lock. Gas was pressurizing and fuel pump was overheating. I swapped the gas cap then put a new ipd intank pump in.
One of the fuel pumps could be worn out, or seals when they get warm
Have you checked fuel pressure when car is acting up? I think you're on the right track to it being fuel related
Originally Posted by bobxyz View Post
I'm sure glad that our mods are protecting us from excess poop in these trying times of TP shortages....
Shoot the poop!
Originally Posted by centason View Post
I WANT TO BE HIRED BY 240240!!!
"e-gay"
Old 05-17-2019, 04:51 PM   #12
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
Could be a fuel relay getting warm and doing weird stuffs?
1980 242 Turbo
2004 V70R
Old 05-18-2019, 11:23 PM   #13
Hutch.
Hutch.'s Avatar
Well, I checked the fuel pressure and it seems to be fine... of course that’s when the car is also running fine. It was acting up bad for a few days, way more unpredictable and spastic than fuel issues could be. I started looking back through the ignition system and the hall Sensor was clearly shot, swapped out the distributor and it’s running great. I attack the gauntlet to Savannah again on Monday. Hate to wish for bumper to bumper in 90 degree heat but, it’s the only way to see if the hall sensor was the fix. I’m pretty certain they are unrelated issues.
I’m tempted to run a fuel line through the firewall to monitor the pressure for the drive.
Old 05-23-2019, 07:02 PM   #14
Hutch.
Hutch.'s Avatar
I was correct. Still stalling after long drives in the heat.
Think I’m going to check all the wiring this weekend and maybe wire the pumps direct to a switch to see if that does anything.
Old 05-23-2019, 08:05 PM   #15
lummert
lummert's Avatar
Use an electric oil pressure sender and gauge inside the car connected to the fuel rail. It will be much safer than running a fuel line inside the car. Still suspecting vapor lock due to in-tank pump issues. Does running a full tank of fuel make an improvement? Things start getting bad at about 5 gallons less than a full tank?
Old 05-23-2019, 10:25 PM   #16
NotSoFresh
NotSoFresh's Avatar
Does your gas tank make a sucking noise when you open the cap? Outside chance its the cause but a plugged evap system can cause the tank to go into vacuum as it empties and make the fuel pumps work harder. This could cause low fuel pressure, especially if the pumps are a little weak already.
Old 05-24-2019, 07:53 AM   #17
Hutch.
Hutch.'s Avatar
Good call on the oil pressure setup, I’ll do that this afternoon.
It doesn’t seem to matter how much gas is in the tank. Outside air temperature seems to be the only variable that matters. If it’s cool out on early morning commutes, no problem. Even with a nearly empty tank. That said, could be the pumps are working overtime already and the heat is just the final straw.
Old 06-04-2019, 03:25 PM   #18
Hutch.
Hutch.'s Avatar
Think I may have solved the problem. The fuel pressure was dropping significantly when it started stalling out. I decided to check the in tank pump wiring and work my way forward from there. Turns out the in tank hose had a small crack. I’m thinking it wasn’t big enough to make much difference when cool but, as it heated up the problem was exaggerated. Driving back to Savannah tomorrow, fingers crossed.
