Old 04-30-2017, 06:03 PM   #126
EivlEvo
Originally Posted by LC4CARL View Post
Tracking has improved over the course of our road trip. Wearing in new tires?
Seems unlikely... plausible I suppose.
Old 04-30-2017, 10:57 PM   #127
LC4CARL
Aero challenged
LC4CARL's Avatar
Well whatever the change, I can now take my hand off the wheel on the highway. I appreciate all the input.
'87 245 DL: B21FT in the works!
Old 04-30-2017, 11:00 PM   #128
The Mrs taking a turn at the wheel?
how psi a stock can support?
Old 05-01-2017, 01:18 AM   #129
LC4CARL
Aero challenged
LC4CARL's Avatar
I offered / she declined. Been a while since we've owned a stick shift.
Remember column shift cars? Always a good time.
Old 05-01-2017, 06:21 PM   #130
LC4CARL
Aero challenged
LC4CARL's Avatar
Made it home from Davis. As the smooth highways of Northern California rolled by and we returned to the wagon wheel ruts of Oregon's studded tire roads, so to the wander returned. Oh well. Not terrible. Just there.
Old 05-01-2017, 06:23 PM   #131
Our 64 Buick special wagon had a 310 Wildcat engine, and a three on the tree.
Old 05-01-2017, 06:37 PM   #132
KeizerBrickGuy
KeizerBrickGuy's Avatar
My car wanders on our lovely rutted roads, to an extent as well. Hope Davis was all you hoped it to be?
-Stephen
#mclovethesenuts
-Wife's car: White 1990 244DL, T cam, 190k miles.B230F LH2.4, AW70 w/aux cooler, Duracool AC, purple refinished Virgos, tow hitch, ipd wagon overload springs.
Old 05-02-2017, 12:27 AM   #133
LC4CARL
Aero challenged
LC4CARL's Avatar
I remember when I was a kid and we borrowed a neighbor's car. Mom climbed behind the wheel, looked at the column and said: "This should be interesting." Like riding a bike. She did great.
Old 05-02-2017, 12:31 AM   #134
LC4CARL
Aero challenged
LC4CARL's Avatar
A small price to pay for cat-like handling, eh?
Old 07-10-2017, 07:09 PM   #135
LC4CARL
Aero challenged
LC4CARL's Avatar
I think I found the problem...
Old 07-11-2017, 01:31 AM   #136
LC4CARL
Aero challenged
LC4CARL's Avatar
Tough crowd...
Old 08-09-2017, 09:48 PM   #137
petiww
petiww's Avatar
Bump! Because i have the same issue and it is annoying.
Stock suspension minus -1.5coil off upfront, balljoints are tight, steering rack is tight, bushings are new or good condition. But when I'm holding the steering wheel in one position on a little wavy road the car starts to wander and i need to "countersteer". Happened on completely smooth highway too and was a bit weird.
Car has working PS, PS balljoints, and also i moved the control arms 6mm forward to gain a little bit more caster. It tracks straight, toe is somewhat good but I did not take the car to an alignment yet.
It sort of feels like the rear end just steers the car with the big rubber trailing arm bushings. Want to go spherical there, do you guys think it will improve the situation?
1980 Brown 244 GL
Old 08-09-2017, 11:53 PM   #138
One hundred gift baskets
How much air pressure are you running in your tires? What's size tires and rims? My 235/45/18 kumho v720 grab every ripple and rut in the road, but it's much worse with too much air in the tires, they're only drivable at 28 psi or less. My 195/65/15 also make the car almost comfortable to ride in, but also at around 28psi. I'm on cut springs with Koni s so the ride is very stiff regardless.
1980 primer Franken-242DL, 1989 silver 780 bone stock.
Old 08-10-2017, 01:00 AM   #139
quillc
yv1a.com
quillc's Avatar
LOL, I learned to drive on my parents 75 Ford Grenada with a three on the tree.
Chris
www.yv1a.com
Old 08-10-2017, 07:16 AM   #140
petiww
petiww's Avatar
Interesting!
I'm running stock GT rims with 195/60r14 tyres at 2,5bar.
Old 08-11-2017, 08:13 AM   #141
petiww
petiww's Avatar
Dropped tire pressures to recommended values, 1,8bar front, 1,9bar rear and it seems this weird issue is improved! Will play with pressures more to see if it really cured the wandering.
Old 10-30-2017, 01:07 PM   #142
LC4CARL
Aero challenged
LC4CARL's Avatar
Interesting read:
https://www.tirerack.com/tires/tiret....jsp?techid=47
"Tires have the most direct influence on tramlining because..."
The tires I took off were unsafe, so I don't have a good back to back comparison from the old tires to the new tires. I would be curious to swap on a different set of wheels / tires and see what changes. If anything.
Old 10-30-2017, 05:08 PM   #143
LC4CARL
Aero challenged
LC4CARL's Avatar
I put wider tires (215's I think) on a '76 Celica once with no problems. On a '77 Z28 the car went to heck with 245's. But at least I looked cool.
