Old 09-13-2016, 09:55 PM   #26
Dadssleeper
Brakes came in today so got them installed , this is how she sits on IPD springs and 205/65/15's . After I get the windshield installed I will be working on getting all the needed parts I will need to freshen up the b230ft (gaskets hoses etc. ) as well as the resistor pack I will need and the oil cooler. Although the clutch didn't slip I'll be doing the clutch and the rear engine seals as well so it will take me a bit of time to earn and get up all the parts I need for the swap to be done right.
I posted some photos in the showroom as well.
Old 09-13-2016, 10:48 PM   #27
photoman327
photoman327's Avatar
You can also run later high impendce injectors and not runs the restitor pack also.
Old 09-14-2016, 12:59 AM   #28
Wilford Brimley
enjoys the beetus
Wilford Brimley's Avatar
This, I'm doing this and it works great
(Insert Photobucket pic here)
http://forums.turbobricks.com/showthread.php?t=316428 91'744T .57 t3/t4, big ic, greddy type s, 55lb/hr injectors, bosch 044, tloa ecu/ezk, 3"amm, rsi stg 3 cam, ttr cam gear, top mount header, 3" exhaust, kevlar tbelt, e-fan, 22 psi, intrax springs, cherry turbo brace, ipd rear sway, dual front sway bars, bilstein struts, camber mod, accum mod
Old 09-14-2016, 08:59 AM   #29
Dadssleeper
I read about that when I was looking into resistor packs and This will be the route I am going, I prefer not to splice the wires , plus its one less step, yet its one less part I have to see.
After I pull the Engine an transmission I plan to do some body work in the engine bay, hide a few wires ....then finish with my rhino truck bed lining.
Old 09-20-2016, 06:55 PM   #30
Dadssleeper
Originally Posted by BillyMaysHere View Post
Injector impedience info, just check the part number http://users.erols.com/srweiss/tableifc.htm
This is great spent a lot of time here.
Ok so I was suggested to go with the red injectors from an 850 turbo, I found the P/N 0-280-150-785 at high ind. and ev1 at a flow rate of 29.5
Looking into other options (what I am able to find affordable) I found some.
p/n/ 0-280-155-830 blue injectors high ind. EV6 and a flow rate of 30.
I think I am on the money here with these blue injectors but just wanted to check with some experts to make sure I got this right before I buy them and find out that there is something else beside spray pattern, flow rate and ind.
Old 09-20-2016, 07:31 PM   #31
cwdodson88
yessir
The Build Thread
SVEA - PUSHROD TURBO!
cwdodson88 is online now   Reply With Quote
Old 09-21-2016, 02:58 AM   #32
BillyMaysHere
BillyMaysHere's Avatar
I snagged some injectors from this guy, great service and already cleaned in ultrasonic cleaner. $10 each with free shipping http://forums.turbobricks.com/showthread.php?t=301784
I also I bought a rebuild kit from these guys
http://www.mrinjectorparts.com/store..._Kits_002.html cheap and came with 2 jolly ranches in the package
Old 09-21-2016, 02:58 AM   #33
BillyMaysHere
actually the reds are only $8 each
Old 10-17-2016, 12:51 PM   #34
BillyMaysHere
update?
Old 11-10-2016, 04:28 PM   #35
Dadssleeper
Default Update
Yeah I got it all apart and and waiting for the gaskets , ran across an issue with the original car with the b230f having a cold start injector and the newer engine with the b230ft does not. So I prepped and painted the wrong intake. Anyway I got to taking the b230f intake apart and got to wondering about the computer from the b230ft and wondering if it has the ability to control that injector properly because it did not operate one before.
So now I am wondering should I go with or with out the cold start injector. I live in maine so I think it would be good to have and the car was starting and running great before I took it apart, but if there is going to be an issue with the computer then I can't do it so far I haven't found much info about it.
Old 11-11-2016, 11:27 AM   #36
Dadssleeper
I think I found the info I needed here on TB (quoted from the post I found ) "Also you don't have lh2.4. Also LH 2.4 doesn't need the cold start injector. If it doesn't have the cold start with lh2.4 only, it will still work. The lh2.4 ECU knows if you do or you don't and can do either. The earlier lh that you have, different story and I don't know it...."
http://forums.turbobricks.com/showthread.php?t=184958
So if what I am reading I am reading correctly , I can just use my older manifold with the CS injector and the computer will know what to do?
Boy I hope its that simple.
Old 11-11-2016, 11:29 AM   #37
Dadssleeper
update?
Cleaning it up getting it ready, making sure I do everything right looks like a mess now.
Old 11-12-2016, 01:43 AM   #38
BillyMaysHere
as for the cold start injector, if your newly swapped computers (from the 740) ran an engine without an cold start injector, then you don't need to use the cold start injector.
VOlvos without cold start injectors, simply read the engine temperature from the ECT sensor (there are 2 temp sensors, one for gauges and one for the computer) when the car is cold, it richens the mixture and accomplishes the same effect until the car is warm.
The senor that goes to the ecu mounted on the head and is the one of the right (the one with a black connector)
Old 11-12-2016, 01:52 AM   #39
BillyMaysHere
Just run the b230ft mani and disregard the plug for the cold start injector. Or find a b230ft intake with a cold start injectors set up, orrrrrr have your mani drilled and tapped check link to see the difference between the intakes http://ovtuners.org/forum/viewtopic.php?f=18&t=6058
Old 11-12-2016, 01:54 AM   #40
BillyMaysHere
disregard my last posts, yes use your old mani. It should be all good. If it isnt then all youd need to do is unplug the cs injector
Old 11-12-2016, 11:09 AM   #41
Dadssleeper
I am getting this now ...I just saw the light at the end of the tunnel!
Old 11-12-2016, 11:13 AM   #42
apachechef
Burnt Sierra Madre
It might be a train, though.
Dammit, Lummert.
Old 11-12-2016, 11:29 AM   #43
Dadssleeper
I just got to thinking then, I don't want the cold start injector if the 740's computers will compensate. Not to sound like a bouncing ball but thats just one more thing that can leak or fail.
I got the truck bed coating under the hood almost done, spent a bit more time under there with the grinder then I thought but glad I did.
Old 11-16-2016, 08:45 PM   #44
Dadssleeper
Cut the top part of the exhaust today , will also do a cut in the center to align it correctly when I add build the support bracket for it. I will have to extend this a bit to reach my cat.
Waiting on the new clutch and a few other things as I proceed , but been sanding and painting a bunch of parts in the mean time.
I liked the location of the 02 hole so I left that where it is and will plug the other that came on the 240.
Also here in Maine we get the worst rust issues so I have taken the time to undercoat everything using a truck bed lining paint.
Old 11-16-2016, 09:19 PM   #45
BillyMaysHere
nice Progress!!!
Old 11-22-2016, 10:34 AM   #46
Dadssleeper
nice Progress!!!
I found one more issue I am hoping you can help me out with. The MAF tube/hose has a sensor in it. Of coarse my 1990 240 does not have a connection for it. I been researching it and I cannot find much about it.
This is the hose I am talking about and the sensor in it.
http://www.autohausaz.com/search/pro...FQkKaQodOEcIgA
Old 11-22-2016, 03:37 PM   #47
Dadssleeper
Default Air Temperature Sensor
I found out that its an air temperature sensor, but can't find if it throws codes or what its is suppose to adjust and how important it is to the computes I got. at this point I got some parts in some I am working up to this point and trying to read up on anything I can find but this thing don't seem to get much talk.
Old 11-22-2016, 10:05 PM   #48
aendrody
Just gonna send it
aendrody's Avatar
Called a PTC resistor. Will set check engine. Will run fine without it. Side bar: i used an LH 2.4 harness out of a 240. It makes things a whole hell of a lot easier, especially if your drunk doing the harness.
aendrody is offline   Reply With Quote
Old 11-22-2016, 11:16 PM   #49
Dadssleeper
OK Great I found that! PTC resistor , Its hooked up 12v via the fuel pump relay so it gets power when the car is on....weird.
Thanks for the info a whole bunch more stuff is coming up in my sears now.
Old 11-23-2016, 12:03 AM   #50
Dadssleeper
Default PTC Resistor
Ok this is what I found out and please feel free to steer me straight if I am wrong.
Following The diagram its grounded SB wire (guessing that means solid black) Then its also has one more wire that goes to it BL-Y ...The BL-Y wire connects to the BL-Y coming from the MAF, jet tronic control module, and the EFI Relay from the EFI Relay it then leads to the Radio suppression.
I am thinking I can just splice this thing into the BL-Y in my harness if I get an engine light.
http://www.autoelectric.ru/auto/volv...993/940-93.htm
