Old 02-20-2017, 11:13 PM   #1
LC4CARL
Aero challenged
LC4CARL's Avatar
Default Going straight / 240 steering "wander"
The car ('87 245 N/A) has the following mods: 2.5 coils off front, 1.0 off rear, Bilstien Touring shocks, adjustable rear track bar, 16.5 mm rear wheel spacers, upper and lower front braces, Hydras with new 215/55R16 tires (32 psi), 23mm / 19mm swaybars, manual steering rack, new ball joints, tight tie rod ends, original bushings.
Alignment: Camber: L -.3 / R -.1, Caster: L 2.2 / R 1.8, Toe: L .15* / R .15*
The goal is a decent handling, reliable street car.
The absolute worst thing about this car is that it will not track straight. It drives me crazy. On anything less than a perfect road, it wanders in the lane requiring near constant steering input.
I seldom drive the car and don't recall at which point in my modifications the steering deteriorated. It's possible it was like this from the start as the car was in extreme disrepair.
By lowering the front end and "skying" the lower control arms, is it common for the car to wander? I've lowered other vehicles and not run into this, but each car is different. My first thought is worn parts, but I can't find them.
At this point, it goes without saying that, Redwood has the right for a huge "I told you so."
Built-not-bought: PDXdl Resto-Mod.
Old 02-20-2017, 11:24 PM   #2
You got a big fat rake going on there, and not only is it not a top fuel dragster BUT you've negated a good deal of the caster.
TOLD YOU SO SUCKA!
how psi stock can support?
Old 02-20-2017, 11:25 PM   #3
KeizerBrickGuy
Don't Do It
KeizerBrickGuy's Avatar
So it drives straight on a decent road(with no need for contact with the steering wheel)? If it doesn't drive straight on it's own on a mostly flat street, the alignment tech needs a toe punch to his sack. When I was getting my bricks aligned I made sure that camber and toe were to spec. The caster doesn't look horrible. I would try getting the camber set to -0.5* with the same current toe setting of -0.15*. My car has the strut mounts that are separating and I was able to get camber set to -0.5* and toe around -0.1 to -0.15* and it doesn't wander unless I'm on I-5.
-Stephen
#mclovethesenuts
-Wife's car: White 1990 244DL, T cam, 190k miles.B230F LH2.4, AW70 w/aux cooler, Duracool AC, purple refinished Virgos, tow hitch, ipd wagon overload springs.
Old 02-20-2017, 11:26 PM   #4
KeizerBrickGuy
Don't Do It
TOLD YOU SO SUCKA!
Old 02-20-2017, 11:45 PM   #5
LC4CARL
Aero challenged
LC4CARL's Avatar
TOLD YOU SO SUCKA!
More caster couldn't hurt. Wish there was a way to adjust it. I've got the power steering ball joints on it. What are you guys seeing for caster numbers?
I probably did take too much out of the front springs. Didn't want to cripple the rear suspension too much in case I actually had to carry something.
It's not nearly as jacked up as my HS buddies Nova with shackles...
Old 02-20-2017, 11:48 PM   #6
Default N00brake
NB4 how come my front tires are getting feathered and worn on the outer edges?
But hey you're one of the kewl kids now right?
Old 02-21-2017, 12:21 AM   #7
PromiseRing
We don't even like Volvos
relatable
Old 02-21-2017, 01:05 AM   #8
LC4CARL
Aero challenged
LC4CARL's Avatar
Whatever.
Old 02-21-2017, 02:11 AM   #9
toms_elleck
toms_elleck's Avatar
Try just lowering the back a 1/2 coil. It won't hurt your ability to load it up. Unless you plan on sticking like a half a ton of bricks in there or something. And at that point, you'd want overload springs (cut down) with stiffer shocks anyway.
I used to load my Beige Against the Machine wagon to the gills with swap meet parts. Never had a problem. And it started out lower than yours, I believe.
Unloaded:
These cars wander like **** without enough caster. If you really want to keep the rake, get aftermarket camber plates so that you can wank a bunch of additional caster into the car.
toms_elleck is offline   Reply With Quote
Old 02-21-2017, 05:13 AM   #10
Tuff240
240 Ninja
Tuff240's Avatar
Go have A N T tire align it.
-.5 to -1 camber, toe 0* would be a good start from where you are at.
The rake isn't helping at all. As Ken said, you lost caster, but you have a lot of weight riding on the front tires now also. It's probably squirrelly under braking or during hard cornering right now too.
Also what ball joints are you using? Manual or power ones? Should be using power ones with more castor.
Loosen the 3 bj bolts and pull out and forward on the strut assembly while you tighten them.
-Patrick
Old 02-21-2017, 11:56 AM   #11
If only there was some magical way....
http://www.kaplhenke.com/collections...t-strut-mounts
or
http://www.kaplhenke.com/collections...e-strut-mounts
www.BEIGEPOWER.com
Kaplhenke Racing Facebook
The only safe bet is Ben.©
Old 02-21-2017, 12:42 PM   #12
KeizerBrickGuy
Don't Do It
My caster is shot to hell, but it doesn't wander unless I'm driving on a heavily travelled road like I-5, I-84 or the like. Caster is important too, but those numbers shouldn't make it too bad. I've been considering Bens strut mounts, just gotta save. I need to pull my alignment specs from the last alignment I did before I got my State job. I'll report with my numbers when I get to my work bench/station.
Old 02-21-2017, 01:05 PM   #13
Your worn out rack probably isn't helping either.
Old 02-21-2017, 01:07 PM   #14
Pro Sneaker Peddler
Lower the ass end and get BNE Select top mounts. DO IT NOOB.
Old 02-21-2017, 01:50 PM   #15
Jack
junkman
Jack's Avatar
TOLD YOU SO SUCKA!
You don't know nothing old man....
We said this would happen from the start
✅ cut sprangs
✅ complain of crap ride/drive ability
Future ✅ s
- worn tires
- put on jackstands
- let 6 months pass
- buy another Volvo
- crush
Old 02-21-2017, 01:59 PM   #16
Benjam83
Moar Volvos than Queen B
Tie rod ends?
Ball joints?
Bushings?
Adjustable strut mounts aren't going to do crap if the rest of the system isn't in good repair.
Ben
12 WRX Hatchback
10 Subaru Outback
93 245 m47
Benjam83 is offline   Reply With Quote
Old 02-21-2017, 02:01 PM   #17
Jack
junkman
Jack's Avatar
Originally Posted by Benjam83 View Post
Tie rod ends?
Ball joints?
Bushings?
Are you turning blue yet?
Old 02-21-2017, 02:03 PM   #18
Pro Sneaker Peddler
Tie rod ends?
Ball joints?
Bushings?
We are all assuming that OP knows how to keep wear items replaced when needed, based on post history.
Old 02-21-2017, 02:15 PM   #19
Jack
junkman
Jack's Avatar
Well I'm on page 22 of his thread and do far only suspension work done was fatter sways
Edit page 25 got lower chassis braces...
Old 02-21-2017, 05:36 PM   #20
He thinks it looks good though ....
Little does he know he's the only one.
And Chicks definitely don't dig it.
Old 02-21-2017, 06:11 PM   #21
culberro
culberro's Avatar
This^
If you're in the Portland area, seriously get to know Garth and the crew at Trackside Motorsports / A-n-T Tire.
I'd suggest just a smidge of toe-in for a DD, and as much camber as you can get with stock sprangs.
Want better handling? Spend the coin to get more caster and a bit more negative camber.
Old 02-21-2017, 06:13 PM   #22
Jack
junkman
Jack's Avatar
chicks dig 122s
Old 02-21-2017, 08:09 PM   #23
LC4CARL
Aero challenged
LC4CARL's Avatar
NB4? Thanks a lot.
Old 02-21-2017, 08:10 PM   #24
LC4CARL
Aero challenged
LC4CARL's Avatar
Good stuff. Thanks.
Old 02-21-2017, 08:11 PM   #25
LC4CARL
Aero challenged
LC4CARL's Avatar
Very helpful. Beautiful car. Thank you.
