Old 06-06-2019, 09:33 PM   #1
2turbotoys
Have you seen me?
2turbotoys's Avatar
Default Part number request, windshield washer check valve
I'm redoing the windshield washer system on my '78 242 and wanted to include a check valve from a newer car. I have 2 of them but after inspection the diaphragms are bad, I can't remember what cars I got them from though.
Example pic, doesn't have to be that one though.
Thanks!
1978 242, 5.3 L33
1979 242, MS, R brakes
2006 V50 T5 AWD @ 17 PSI
Old 06-06-2019, 10:32 PM   #2
The Librarian
240's -'80 use an inline check valve part #1210139. The one pictured is part #1392074 and is used on 7/8/900 series cars.
Old 06-07-2019, 12:08 AM   #3
freevolvos
freevolvos's Avatar
So what do these valves do? I've had them leak and removed them
Old 06-07-2019, 11:27 AM   #4
2turbotoys
Have you seen me?
2turbotoys's Avatar
It helps the washer fluid lines stay full so the fluid doesn't drain back down to the reservoir. Saves a few seconds of running the pump, squirts faster. (Insert squirting faster joke here)
Old 06-07-2019, 11:48 AM   #5
Run a filter too.
Old 06-07-2019, 05:53 PM   #6
2turbotoys
Have you seen me?
2turbotoys's Avatar
Thanks for the p/n's. I like the 7/9 one better so ordered that. I will definitely run a filter also, just replaced every part in the system except the reservoir, that got a thorough cleaning.
Old 06-07-2019, 08:49 PM   #7
freevolvos
freevolvos's Avatar
That what I thought they did thanks tho for taking the time to answer me
Old 06-07-2019, 09:00 PM   #8
2turbotoys
Have you seen me?
2turbotoys's Avatar
Anytime. My old '70's 242's didn't have those valves, so since I replaced all the lines, pump, nozzles, etc, I just want max performance from the system lol, a bit silly but it is a very noticeable difference, and prevents a few dry wipes on the window.
