Old 07-01-2017, 10:11 PM   #1
Joe_Diesel
Joe_Diesel's Avatar
Default Wheel Fitment/Experiences 700 Series
So I want a set of these wheels I found on eBay for my 1989 780 Bertone which currently has 6Jx15 ET25 multi X wheels with 205/60 R15 tires on it and stock suspension all the way around with nivomatic shocks that do sag down after a day or so almost to where I feel like it would sit on larger wider wheels. Anyway my question is has anyone tried fitting 18x8 ET30 wheels on their 700 series? I would use hub centric rings to adapt them right (65.1mm to 74mm) and the bolt patterns match one another 5x108. Would they fit, front and rear? Would they rub at full lock? And if so whats t a comfortable good looking 18" tire to run.
Joe_Diesel is offline   Reply With Quote
Old 07-01-2017, 11:45 PM   #2
AndrewNance
Amateur hour!
AndrewNance's Avatar
8" et30 is going to rub something somewhere on the inside. The wider you go, the further out you need to push the wheel to keep enough clearance.
'71 142
'80 245
Feedback
Old 07-02-2017, 12:19 AM   #3
Steve Beswick
Edit: I was just being snarky. Never mind this post.
Steve Beswick is offline   Reply With Quote
Old 07-02-2017, 12:19 AM   #4
First off mulit X are 20et.
Secondly an 18" tire @ 25" Ø isn't going to ride nice.
how psi a stock can support?
Old 07-02-2017, 01:27 AM   #5
daijoubanai
waste of skin and blood
daijoubanai's Avatar
I already replied to your PM, but the short answer for good fitment with those wheels would be 20mm adapters on the front, 10mm spacers on the rear.
Oh, and they wont be comfortable, as you'd probably be running 225/40/18 tires, which don't have much sidewall. And in my opinion 18's don't look good on a car that's not lowered anyway.
daijoubanai is offline   Reply With Quote
Old 07-02-2017, 07:25 AM   #6
reed
reed's Avatar
I'm running 17" pegs with the ipd spacers and 225 45 17. If that helps. I'm also lowered and have a adjustable pan hard rod. With my thrust angle at 0, I run a little on the right rear inner tire and left rear outer tire over big bumps.
reed is offline   Reply With Quote
Old 07-03-2017, 01:45 AM   #7
LC4CARL
Aero challenged
LC4CARL's Avatar
Pix please. This sounds sweet.
'87 245 DL: B21FT in the works!
Old 07-03-2017, 07:45 AM   #8
reed
reed's Avatar
I'll see if I can put some up today
Old 07-03-2017, 11:06 AM   #9
fortbrick
fortbrick's Avatar
17x8 et-5 barely clears the inner wheelwell on full lock, so YMMV.
18's with proper size tires are going to make the car look like a truck if you don't lower it.
Old 07-03-2017, 11:56 AM   #10
LC4CARL
Aero challenged
LC4CARL's Avatar
8" sounds pretty wide.
I like it...
Old 07-03-2017, 12:04 PM   #11
1slo9_4_oh
1slo9_4_oh's Avatar
I don't know bout the its equipped cars but my 95 940t has custom diamond steel wheels thay are 5x108 16x8 0 offset
1990 Volvo 740 Sedan Turbo 371k M46
-16t at 16lbs daily, 3"maf, 3"intercooler piping
-huge fmic, 390cc gm injectors and 2.5" straightpipe
-blitz bov and turbo timer, saab fuse harness (hids,fogs,a/c)
-ipd sways front/rear, lwr chassis and strut bar, billy hds
-hood bra, 850 roof rack, 740se spoiler, 760 front end swap
Feedback Thread:
http://forums.turbobricks.com/showth...88#post4905988
1slo9_4_oh is offline   Reply With Quote
Old 07-03-2017, 05:52 PM   #12
Joe_Diesel
Joe_Diesel's Avatar
This is all very helpful. I guess I should start by lowering the car first and worry about wheel fitment later. I'd like to keep the multi X look but just larger because I think they look classy which is why when I saw some used BBS for cheap I got so interested. Maybe I would go 17" then if they'll ride that poorly. I was basing the idea of a photoshopped 780 on google images.
Old 07-03-2017, 05:53 PM   #13
Joe_Diesel
Joe_Diesel's Avatar
https://s-media-cache-ak0.pinimg.com...98f6841fe9.jpg
Old 07-03-2017, 05:58 PM   #14
reed
reed's Avatar
https://i.imgur.com/5ksWtqn.jpg
Old 07-03-2017, 06:03 PM   #15
reed
reed's Avatar
http://https://i.imgur.com/5ksWtqn.jpg
Old 07-03-2017, 06:03 PM   #16
reed
reed's Avatar
I don't know how to inset pictures
Old 07-03-2017, 07:35 PM   #17
Phezero
fixed it for you. just needed to add [IMG] tags
Phezero is offline   Reply With Quote
Old 07-03-2017, 07:43 PM   #18
reed
reed's Avatar
Thanks. So I need to add hat before and after the link?
Old 07-08-2017, 09:01 AM   #19
Joe_Diesel
Joe_Diesel's Avatar
I like that look a lot, how much is it lowered? And do you think with some more spacing, you could avoid rubbing in the rear?
Old 07-11-2017, 09:30 PM   #20
reed
reed's Avatar
I could probably adjust the panhard rod so it won't rub. But I want the alignment right. The rubbing is very minor. Not sure how much it's lowered. Maybe a inch
