Old 06-20-2017, 06:50 AM   #1
benbull
Thumbs up Fun Volvo 940 Rally project...
A friend and I have just purchased this volvo 940 2.3t (think its the B230fk).
We're driving it to the Nurburgring in Germany (from the UK) in September for a friends stag do.
Its had no performance upgrades, so we were thinking of doing some work! Thoughts are...
Lowering
Exhaust (more noise required!)
Engine/turbo tweaks
This is all on a budget, and for a good laugh! Would appreciate some advice/thoughts!
benbull is offline   Reply With Quote
Old 06-20-2017, 07:27 AM   #2
jakemness
jakemness's Avatar
Looks like a fun project! The cheapest way to get a little more out of it would be to get a manual boost controller (for the turbo) and turn it up a couple more psi. Make sure you have a proper boost gauge though so you can keep track of the psi. Keep us updated on the progress.
jakemness is offline   Reply With Quote
Old 06-20-2017, 10:35 AM   #3
crogthomas
crogthomas's Avatar
Originally Posted by benbull View Post
Lowering
Angle grinder, spring compressors. Cut a coil off the front and rear. You then be the same height as the 'Sport' model and no risk of them dropping out.
Remove everything after the cat. Add a 90 degree bend that exits out the side.
Engine/turbo tweaks
MBC as mentioned by jakemness (aim for about 1bar), plus search on here for airbox modifications (basically; remove foam and open up the cold air inlet part).
For the Nurburgring I'd look at getting some decent brake pads fitted. At the very least put some new standard ones in to try and prevent them overheating.
Have fun. Take pictures.
crogthomas is offline   Reply With Quote
Old 06-21-2017, 04:39 PM   #4
benbull
Great, all things we'll definitely get sorted! Thanks!
Old 06-21-2017, 04:50 PM   #5
PCH
What kind of fog lights there and do you have any pictures of how they are mounted?
Old 06-22-2017, 04:53 AM   #6
benbull
Collecting it tonight, so will let you know..
Old 06-22-2017, 07:46 PM   #7
classicswede
Volvo upgrades
rally car wants to be reasoably hgh but track car can be low
Old 06-23-2017, 06:30 AM   #8
p18002.5t
Get hold of some bosch green injectors and a 960 3"MAF and get the fuel ecu chipped, then get a 3" downpipe and exhaust.
The cheapest way to increase boost is to shorten the wastgate rod.
Good luck and have fun
p18002.5t is offline   Reply With Quote
Old 06-29-2017, 06:37 AM   #9
Janspeed
the stock wastegate actuator on a B230FK is not adjustable. But you could add an additional spring to keep the wastegate shut just that little bit longer. That will raise boost.
Or find some other stiffer actuator and make that work.
Old 07-03-2017, 10:31 AM   #10
benbull
We've fitted a manual boost controller and gauge, running 10psi..ish.
It already had a side-exit exhaust, but we really want to lower it, so will probably have to run that back to the rear, as it will hit otherwise.
Old 07-03-2017, 12:45 PM   #11
mark244turbo
mark244turbo's Avatar
Camber and caster mod + 960 subframe braces will greatly improve the front grip and handling of your car.
1994 960 B204FT, full options, leather interior.
1991 745 B204GT (Swede Sixteen VT) M90 conversion.
1986 745 B230FT, 302mm V70 brakes, camber mod. (sold)
1983 244 turbo B21FT/AW71 - leather /airconditioning
1987 244 GLT - Polaris, Strutbar, lower chassis brace, k-cam
mark244turbo is offline   Reply With Quote
Old 07-05-2017, 05:10 AM   #12
benbull
We want to fit a dump valve.. purely for the noise/laughs...
I'm wondering if the area I have circled in yellow is a recirculating valve of some kind, and can be replaced with the dump valve, or have I got that completely wrong and its something else that needs to remain!? ...
Old 07-05-2017, 05:50 AM   #13
JerryJS8
der Junge
JerryJS8's Avatar
That's your idle control valve, you'll want to leave that right where it is!
- 1992 480 (Renault disaster)
- 1989 745 16v
- 1991 744 (SE) Turbo 16v (restauration project)
Old 07-05-2017, 06:09 AM   #14
benbull
ah! indeed...
can we 'T-off' the pipe circled red? Or somewhere better to pop her?
Old 07-05-2017, 12:58 PM   #15
J_Jones
J_Jones's Avatar
Should have a Mitsubishi turbo and I think you can use the srt4 bov with that, used to be cheap. Might mess with how the engine runs though, no experience so not sure.
Old 07-13-2017, 05:14 AM   #16
benbull
I see that attaches directly to the turbo? and actually tricky to get hold of.
We've been given a blitz dump valve from a friend, is it ok to plumb that in somewhere on the intake pipe? Or is there essentially already one fitted to the turbo... and this will cause issues?
Cheers
Old 07-13-2017, 08:47 AM   #17
crogthomas
crogthomas's Avatar
Yes. Issues.
Fitting a dump valve tends to make the engine stall every time you dip the clutch. This becomes very tiresome very quickly.
The problem is metered air exiting the system and causing a rich mixture.
The car already has a 'dump' valve in the form of a recirculating compressor bypass valve attached to the side of the turbocharger itself. This puts the metered air back into the system and thus avoids the issues.
If all you want is more noise then take the airbox off and replace it with a open cone filter. But be aware that you'll probably lose power as the Volvo airbox is very well designed.
Old 07-13-2017, 09:05 AM   #18
Uncleknucklez
bruspeed
Uncleknucklez's Avatar
If you are looking for BOV sounds, This is the best way to do it. I love the way the Mitsubishi Recirc valves sound!
1980 242 Turbo
2004 V70R
Old 07-18-2017, 07:09 AM   #19
benbull
ok.. cheers all.. will leave that all as it is, and yes, just stuck a cone on it... despite the slight performance loss, I doubt we'll really notice!
..does sound good!
