Old 06-02-2019, 05:54 PM   #1
vwbusman66
Stößelstange über alles!
vwbusman66's Avatar
Default 140 ignition switch smoke?
Turned the key to move the 142 back into the garage and as I turned the key to "ON" and "Start", I was greeted by a small plume of smoke that persisted until I turned the key back to off.
Is this the switch portion of the ignition going bad or a loose wire? The engine won't turn over with the key anymore, but the warning lights dim.
Help.
1971 142 beater/fake racecar
1972 145 sh*t hauler
Originally Posted by propav8r
The incest is implied.
Old 06-02-2019, 06:04 PM   #2
alschnertz
Enough already!
alschnertz's Avatar
Do whatever you can to save that switch.
Replacements are not easy to come by.
Old 06-02-2019, 06:08 PM   #3
The Librarian
You just let the smoke out. Now you have to replace it.
Old 06-02-2019, 06:14 PM   #4
vwbusman66
vwbusman66's Avatar
What am I supposed to do to save it if it already smoked? How can I prevent further damage?
We had a jar of that at the shop I used to work at.
Old 06-02-2019, 07:50 PM   #5
alschnertz
Enough already!
alschnertz's Avatar
I wouldn't say it's trash yet, unless you let it smoke for an extended period of time.
Label and disconnect all the wires at the switch and start fault tracing.
My $0.02.
Old 06-07-2019, 11:25 PM   #6
Old 06-08-2019, 08:59 AM   #7
vwbusman66
vwbusman66's Avatar
Turns out it wasn't the ignition switch.
The junction plate near the driver's headlight decided to come loose and ground. I wrapped it in electrical tape and it solved the problem. None of the wires at the switch shorted and showed signs of melted insulation.
The switch still functions fine.
Old 06-08-2019, 12:37 PM   #8
planetman
planetman's Avatar
Electrical tape is the way to go for now, but you should consider a more permanent repair.
That junction is 1 of Volvos dumber electrical designs and it was used on 140s, 164s and 240s through 1977.
The weak link of the 3 pieces is the cover and of course that part is NLA.
However, I've got some 3D printed covers made.
Eric
Torrance, CA 90502
Old 06-08-2019, 01:23 PM   #9
The Librarian
Old 06-08-2019, 11:58 PM   #10
vwbusman66
vwbusman66's Avatar
Holy ****!
What don't you guys stock/make??
