Old 03-07-2017, 03:00 PM   #51
toms_elleck
toms_elleck's Avatar
I can't take the credit. A group of us got together in OT and greatly discussed why people most often crush their Volvo around here. Extensive research by 17 members discovered that
97% of the time it starts with cut springs
the stats go even higher when car is an 85+ 240 to a 98.7% probability of crushing
99.9876% if belt line trim has been removed
fix your suspension and steering and quit trying to reinvent the wheel
I have cut springs on several Volvos, and haven't crushed even one.
You haven't cut springs on any Volvos, but you have crushed several.
Something doesn't add up with your logic.
toms_elleck is offline   Reply With Quote
Old 03-07-2017, 03:02 PM   #52
Jack
junkman
Jack's Avatar
I saved move Volvos then 99% of people on here
also stats never claimed 100% because we actually counted people like you into our survey
Originally Posted by toms_elleck View Post
I regretfully agree with Jack.
Originally Posted by 122power View Post
make k-jet great again.
Old 03-07-2017, 03:08 PM   #53
2manyturbos
Originally Posted by KeizerBrickGuy View Post
That is true about the camber, but zero toe? Talk about stability issues. So maybe it would boil down to bushings now....
It was Tuff240 that suggested starting with zero toe. He likes his cars responsive. When you want your car to change direction quickly, zero toe to positive toe is what you want with a RWD platform. It will make them climb the groves in the road is the drawback. Hence, "wander".
Old 03-07-2017, 04:33 PM   #54
toms_elleck
Originally Posted by LC4CARL View Post
It's probably me, but the camaraderie of a shared enthusiasm in Volvo's is nil around here sometimes. I have put hundreds of hours and thousands of dollars into my ride. I have been supportive and respectful of others on the forum. I need to take a break from this place.
It's not just you. I don't like the way certain people constantly talk down to other members either.
I like to set my toe at 1/8" in, and usually I just jam the camber to as much negative as I can get with the stock strut mounts. I think that usually ends up at just under 1 degree.
It is key to measure toe after pushing the car forward 5-10 feet. That way, whatever bushings or mounts that might be loose or worn will be tensioned in the direction that they will be tensioned while driving down the road. I've heard of people having someone sit in the driver's seat when they do this too, but I'm usually working on my car alone so I skip that step.
The use of a toe measurement bar makes the procedure a lot easier, and you can make a cheap one yourself:
Old 03-07-2017, 04:41 PM   #55
2manyturbos
That's what I set 240s to, 1/8-3/16 inch toe in, depending on how the car tracks when I take it for a test drive. I try to get away with as little toe in as possible.
With all the FWD cars on the road these days one of the first things I suspect with a wandering car is whether the alignment guy realized the car was RWD. I have corrected a few 2/9 cars that came to me with their front wheels towed out, including a long time customer that has a 93 245. The shop had set it 1/8" towed out. The thing was all over the place even though the suspension is in top notch stock condition.
Old 03-07-2017, 05:57 PM   #56
Tuff240
240 Ninja
Tuff240's Avatar
I set mine to just a touch of toe out. Like a 1/16th. Depends on what I'm doing with the car overall, but generally all of mine are set up for very spirited if not track driving.
-Patrick
Old 03-07-2017, 06:06 PM   #57
2manyturbos
Definitely not recommended for those that are spending time texting while driving.
Old 03-07-2017, 06:18 PM   #58
KeizerBrickGuy
KeizerBrickGuy's Avatar
I would go through and bite the bullet and replace bushings. I know I'm going to need to on my car... Then I will get around to lowering it on ipd springs with billy hd's.
-Stephen
#mclovethesenuts
-Wife's car: White 1990 244DL, T cam, 190k miles.B230F LH2.4, AW70 w/aux cooler, Duracool AC, purple refinished Virgos, tow hitch, ipd wagon overload springs.
Old 03-07-2017, 06:20 PM   #59
Jack
junkman
Jack's Avatar
the OP crushed his Volvo and got a 2008 Camry
/end thread
Old 03-07-2017, 06:23 PM   #60
toms_elleck
/end thread
Old 03-07-2017, 06:47 PM   #61
Tuff240
240 Ninja
Tuff240's Avatar
/end thread
Probably waxes it with NuFinish also.
Old 03-07-2017, 06:49 PM   #62
Tuff240
240 Ninja
Tuff240's Avatar
Heaven forbid someone set up a car for driving over being able to text. Our world is so !@#$%^!
Old 03-07-2017, 06:49 PM   #63
Jack
junkman
Jack's Avatar
but twice a year
Old 03-07-2017, 06:53 PM   #64
2manyturbos
Hey, when the auto manufacturers put a display screen down in the center of the dash we were all doomed. Self driving cars can't happen quick enough, IMO.
Old 03-07-2017, 06:56 PM   #65
Jack
junkman
Jack's Avatar
sigh... I have a feeling that "man driven" cars will be outlawed on highways etc when that crap happens
Old 03-07-2017, 06:58 PM   #66
Tuff240
240 Ninja
Tuff240's Avatar
Well there is no computer controlled car that will ever catch me, so have at it. I don't care if I have to drill for my own fuel/oil and refine it myself. Never going to happen here.
Old 03-07-2017, 07:07 PM   #67
Jack
junkman
Jack's Avatar
Old 03-07-2017, 07:08 PM   #68
2manyturbos
Have you seen the commercial for the car with the collision avoidance system with the woman driving, looking in the mirror imagining herself on The Voice or Idol show? I actually had a woman doing that 3 weeks ago. It took 1/2 mile with my signal on before she looked back at the road and realized I wanted to slow down so I could turn. I was going to go right past the road I wanted to turn on because I already got rear ended by someone texting back in July. I'm still going to a concussion specialist because of that idiot. People think their cars are their living room or cubicle at work.
Old 03-07-2017, 07:10 PM   #69
2manyturbos
I don't want to see that happen either. I do believe there are many people on the road that should have self driving cars though.
Old 03-07-2017, 07:55 PM   #70
KeizerBrickGuy
So true. Drive, then text. Not both.
Old 03-07-2017, 11:38 PM   #71
LC4CARL
Aero challenged
LC4CARL's Avatar
I love TBís. The combined knowledge and experience with these cars here is simply awesome. If one is willing to work some and spend some, the resulting car can be something special. But mostly for me, itís the opportunity to hang out and BS. Ideally, these conversations would be had in the garage over a pint of brew. But, on the plus side, I do get to visit with Volvo enthusiasts from around the globe. And thatís pretty cool.
Thanks for all the great input on my dilemma. Nothing a little blood, sweat and tears wonít resolve. Very much looking forward to the upcoming car event season. Hoping to do some fun road trips and make some new friends.
'87 245 DL: B21FT in the works!
Old 03-08-2017, 12:20 PM   #72
LC4CARL
Aero challenged
LC4CARL's Avatar
Interesting read.
https://nasaspeed.news/toolshed-engi...e-by-yourself/
Old 03-08-2017, 12:29 PM   #73
Dan
TQ>HP
Dan's Avatar
I like this tool, I usually measure inside the wheels and stuff gets in the way, gonna make one of these
"You never want to keep a perfectly good car running and driving for too long. You gotta disable it for months to years at a time or you're no Hot rodder" David Freiburger
Old 03-09-2017, 04:09 AM   #74
Kjets On a Plane
Devoid of Luxury
Kjets On a Plane's Avatar
Probably more just unfeasibly costly to insure to drive in city limits/certain places than outright illegal.
It'll be a minute to say the least.. America isn't Hong Kong yet where every square inch is built up. Many cites you can be in city limits with lots of traffic control, straight to un-improved cut through gravel roads.
How PSI a stock can support?
Old 03-14-2017, 12:40 AM   #75
LC4CARL
Aero challenged
LC4CARL's Avatar
Stands under crossmember, front wheels off.
With large Channel Locks, squeezing new PS ball joints top to bottom shows approx 1/8" vertical movement. With a small pry bar lifting bottom of the new lower ball joints against a jack stand fulcrum shows no apparent movement on an unloaded suspension. Small pry bar on front lower control arm bushings: from below with jack stand as fulcrum, no apparent movement (F&R). On front bushings pushing out against the crossmember, no apparent movement. On the rear bushings, pushing against the washer from the mount, the bushings do visibly deflect forward. This does not, in my lay person opinion, appear to be excessive and is the same side to side.
Do wide tires contribute to this condition? I've got 215/55R16's. Not super wide, but bigger than OE.
Corresponded with Ben, to get the caster out in the 3-4 (5*?) range with the camber plates would require the smaller springs, so I probably won't pursue that. I'm at 2* now.
More to come.
