Old 06-03-2019, 06:51 AM   #1
RickATL
Family's fleet manager
RickATL's Avatar
Default turns over, won't start, codes 123 & 224
1993 240/244 2.3
Would a coolant temperature sensor fault code be thrown and cause a no start due to no coolant?
This is the first start in near a year after a reconditioned head and many new parts. I wanted to perform a coolant system flush with a cleaner so i just put some distilled water in with the thermostat removed. I was going to add the cleaner once it started through the overflow container. The coolant temperature sensor is a new one.
RickATL is offline   Reply With Quote
Old 06-03-2019, 08:29 AM   #2
bobxyz
bobxyz's Avatar
Check that the coolant temp sensor connector is fully seated, and that it's the right connector. On a '93, I don't know if it's possible to accidentally swap a couple connectors, but it is possible on earlier years that have a separate start injector.
Old 06-03-2019, 02:14 PM   #3
283SD
I had a coolant temp sensor code problem turns out it was a bad ground on the fuel rail [2 grounds]
Old 06-03-2019, 08:15 PM   #4
2manyturbos
The connector for the IAC and the ECT sensor will interchange. Make sure you have the white 2 terminal connector connected to the ECT sensor.
Old 06-03-2019, 08:53 PM   #5
RickATL
RickATL's Avatar
Thanks for the help.
I put in new coolant temp sensors, re- set the timing belt, and 13 hours later, i figured out it was the terminal cartridge fuses. Looks like it was almost a fire.
Old 06-03-2019, 09:05 PM   #6
2manyturbos
That is really common.
Old 06-03-2019, 09:37 PM   #7
RickATL
RickATL's Avatar
I just read on another thread (5 years old) that these were discontinued due to fires. Any idea what to replace it with? I don't think it mine will make it much longer.
