Old 04-07-2012, 01:55 AM   #1
jerryc
jerryc's Avatar
Default Head coolant q's
I'm prepping a head and turbo to swap into my 93 940T. Head is a 530.
I'm doing minor port touch-ups re: stealthfti's site, lips here and there, using touch to try to get them all the same. I ground down the intake guides also. You don't need those, right?
In looking at the head and at many pics of heads, and some discussion of cooling passages, and that some have said that no.3 cyl runs lean/hot, I was thinking about the holes in the block and hg that do not have matching holes in the head. IOW, the GrpA mod.
I note that the cyls have different coolant passages near them.
No1 has two, 180 apart.
No2 and 3 have two, towards the intake valve
No4 has 3, two at the intake end, one at the exh end.
Hmm; I thought I knew where the pics were of the GrpA mod were, with 6mm and 4mm holes drilled along the cyls and at the back of the head; now I can't find them. Well anyway, I was thinking this was probably a good idea, esp at cyl3.
Comments? And links to pics?
What's the female equivalent to a dick pic? twat shot?
There isn't one because dudes aren't grossed out by unsolicited vaginas.
jerryc is offline   Reply With Quote
Old 04-07-2012, 10:06 PM   #2
jerryc
jerryc's Avatar
So these are what I'm talking about, at the rear. I don't know what head that is, it has small round passages rather than small teardrop ones along the sides, but it seems to have all the holes drilled.
http://forums.turbobricks.com/showpo...6&postcount=37
And later I found more info but no recommendations. Some have thought of it the way I am, though.
"by "group A holes" do you mean the 6mm holes in the back of the head and the 4mm holes along the exhaust side, to take advantage of the holes that are already in the head gasket?"
http://www.forums.turbobricks.com/sh...3&postcount=15
"I concluded that the GrpA holes were useful as far as assisting in getting some cooler coolant up under #1, #2, and #3 exhaust port structures in the head [#4 already has it]; and that the 2 added holes behind #4 bore would also assist in getting the flow up into the very rear of the head.
BUT, I had some reservations about adding those holes because of what I concluded about the flow through the head.
The flow is intended to go rearward in the block; then rise up into the head at #4 and then come forward to the thermostat housing. [that is the general desired flow path] The passages that let coolant up into the head at #1, #2, and #3 are there to mix in some cooler coolant to the already heated coolant that has gone all the way to #4 and is coming forward...to even out the temp of the coolant; to try to get and keep all four combustion chamber structures at the same temperature.
" Stealthfti
http://www.forums.turbobricks.com/sh...7&postcount=25
Hmm.
Old 04-07-2012, 10:21 PM   #3
Koston740
Rollin on reps
Koston740's Avatar
interesting
90 745 w/ b230ft- Holset He351cw, TLAO chips, eBay ic, Delphi 65's, bmw oil squirters, spec stage 2+ clutch, t5 WC E85
Feedback thread:
http://forums.turbobricks.com/showthread.php?t=236339
Koston740 is offline   Reply With Quote
Old 07-13-2017, 06:49 AM   #4
classicswede
Volvo upgrades
I remember seeing some details on this much more recently but my googlefoo is weak and I cant find it.
Anyone have teh exact details?
Old 07-13-2017, 07:25 AM   #5
Jimmyhoppityhop
Have you thought about using an electric pump only to try and improve coolant flow before drilling into the head and having the interruption of coolant flow like some believe? You'd then remove the draw on the engine from the pump as well.
Just realised you revived a dead post, whoops.
Jimmyhoppityhop is offline   Reply With Quote
Old 07-13-2017, 08:42 AM   #6
crogthomas
crogthomas's Avatar
Right at the top of the forum:
http://forums.turbobricks.com/showthread.php?t=218895
crogthomas is offline   Reply With Quote
Old 07-13-2017, 06:34 PM   #7
classicswede
Volvo upgrades
Na that not the one. There is mention of it there but there was more detailed post from a Swedish guy.
Electric pumps are race engine only as they just dont last
Old 07-14-2017, 03:48 PM   #8
K9 240
K9 240's Avatar
was it this one?
http://www.stonis-world.com/headwork.html
K9 240 is online now   Reply With Quote
Old 07-14-2017, 04:31 PM   #9
PCH
Since this thread is about 7/9 Series originally: There are claims that alternative heater control valve from GM application provides additional coolant flow through the cylinder head http://forums.turbobricks.com/showthread.php?t=246617
Old 07-14-2017, 05:45 PM   #10
classicswede
Volvo upgrades
Originally Posted by K9 240 View Post
Thanks, exactly what I was thinking of
Old 07-14-2017, 05:57 PM   #11
classicswede
Volvo upgrades
interesting reading
