Old 05-26-2019, 08:17 PM   #1
durk80
durk80's Avatar
Default air conditioner not quite conditioning
First, let me apologize for sounding even more neurotic than Woody Allen... The a/c in my 1990 240 is not blowing cold enough. About 2 years ago, I flushed the condenser and evaporator. I replaced both high and low side hoses, except for the one that goes from the condenser to the receiver dryer. The receiver dryer, expansion valve and 4-Seasons compressor were also replaced. I added an electric fan to the front of the condenser that is triggered to come on when the a/c is on. Of course, everything that I couldn't find a replacement for was sprayed with brake cleaner and shot out with an air compressor until it was clear. The entire system was put back together and put on vacuum until I could be sure there were no leaks (several hours). 3 cans of 134a were put into the system if I remember correctly.
The ambient temp today was 92 degrees. The chart says that the low side pressure should be 50-55 psi. My low pressure was 40 and High was 350--which seems rather high.
The air from the vent with a/c on max was 65 degrees. Not sure if there was a leak or not, I added more r134a to try and get the psi near 50 on the low side.
Is there anything I should look at that might give this reading, or should I just leave it and be happy that at least it is cooler than ambient temp?
I used this chart: http://rechargeac.com/how-to/ac-system-pressure-chart
Thanks as always, for your guidance.
durk80 is offline   Reply With Quote
Old 05-26-2019, 09:58 PM   #2
stevecole33
Just charged my '90 245. The best temp I could get at the vents, with recirc on, was about 50 fahrenheit. And the car would then start to overheat at stop lights.
How many ounces were the cans you used?
The sticker on mine called for 2.9 lbs of R12. General rule for replacing with R134 is 80%, so 2.3 lbs is what I filled it to. I have no high side fitting so can't compare that. I saw low side between 35-50 psi. This was just last week, ambient temps above 80.
stevecole33 is offline   Reply With Quote
Old 05-26-2019, 10:23 PM   #3
iHateVolvoPeople
That’s probably just your compensator board saying it’s overheating. But they added pusher fans in 1991 I think..
OP, Idle temps are hard to get low on the undersized weak Volvo systems. 93+ is pretty decent. You might have a faulty heater control valve letting heater core heat taint the system.
Feedback Thread
Current:
'93 244T M47
'95 Camry A140E, 254k
'99 Camry A140E, 256k
Old 05-27-2019, 12:03 AM   #4
durk80
durk80's Avatar
Thank you for the advice! I will check that out. Do you know if the cable be adjusted to completely close the valve, or must it be replaced because of internal wear? How do these things become faulty?
stevecole33
Thank you Steve, it's good to know that this is somewhat normal...For your overheating problem, have you tried putting an Infrared thermometer near the top of the thermostat housing? If you don't have access to one, I suppose you could 'very carefully' stick a conventional thermometer by the top hose inlet to get an idea of the temp when the gauge is in the normal position, and if it changes significantly when the a/c is on.
How is the fan clutch at low speed--can it easily be stopped with some rolled up newspaper? https://troubleshootmyvehicle.com/gm...g-case-study-3 This guy also has some troubleshooting for fan clutches if you care to check it out. Good luck and hopefully it will be an easy fix for you!
Old 05-27-2019, 02:48 AM   #5
Turboschnauzer
Turboschnauzer's Avatar
High side PSI seems a bit high to have good operation of the A/C system. Several things can cause this, too much refrigerant, poor air flow across the condenser, contaminated refrigerant or a faulty compressor. A quick test that will help sort this out requires running cool water from a garden hose across the condenser while the A/C is on. If the high side PSI drops and vent temperatures improve, air flow across the condenser is causing your problem.
Turboschnauzer is offline   Reply With Quote
Old 05-27-2019, 09:24 AM   #6
stevecole33
Thanks for the suggestions. I've already bypassed the temp faker and haven't had time to put a temp gun on the engine. At some point soon it will probably get an electric fan.
Good luck with your heater controls. Hope you don't need to get too deep in the dash.
Old 05-30-2019, 07:17 PM   #7
dbarton
Dejected by Volvo
dbarton's Avatar
[QUOTE=durk80;5955859]Thank you for the advice! I will check that out. Do you know if the cable be adjusted to completely close the valve, or must it be replaced because of internal wear? How do these things become faulty?
/QUOTE]
They can leak inside past the closed valve and you'll never know, except you'll get heat competing with the ac trying to cool things. To rule this out, simply get something to pinch closed the top heater hose on the firewall under the hood. Hose pinch pliers or vise grips. If vent temps get cooler, you found a leaking heater valve.
Dave B
'84 242ti, owned since 2003. Always garaged since brand new. Old-school rounds because. B21FT, SDS EFI/IGN, TD04HL-15G, T5Z trans with 0.73 OD, 3.91 diff with unmodified G80.
Volvo Seeks Divorce from Volvo Enthusiast Community: www.prancingmoose.com/#novolvo
Alternator Idler Pulley Project: https://forums.turbobricks.com/showthread.php?t=350085
Old 05-30-2019, 10:39 PM   #8
Texas240
Prius Owner
Texas240's Avatar
I also recommend getting a double pass condenser. I swapped one in my 93 240 an im getting 39-43º temp at stop slights and around that in 80-90º ambient temp outside. I also added an Ls engine to my ac unit.
93 245 LS Engine Swap Project
Old 05-30-2019, 10:49 PM   #9
iHateVolvoPeople
Link to condenser? I think the 93 (and 93 only) 240s were your standard parallel flow condenser correct? Too lazy to go look at mine.
Old 05-30-2019, 10:58 PM   #10
Texas240
Prius Owner
Texas240's Avatar
No idea, was over 4 years ago and is no longer in my purchase history.
Old 06-01-2019, 08:40 PM   #11
durk80
durk80's Avatar
[QUOTE=dbarton;5957398]
/QUOTE]
Dave B
Thank you Dave! I'll try that because I could never really get it that cool, and I much rather replace the valve than evac the system. And a simple test too
Old 06-03-2019, 12:21 PM   #12
rallydallas
Well this might help a bit. Looked at the GCP.SE catalog for 88-93 (group 87, page 1014 )
1259556 Condenser 4cyl -1990
3540373 Condenser 4cyl 1991- (LHD/RHD -1992)
3540647 Condenser 4cyl 1991- (LHD/RHD 1993- R134A)
1259556 Condenser DSL
The 3** numbered one in the pictures definitely looks like 2 row, while the 1** numbered ones appear single (although hard to tell..)
rallydallas is offline   Reply With Quote
Old 06-05-2019, 12:01 AM   #13
That high side is too high. You could be overcharged. Or a restriction. I would feel around and see if there's a spot that gets hot, but not right after the hot spot.
I use a machine that puts in the correct weight.
