Old 06-05-2019, 03:28 AM   #1
Brotkasten
Jonas
Brotkasten's Avatar
Default 940 Wagon rear end clunk
Hello,
I've got a bad rear end clunk on my 91' 940 Wagon (lowered 65/40) with 236,000 miles. It occurs mostly while accelerating at a turn from very low speeds. I changed the torque rod bushings to PU and reinforced the subframe but there is no noticeable difference. The subframe bushings looked great.
It also produces a clunk when disengaging the clutch. It sounds like its coming from the rear end too.
Is my rear axle just worn out internally?
91' 940 B230FB+T M90
Old 06-05-2019, 05:19 AM   #2
mocambique-amazone
At first I would check the rear u-joint, Kreuzgelenk, Jonas.
Beste Grüße Kay
