Old 06-12-2017, 11:17 AM   #1
EivlEvo
Default Manifolds and Manifold Design?
So... using what little logic I possess, I've traced the whistling, and "louder valves" to actually be an exhaust leak on my car.
This is most likely a cracked manifold because obviously.
My question is...
If I were to make my own manifold, what setup works best on the 240 B230F+t?
I know the crappy ebay one moves the turbo further forward (why?), but I don't know that I've seen anything else.
Thoughts?
Old 06-12-2017, 11:21 AM   #2
greasegram
Member Board
greasegram's Avatar
Why not repair the existing manifold?
8v death squad
greasegram is offline   Reply With Quote
Old 06-12-2017, 11:26 AM   #3
JohnMc
JohnMc's Avatar
Moving the turbo further forward gives you more room for a larger turbo, if you are so inclined. There's space in the front corner of the engine bay, but there's not much you can do about the shock tower in the stock (or close to) position.
'63 PV Rat Rod
'93 245 16VT Classic #1141
Old 06-12-2017, 11:50 AM   #4
EivlEvo
If I have to yank it off of there anyhow, I may as well get into other turbos and such. I have a spare 16G lying around that could probably use a new CHRA. Might be nice to set this up with an external gate and try and blow my motor.
Otherwise disco potato or maybe cheap holset.
Anybody know what size turbos reliably fit on stock manifolds? Don't the holsets just bolt up?
Old 06-12-2017, 01:22 PM   #5
Benjam83
Moar Volvos than Queen B
Ah yes, the old "While I'm at it...." thought process.
I like it...
Ben
12 WRX Hatchback
10 Subaru Outback
93 245 m47
Benjam83 is offline   Reply With Quote
Old 06-12-2017, 01:25 PM   #6
linuxman51
BRANDSCHUTZVORSCHRIFTEN!
linuxman51's Avatar
the 3076R in the blue car I'm working on does quite well..
Megasquirt Tuning!
Old 06-12-2017, 02:00 PM   #7
EivlEvo
Where you put it though? Forward? Or stock position? Which manifold?
Also... I mean, broken studs are a thing man... I'm not trying to be taking this all off a million times. I'll die!
Old 06-12-2017, 02:18 PM   #8
centason
Knipex=welfare queen
centason's Avatar
J-pipe is the easiest with a NA manifold. Has to be braced. There was a good example of one done correctly, I just can't find the pic/thread.
Member: TBCCS
“The demagogue is one who preaches doctrines he knows to be untrue to men he knows to be idiots.” -H.L. Mencken
Old 06-12-2017, 02:23 PM   #9
EivlEvo
Car is already a +t.
I wouldn't go J pipe.
Old 06-12-2017, 02:25 PM   #10
centason
centason's Avatar
I'm just saying if you were to build your own, that's the easiest way. +t is +t... you're asking about manifolds.
http://forums.turbobricks.com/showth...er4life&page=5
Old 06-12-2017, 02:48 PM   #11
linuxman51
linuxman51's Avatar
it's on a stock manifold. snug, but not impossible. I don't break too many studs, and at any rate, they're cheap to replace. normally the studs come out of the head if they've been in a while.
Old 06-12-2017, 03:07 PM   #12
Tfrasca
Tfrasca's Avatar
How does that not hit the strut tower when the engine rocks?
Old 06-12-2017, 04:15 PM   #13
linuxman51
linuxman51's Avatar
good mounts. it's not quite as close as it looks, but it's snug.
Old 06-12-2017, 04:41 PM   #14
Marvelous3
Who engineered this?
Marvelous3's Avatar
That thing has gobs of space.
Old 06-12-2017, 05:00 PM   #15
mopar318
mopar318's Avatar
There isn't a whole lot of space due to the strut tower so you have to move the turbo up closer to the radiator.
There is my example. There will be more room with a 8 valve
Pimps out interiors.
1980 242 16 valve turbo
2007 V70R
mopar318 is offline   Reply With Quote
Old 06-21-2017, 02:00 PM   #16
EivlEvo
This all good info... thanks crew.
Old 07-13-2017, 12:16 PM   #17
EivlEvo
I have updated questions as I begin the journey to Holset land.
The general consensus is to grind the flange off of the stock B230FT turbo manifold, and mount holset there.
Is this considered better than log manifold or j pipe? I have both NA and turbo manifolds available to yutz with, and Holset 351 has a wastegate port welded to hotside so I believe I should be good to go in that sense...
TLAO was just implying in another thread that the J pipe proved to be quite limiting compared to his custom equal length setup. This would seem obvious to me, but I wonder how it compares to just a stock turbo manifold? Just trying to weigh out my strategy and options moving forward here.
Old 07-13-2017, 03:04 PM   #18
gross polluter
They see me trollin'
gross polluter's Avatar
I'm confused how it's limiting when the car in question was performing the same with less boost.
Old 07-13-2017, 04:01 PM   #19
EivlEvo
Maybe I missed that part. I read that that car seemed to hit a wall at about 18psi (don't quote me on this). Whereas he was able to bring his up to much more boost.
I'm asking more than stating. My suggesting that was merely my interpreting it. But I'm genuinely asking what people think is better now.
Does anyone have any flow numbers (I can't imagine) on the turbo manifold vs an NA manifold? Anything with up/J pipes?
Old 07-13-2017, 04:22 PM   #20
thelostartof
unbalanced chemical
thelostartof's Avatar
It didn't hit a wall, that is just the boost he was running.
J pipe will perform way better than a 90+ in my mind.
Old 07-13-2017, 04:55 PM   #21
EivlEvo
J pipe on an NA manifold? Interesting... what do you suppose causes that?
Old 07-13-2017, 05:14 PM   #22
A tough rowing ho
Because twin scroll?
Old 07-13-2017, 05:55 PM   #23
gross polluter
This is correct. On both my car and Josh's 242 there was approximately 18-25% difference in VE across the powerband between NA manifold with J pipe and 90+, the NA manifold with J pipe being greater in engine VE.
Still didn't stop us from making 400whp on a 90+ adapted to a 16v head.
Old 07-13-2017, 05:59 PM   #24
cosbySweater
cosbySweater's Avatar
If he's not doing any head work I vote 90+ for 99% of tbrick builds
1982 Ford Fairmont Futura. 3sge Beams, j160 6speed, full aje suspension and tubular arms everywhere
1995 Porsche 993
Old 07-13-2017, 06:12 PM   #25
gross polluter
Agreed. Although not as ideal as other options, it won't be the weak link for the 99% of the setups on this forum.
