Old 06-10-2019, 06:58 PM   #1
sksmith
sksmith's Avatar
Default Big A$$ Poly Trailing Arm Bushing Installation
Can anyone post any tricks for installing the big a$$ poly rear trailing arm bushings in a 140 series?
I'm assuming that I can use my fancy China Freight ball joint / control arm press kit. Just want to avoid damaging my pretty painted trailing arms as much as possible.
Thanks,
Steve
Old 06-10-2019, 09:08 PM   #2
nel621
maybe a smaller tool?https://forums.tbforums.com/showthre...m+bushing+tool
Old 06-10-2019, 09:16 PM   #3
2turbotoys
Salaminizer
2turbotoys's Avatar
I got that tool, it's dam nice.
2006 V50 T5 AWD 16 PSI +
Old 06-10-2019, 09:27 PM   #4
The big bushing presses into the arm, not the diff brackets like a 240. There's no outer metal shell so it's just a friction fit.
Lube the poly bushing and the arm with some aqua-lube and press it in with a flat plate on top of the bushing. Leave the steel sleeve out until the bushing is installed.
Old 06-10-2019, 09:35 PM   #5
gsellstr
gsellstr's Avatar
I've found it VERY helpful once you've greased up the bushing to put it into a piston ring compressor and compress it as far as you can. This helps it go in easier, plus it helps get it started straight, rather than launching across the shop. I've been doing that for the last several sets of 740 torque rod bushings, uses the same bushing actually.
RIP
Nick Fengler "fengler" 8/6/18
74 144 B20
90 745Ti
Old 06-11-2019, 11:15 AM   #6
sksmith
sksmith's Avatar
I'll have to give the piston ring compressor a shot & take the sleeve out.
You guys are a wealth of knowledge!!
Thanks,
Steve
Old 06-11-2019, 09:05 PM   #7
gsellstr
gsellstr's Avatar
DEFINITELY need to have the inner sleeve out as well, otherwise they will be a complete PITA to install, moreso than normal.
